Strobe Signals. It's not just blinking to the music?!
What is strobe signals (recorded with music on a CD)? In accordance with what principles they blink? It's not just the flashing to the tempo of the music. If you imagine that the strobe signal is a special language - then what is written in this language??? I hope you understand the question asked )))).
Re: Strobe Signals. It's not just blinking to the music?!
This, in particular, and the flashing in the tempo of the music and at the same time, as You write, a special language - the language of the brain. And spelled out the language of psycho-physiological state.VADim wrote:What is the strobe signals (recorded with music on a CD)? In accordance with what principles they blink? It's not just the flashing to the tempo of the music. If you imagine that the strobe signal is a special language - then what is written in this language??? I hope you understand the question asked )))).
On the forum quite a lot more about audiostrobe written...
Andrew, where can I find this "language"? I would like to know more about the mechanisms which operate when viewing the strobe signals. How can I to make their discs I'm interested in parameters? I understand that this is a large amount of information, but maybe the links you have or still that-thread on this issue?
Were collected at this site to read everything available online on this subject. Specific questions will be answered.VADim wrote:Andrew, where can I find this "language"? I would like to know more about the mechanisms which operate when viewing the strobe signals. How can I to make their discs I'm interested in parameters? I understand that this is a large amount of information, but maybe the links you have or still that-thread on this issue?
Andrew, I clambered whole site can't find anything, on the subject of creating discs. From a technical point of view, I understand everything. I can't understand how for example on music gr. Ramstein - put signals that would get the effect of vivacity.were collected At this site to read everything available online on this subject. Specific questions will be answered.
Also saw somewhere you saying that you BrainWave Generator can automatically generate gate signals. Too I know the program didn't find anything similar (well, maybe I do not yet fully understand).
Can you tell me any thread of reference to give?
The forum has become so large that not all posts manage to reply on time.
In the article "help for the wounded..." in the application given to all frequencies. Audiostrobe can be done using Cool Edit Pro (Adobe autdition) using amplitude modulation on the carrier 19200Гц. On the spectrum analyzer in the mix, the power of this frequency must be within the "-36dB" well, it is possible to raise up "-33дБ". Below is not enough for the decoder of sensitivity, higher the overload (all will be lit without blinking).
In BWG, it is also possible to take the bearing 19200Гц and do with it anything.
Good Luck Running!
Good Luck Running!
татьяна анатольевна
I think that this is the chip produces the player, since the spectrogram for the mp3 after 15kHz signal is present.Anonymous wrote:Good day!![]()
Recently became the owner of Inner Puls and decided to conduct an experiment: connected to IP your MP3 player, Schaub to look into it? got that almost all of my collection has AS signal points blink on ANY songs!!!??? - is this normal? or is it meant to be?
Some distortion will, of course, but the useful signal is still stronger, I think, will block...Anonymous wrote:another question Then:
I have a few AS drives, but no CD player, by distillation in WAV format if they properly play with the MP3 player, or trouble "...the chip produces the player..." is to distort the true AS the effect?
Damn, read 2 times (best, Audiograbber 1.8* don't forget to turn off all effects, compression, and normalization) - 2 times a single disk.
And then compare the read wav's - if the same means procialis. If not - read on. Audiograbber 1.8* good, in particular, that allows different reading modes, i.e., if a full-time "dinamic sync width" doesn't compare - try buffered or unbuffered burst copy burst copy - sooner or later 2 of the track match. This ensures that the TRACKS are READ WITHOUT any LOSSES, the only loss - sdvizhka to several. tens of bytes of all tracks (the value changes - experience shows - constant for your CD/DVD drive).
AND NO LOSS.
AND NO LOSS.
AND NO LOSS.
AND NO LOSS.
AND NO LOSS.
AND NO LOSS.
And please remember - audiosector (minimum a unit of information on the audio-CD) (about 3 KB) is read as a WHOLE in it (in data read) no high frequencies, no low, and no way to know - read it correctly or not. The only thing is - block correcting reed-Solomon code, "smeared" possible read error in most cases in the form (to the ear) a light noise, usually unnoticed. 2 (or 3, if you skinny to paranoia) fold schityvanie track the results of gives almost a guarantee that the track is read.
(comparison:
>a comp.wav b.vav
either
>fc/b a.vaw b.wav
"The shift" at the rate that less sector is the property of the principle organization of data on disk and not a defect.
I knew (old and expensive) drives, which changes not given; unfortunately all the known ATAPI / SATA devices have shift schedule (it changes the boundaries of the track(s) in units of milliseconds and can be neglected) is the only morality from the fact of its existence is that a single drive must be read on one drive. Matched tracks count is not necessary.
THIS is NOT SAID in ORDER to MAKE COUNTERFEIT copies of the DISKS (for this, as a rule, do not resort to such a "thin" technologies), BUT in ORDER to DO a PROPER BACKUP OR RIGHT to MOVE YOUR CD TO YOUR FAVORITE PLAYER THAT PERMITTED by APPLICABLE LAW. As well AS BECAUSE took the CART FROM the CYCLE "COPYING DISCS WITH HIGH FREQUENCIES" and the like.
(comparison:
>a comp.wav b.vav
either
>fc/b a.vaw b.wav
It is possible and correct:Anonymous wrote: unfortunately, all known ATAPI / SATA devices have shift schedule (it changes the boundaries of the track(s) in units of milliseconds and can be neglected)
http://cd2flac.narod.ru/fooAddons.htm
