The use of
Александр79
The use of
Post by Александр79 » Tue Mar 24, 2009 14:31
Hello dear.
I can not figure out how to use the discs. Just listen to player? Or something in conjunction with MM? If MM, then how to do it which session to include together with MM, never found a description that as a Yes :)
Post by Dimas » Tue Mar 24, 2009 15:07
Александр79
Hello!Yes,you can just listen to these CDs on headphones with the player,session, together not necessary to include,you need to put the car in mode audioscrobbler is written in instruktsii to the car.
Post by Guest » Tue Mar 24, 2009 15:11
you have included is a wire... you take the player back... hectic drive... include...wire connect the player and mm... mm... include right upper pimpochki press 3 times there appears Aus or something similar (on disk identity is written that he with strobe)
in ears have the sound to go with glasses flashing
theta drives are coming without gate them on a computer or player sluhay can
session and the disks together is better not to listen - it's for adventurers (the effect is not predictable) sometimes it gluknet to the brain can be that fucked up...
the conductor and the solar wind (preferably white color to put in the glasses)
good luck..
going forward
Post by Guest » Sun Apr 05, 2009 14:19
Hello! Poskazhite, please. Bought a mind machine, MindSpa, turn the disc A. Patrushev Explorer, start listening and after half an hour mind the machine is turned off. You have to turn it back on. Does anyone had the same problem. I would like to still listen to with glasses. Thank you.
Post by Dimas » Sun Apr 05, 2009 16:15
Please read the user manual,there is a button that turns on audiostrobe decoder.When You turn the machine off stops..
