Sweet...
Zdravstvute!
After several months of work in psycho-acoustics(drives A. Patrushev,as well as other CDs with the binaural beats and different set of frequencies(alpha/theta)listening to the music of George.Thompson,etc.) and mind machine,the last couple of weeks there was a greater desire to eat sweet.I used to eat sweets but now I eat it many times more,well, too strong a desire! Is there any connection between all this?
Re: sweet...
Never had a complaint before...САМОЛЕТ wrote:Zdravstvute!
What do You have with liver and(or) with pagelocal?
Yes, everything was in order there.Sweet just want more than usual....May be the brain due to exposure to the psychoacoustics need sugar....or whatever they say-glucose.For example,during strenuous mental activity,well, for example when the delivery of the session,when working on kandidatskoi thesis, etc., recommend eating dessert,chocolate.Moreover,some of them noted an increase in the desire for sweet at such times.Maybe it can hold some parallel?Because I think psychoacoustics and mind of the machine quite strongly act on the brain....
Sugar is fuel for the brain, but its high consumption have a brain, at least, something much load...Anonymous wrote:Yes all was in order and there is.Sweet just want more than usual....May be the brain due to exposure to the psychoacoustics need sugar....or whatever they say-glucose.For example,during strenuous mental activity,well, for example when the delivery of the session,when working on kandidatskoi thesis, etc., recommend eating dessert,chocolate.Moreover,some of them noted an increase in the desire for sweet at such times.Maybe it can hold some parallel?Because I think psychoacoustics and mind of the machine quite strongly act on the brain....
I noticed that, too.
When listening to the Endorphins for an hour a day.
After about a week I wanted to eat the entire tray of pies in the store.
The shakes started, get the juices flowing.
Ate 10 tablets of ascorbic acid with glucose, a chocolate bar, washed down with water... and then came katushka.
оуаакун wrote:I also noticed.
After about a week I wanted to eat the entire tray of pies in the store.The shakes started, get the juices flowing.
In-in about as well with me.The day before yesterday in the morning, ate 15 pieces of "School"candy.And in the evening two tiles white chocolate and a few pieces of biscuits...
So listening psychoactive disks and the use of a mind machine-it already is a good download brain,IMHO....Андрей Патрушев wrote:Sugar is fuel for the brain, but its high consumption have a brain, at least, something much load...Anonymous wrote:Yes all was in order and there is.Sweet just want more than usual....May be the brain due to exposure to the psychoacoustics need sugar....or whatever they say-glucose.For example,during strenuous mental activity,well, for example when the delivery of the session,when working on kandidatskoi thesis, etc., recommend eating dessert,chocolate.Moreover,some of them noted an increase in the desire for sweet at such times.Maybe it can hold some parallel?Because I think psychoacoustics and mind of the machine quite strongly act on the brain....
On the one hand, of course, the burden is, but relative to the disc, the Endorphins, perhaps the most likely, is a reflex. For example You used to enjoy (of course, the release into the blood of endorphins)from the sweet, now increasing the level of endorphins to the same thing from sweet, got sugar cravings. I would refrain from excessive consumption of sweet (soon to be) - and to diabetes, you can roll. Replace better with something useful and harmless in terms of overdose. For example, the code You are very sweet - breathe in a special way, read poems, etc., etc.
- Дмитрий В.
- Been thanked: 2 times
on account of the "Sugar is fuel for the brain, but its high consumption have a brain, at least, something much load..."
many people simply have no idea what it means fuel and how much it is necessary!
how to hang in grams!!! I remember is was such )
My opinion, for example, the body should be no more than 110 grams of carbs (pure glucose), if I eat less, I lose weight(eat fat), if it is more fattening. So I am for six months lost 20 kg. (if interested, ask)
Keep in mind that in almost "pure" carbohydrates gets bread, potatoes, pasta, sugar, etc. etc. etc.
Normal diet, clabousser person (according to my surveys of thin people) is 300-400 grams of pure glucose.
What Your body wants sweet - pure nonsense. To ask can the brain, though in such quantities only wrong.
Try it, eat your candy and chocolates to translate into calories, and then try to run on the treadmill. Her computer will show You how much You burn of calories. I think that would burn EVERYTHING, it will be necessary to run an hour 4-5
Actually, the shakes, running from sweet - not good. And mayd-machine, as well as all the other endorphins can be either a match or a developer problem...САМОЛЕТ wrote:awaken wrote(a):
After about a week I wanted to eat the entire tray of pies in the store. The shakes started, get the juices flowing.
Personally, I would in your place (Yes, I was not at your place!) nevertheless I would be tested for sugar = diabetes.
I've tested "all" in the spring of 2008. He just said that cholesterol is slightly above normal.Гость wrote:Actually, the shakes, running from sweet - not good. And mayd-machine, as well as all the other endorphins can be either a match or a developer problem...
Then found the info about what to produce serotonin, a kind of iron uses glucose. Reduced the listening time to 30 minutes. And right now, these brownies do not pay attention.
OK! Then all of the above all - really... um... making a note. Just limit yourself, and most importantly - learn to dismiss "the shakes" (it is, believe me is not very difficult, both).оуаакун wrote:I tested "all" in the spring of 2008. He just said that cholesterol is slightly above normal.
Great!оуаакун wrote:And right now these brownies do not pay attention.
Идущая вперед
- Been thanked: 6 times
my identity is the body requires a sweet now... at work all moaning... soon be spring... the sun... the leaves green (grippp wait mows people specifically)....
replaced all sweet (which is heavy in carbohydrates - potatoes, bread, pasta, sugar) in dried apricots raisins apples tomatoes and cucumbers...
organisms wait the lack of sun and even fluorescent lights... the students FINALLY the MOST difficult MONTH of the YEAR IS FEBRUARY... the biggest stress and health and learning....
and started taking the course, the mummy (all fed bee pollen and honey in the family... all salads are prepared with garlic onions and blue night)
bees collect pollen from flowers (a full set of vitamins and minerals is a very useful thing, one teaspoon in the morning - useful only sometimes delicious, mostly it is not the sweets) sold at a 100-200 gram price of 100 rubles for a bag of 150 grams...
now 17 February in Moscow at the Manege will be the next honey fair (there will be heaps) and other bee products (pollen... propolis ...honey comb.... Mead is all useful and necessary for our body pieces (especially in early spring when the body lacks vitamins and minerals and there is some sort of fatigue depressed and other nasty things)...
the yogis say (in several yogic treatises read) that soul is primary and body is secondary but the conditions in which you keep your body depends on the purity of your soul and for the body to do all that it was great - the approximate meaning of ramacharaka...
Going forward
Going forward
But one lady at the fair, asked, like why you need the pollen. I kind of say -- to eat. And she says that pollen has contraindications. Type causes the growth of cancer cells.
In the fall and was advised to buy ambrosia, because in the spring it loses its beneficial properties.
I thought: this is where enlightened people hang out, and type the meaning of ramacharaka understand on an intuitive level.
Идущая вперед
yeah... if any fools to listen to at the fair... maybe she is crazy???
my family life consumes bee products... no one died (surpassed) I don't believe the lady... full of crap...
bees work all summer .... collect this pollen from the flowers and the way they eat it themselves... it is their food... and the bee is not stupid she got there will not be... as well as a cat.... which do not eat sausage of toilet paper... my cat loves bananas for example...
if bees do not develop cancer from the pollen - and then we nicho is not threatened.... and this is just fiction silly aunties.... (wait a lot of people gathered on the streets and in transport)
Well, the cat will not be the same pollen is, and she knows a lot about bee products!
Not like she was crazy. She has her own bee farm... She sells... the Type says if you after illness to regain your strength - you can... and then, half a teaspoon. And just like that, especially people prone to ozirenie, with cancer and diabetes. And the ambrosia, says contraindications none.
The type of pieces of bee-bread should be whole, without waste. If the bread crumbles, then it was not stored correctly and lost its useful properties.
By the way of the ambrosia she had -- all sold. And pollen a few bottles stood.
