Whether the effect from MM, if one eye sees?
Good day, my Psychonauts!
A long time looking at MM, but that's question one.
I have one eye does not see - does this mean that the visual component will have no effect and points can be waived?
Идущая вперед
- Been thanked: 6 times
my dad's eyesight is -10 severe myopia and blurred something there... some body in the eye forgot the name... in early summer gave him to listen to the alpha session... he says that the brightness of the colors improved 2 diopters improvement ie I was 8... then he had a cottage and he scored on mm... well wait as it was and left... ahhh voooot - vitreous opacities this hranica called... ie 1 month of regular classes there were some improvements on the face....
I think that before to buy mm - bylob bad to go to the optometrist-ophthalmologist and consult a Pro and good spec in this area
you have still one eye sees... through him the stimulation going
going forward
going forward
I wonder how many ophthalmologists studied the effect of sitostanol on vision? And that, in this unfamiliar region they can advise?Идущая вперед wrote:I think that before to buy mm - bylob bad to go to the optometrist-ophthalmologist and consult a Pro and good spec in this area
Most likely, the impact will have an effect and through one eye. I would glasses not refused.Нифтяк wrote:in my one eye does not see - does this mean that the visual component will have no effect and points can be waived?
Re: Will the effect of the MM, if one eye sees?
Will - with a slight bias to one hemisphere.Нифтяк wrote:Good day, my Psychonauts!
In the process of adaptation to blindness in one eye, most likely, the nerve fibers have already leveled off by the thickness and the speed of conduction of impulses (each eye is initially associated with obemy hemispheres), so the bias may not be. In addition, the repetition frequency of only the first 5-9 minutes recorded in the relevant derivations in the visual cortex, and then gradually captures the whole crust. "Disharmony" and "imbalance" somewhere "another story."Anonymous wrote:disharmony and imbalance of the hemispheres is not harashi...
Алексей_1962
Andrew, Hello! I am 47 years old, right side is silent. The defeat of the cochlea at the level of the hair cells. Tell me, please, in my case the lack of "stereo" much hurt? And, basically, I can and side effects me I will enter in a trance that I dream of waking will. Or not get there? The practice is?
Sincerely, Alex.
Sincerely, Alex.
Hello, Alex!Алексей_1962 wrote:Andrey, Hello! I am 47 years old, right side is silent. The defeat of the cochlea at the level of the hair cells. Tell me, please, in my case the lack of "stereo" much hurt? And, basically, I can and side effects me I will enter in a trance that I dream of waking will. Or not get there? The practice is?
Sincerely, Alex.
It's hard to say. Several people in my memory with similar issues should be dealt with mashinoy without any unpleasant side effects and with great benefit to myself, But with two CCI (if I am not mistaken
Нетрезвый Сурдопереводчик
- Been thanked: 1 time
You are likely to use, but should be approached with caution - brightness of minimum...Старец Вольдемар wrote:belonging to neither one nor the other.this variation --the result of a blow to the superciliary arc.eyes,where "-" the evening noticeably strained,1 lens,where "more"Андрей Патрушев wrote: It's sharpness and sensitivity how (cataract, glaucoma)?
Анонимус
I have almost the same question - whether the effect if one eye sees? The situation is left eye -11 and right after an unsuccessful operation is deprived of the crystalline lens, plus retinal degeneration. That is preserved peripheral vision in my right eye (very bad, without the lens fact), and the center of the field of view - black the blind spot.
Primarily interested in relaxation and meditation prgoramme. Will result from the use of MM and what are the possible problems? And generally - whether it is dangerous with such a skewed view to use MM?
Thanks in advance.
Thanks in advance.
