Mind-Machine with out the ganzfeld-goggles.
Пафнутий
Hello!
Do You have in selling this? If not, strangely, in the West there are several models. Some inexpensive... the Effect is indeed very powerful, as I understand it?
In case you lack the required product may be, Andrei Patrushev will advise that you can use as an object, which is associated with Infinity, as he advised in his article. In addition to points from balls for ping-pong. Be difficult to illuminate evenly. Or it is possible to achieve uniformity of lighting? Thanks in advance.
and for the ignorant more?
Experience shows that if you blink more or less evenly "lit" the entire field of view.
Ie for my taste, a General lack of abinah led points only one small dynamic range of brightness. Attempt the (apparently not 100% successful) directly to the points signal compressor made in all your favorite ColorTrack sometimes leads to opposite results - see for example, A. Patrushev, "Music for hypnosis and self-hypnosis" - three very-fine "ragged" light for the disk, regardless of settings. Many (including staff) sessions of MM also "does not hold" dynamic range...
Ie if someone dug that better ColorTrack - please write.
Andrew, thank you!
But what about the typewriter, about which Logic said Laxman (Germany)? Look what a serious thing:
http://www.mindmodulations.com/prod-neu ... 3wod9GCCmQ
In Germany, it's probably two times cheaper, and given the crisis, it is possible to take probably almost nothing. In the States now for many products discounted up to 90 percent. In Europe - about the same. The only country where during the crisis, prices continue to rise - Russia. However, this particular product, the type of luxury item... the price may not fall.
Laxman, which also gives a real Ganzfeld effect? What do you think, Andrew?
And what kind of SLR did You use? The distance to the eye? Bulb shape? Spectral characteristics?
I have a halogen floodlight. Pastwatch. But they will burn a person if close. Spotlight sumasshedshei is heated to this temperature. Besides, lamp cigar-shaped, and should be, probably, round as a reflector?
Guest, this is a special effect, like a mirrored hallway, only produce points. It is even in itself activates the right hemisphere is very not weak. And it is all people have greatly atrophied since time immemorial. Therefore, we cannot, as, for example, representatives of Ancient civilizations, to cause changes in Reality simply desire. Access to the Subconscious blocked. And all Magical practices, as you know, performed by the Subconscious mind. "You have the whole World or the whole World is you. The third is not given". V. Shlahter. In order to successfully manage the reality rather than be her slave and carcass for experimentation, in particular, the required maximum integration of the conscious and subconscious.
Пафнутий
No, I made a mistake on the part of the price. In Germany it is the same as in the States. Only in Euros.
http://www.neurotronics.eu/shop/index.p ... c080a5c0f9 http://www.mylaxman.de
See the wholesale buying. But the Germans send separate points. For reasons of hygiene, if multiple users. Still, the German cleanliness is something. Interesting, but will these glasses work with the machine proposed for this site? Probably not? Andrew, what do you say? Threw You questions, you will excuse me.
In General, most of the reviews on foreign sites is that this machine is a new word. No comparison with anything. The level is better. One that can open eyes to work, well worth it. It undermines the Point of Assembly. Very useful. With closed eyes You used to dream and dream. And anything unusual that You see with an open mind, "blab" ossified perception of reality. And You can see it differently. In short, as I write, almost LSD, but without the side effects.
Expensive, however. Especially at the current exchange rate.
I have never used a Mind-Machine. Hemi-sync "Gates of Perception" went up and down.
In General, these visions that occur when exposed to light, it is possible to manage? I mean, in the imagination to build their own reality, very bright and lively? Or is it uncontrollable? Just with sufficient study and we present the visualization of virtual information (like Astral) reality reaches such a degree of concentration that will begin to materialize in physical reality. If you have in hands a powerful magical tool, not a toy.
Пафнутий
Still, I'd like to hear Andrei Patrushev. What he says about the German Machine.
May not need light components? Monroe at the time it was abandoned. Headphones with Hemi-syncom + acid to throw. Never tried Hemi-sync with psychoactive chemicals. Can most it. Maybe the tower will fly off forever.
What's so special about these Mind-Machine, which does not give BWG Hemi-sync? Without Ganzfeld effect, especially... It's the only thing in all of this I found it interesting.
Never make public something that will effectively develop the consciousness. The state is advantageous to further enslavement and brainwashing, not liberation. Monroe thought for a long time before to insert the Fifteenth Focus in your Waves for the user. Because it's a really powerful Magical State.
