Difficulties in the use of audio-visual stimulation.
Влад Н.
Post by Влад Н. » Sun Feb 01, 2009 13:46
Good afternoon everyone!!!
I want to share my trudnostyami associated with AVS.
Do with mind-machines I have more than 2 years.
When I turned on machine first time then first or what not feel 2 times to start rocking, 3-5 times sausage at all (can change the length, shape, geometry of the body, felt its outer shell, flew with great speed through the tunnel because and so.) After that day, felt an emotional lift, but on the 8th day, all those feelings started to fade and at the same time appeared Caqueta negative feeling in the body razdrozhenie,and after the AVS began to appear negative feelings in the body. After some time I reduced the intensity of the sound and illumination to a comfortable level, but the negative feeling still remained after AVS. Then I changed the pose for AVS (sidyachey replaced by legacey), interestingly, a negative feeling after ABC left, but had difficulties with the heart rate, the feeling that heart to fly in kakoki moment, fell for the first time in a deep trance, but for a short time.
Vobscheem delee I started to experiment with colors ABC used different LEDs, stopped at the green color.
After some time, 1 year, and finally found the optimal modes for ABC.
But still internally I feel not happy, when the film tension within the body, which is somewhere stuck and won't come out (generally not very pleasant).On 2 year classes of AVS has established a pattern that when more than 3 days using the same program (I used different alpha sesii, conditioner and other alpha programs on various mind-machines), except nebolshogo discomfort or what not feel.
Kakoeto voltage when mahaut LEDs and sort of feel the sound pressure from the sound. Then I gave up.
After 4 months, put the Explorer, the first 3-4 days immersed in a trance, then that is the sound I started to feel uncomfortable.
Then removed the glasses and began to listen to only one sound, but irritation from the conductor already in the 30th minute, was that me just twisted.
Interestingly when I listened to the Explorer for the first time (15 days) and then after 6 months 2 times, that feeling arose.
In General, here such problem:
When you start to listen to any alpha sesiu and not only the alpha, originally a kind of comfort and relaxation, then a feeling of discomfort or razocharovannogo, then have to change again SEIU or program.
Can't relaxes the body, what interferes, what is annoying and not what equipment (I tried many) did not helps you relax, as for example it is possible to do when you get out of hot baths and about diving in the cool water :)
I have the feeling that my body is so sensitive to sound and flicker of light that he perceives as razdrozhenie.
Some times listening to the disc Endorphins - 15 minutes so I was mahlabatini that I thought I was torn from muscle and brain activity.
I want to cultivate with meditation practices, because I know that this is the right way to use all his vnutrenniy potential, but then I love it that I do not know.
How to find a balance?
If anyone was videoseven my experience and knows how to find a way out of this situation, please help me in this.
I would be very grateful.<
Post by Андрей Патрушев » Sun Feb 01, 2009 14:03
Most likely, for some reason, You are very easy to adapt to the rhythms of light and sound, but just as quickly the brain gets tired of it. A person usually starts to "enter" only at the 5th minute and tired at the 45th.
Output I see one - to minimize the impact to a comfortable level, and then immediately go to the meditation without any devices.
Влад Н.
Post by Влад Н. » Wed Apr 22, 2009 13:59
Hi Andrew!!
Thank you for your help...
The thing is, I noticed the effect it like 2 years ago from mind-machines and audio-visual meditation I have never experienced.
If I've been at it rasslabitsya, I kind of felt like in my head that something is happening and tracked changes in my condition.
But for now just lie and neither a positive effect for me..
Feel only a slight tension in the head and somewhere in the inside of the body.
I just realized that problem is concentration...!!!!!!
Letting it passive or active (work with the breath, visualisatie, even or ochem thinking leads to tension).
Became kakoeto irritating sound, even at minimum volume, light effects, even speech can not go!!
Tried to make a break for 2 months or more, unfortunately also the effect..
Noticed that when I meditate sitting in a chair,the first time after mestnogo rest, it turns out quite interesting things in the process of meditation (elongation of the body, the feeling that with great speed flying through the tunnel). But then the following 2 and 3 day during meditation I feel negative feelings in the body (the feeling that all the negativity accumulated in the muscles) and then go around all day razrushennyi, what with continued meditation in a sitting position have more negative emotions. At this point I made the conclusion that medeival sitting my body can not!!
Please help me to understand my difficulties in the development of meditative practices. Give some sort of advice in developing the skill of meditation, given the fact that I described above..
Thanks in advance for your help!!
Идущая вперед
Post by Идущая вперед » Wed Apr 22, 2009 15:23
Влад Н. wrote:Feel only a slight tension in the head and somewhere in the inside of the body.
there are blocks.... they should be clean.... can try using a rainbow arc first? occasionally there is the affirmation of the type
MY BODY RELAXES EASILY
I'M TOTALLY RELAXED
I'M PERFECTLY HEALTHY. well escho Cho thread in the same spirit...
you concentrate on the stress and need for relaxation..
have you tried to meditate on emptiness.... no need to fly anywhere to do anything just lie there with your eyes closed and nothing there is only the infinity of inner space and emptiness... and full... a total mind....
