Tonsils
Technique treatment congestive colds any degree.
1. On the index finger (of the gland) to put a thin layer of cotton wool, rewind just below the nail with a thread that wool does not fly.
2. Dip the cotton wool in Lugol, it should all soak up.
3. Take up flashlight keychain, with a sticky a button – so convenient. Shine in your mouth, aim and wipe the entire gland in a circular motion to do that efficiently you need straight to “climb” for the gland, under it and over it.
4. Further, without swallowing the saliva and mouth, in the mouth recruit heavily salted water and rinse-vypilivaem a couple of times.
5. Check the cotton wool on the presence of her tubes, if they are, change the cotton wool.
6. Repeat the procedure (agenda items 1-5) with one gland while not visually be seen not a single tube. For the control to view the throat by the light of a flashlight suchecki while moving with the tongue and the glottis. Rinse.
7. Repeat the same for the second lap. Paragraphs 1-6.
8. Brushing the tonsils, clean language. Can teaspoon, he cleaned the spec.scraper Liguasan (there are other analogues). To pink of condition. Rinse-clean-rinse-clean...
9. Pour in the spec.”enema” nose “Dolphin” (Dolphin) about half a teaspoon of Malavit. I insert the neck of the bottle Malavita in the neck of the Dolphin, click on the wall of a Dolphin – and Malavit already inside.
Add the prepared salt water to the top.
10. Rinse the nose. From nostril to nostril. From the other nostril in a nostril. From the nostrils to the throat, plugging the other with your finger. From the other nostril into the throat, plugging the neighboring finger. So repeat until all of the liquid in the Dolphin about once to rinse the throat.
11. Unscrew the spout of a Dolphin, the remaining liquid rinse mouth.
12. The remaining salt solution (without Malavit) plesken alternately in eyes wide open. Wiping the eyelids from the inside with your fingers. The water needs a bit to get into the nose through the tear duct.
13. Bend down, head looking at the floor. Stand up to leakage of the residual liquid from the nose.
14. Do ultrasonic inhalation with an aqueous solution of Malavit. I have an old nebulizer “monsoon-1”, Soviet.
Note:
1. The procedure will be less enjoyable if you get Lugol on the tongue, not the tonsils. Take the direction of movement higher.
2. You will quickly find the optimum thickness of the wool trial, I do so but would not scratch a finger on the throat, the thickness of the layer of cotton wool ~1-2mm.
3. For the entire procedure will take ~0,5-0,7 liters of salt water (prepared before the procedure). Teaspoon with a slide of non-iodized salt per 0.5 liters.
4. I used to do nasal lavage from the throat to the nose, but after a while I refused it, probably the infection may be from the throat to the nose. And the smell comes along with some liquid. The classic version of yoga – from one nostril to another, from nostrils to mouth, mouth to nose, from one to the other, from the nostrils to the mouth.
5. After this procedure, you can't go out in the cold for about an hour.
6. After the procedure is to perform breathing exercises (to exclude or to put at the end of breathing exercises, paragraph 14).
My tonsils were such that almost blocked the throat was bright red, they could see the blood vessels, there was no place living from purulent plugs, I barely talked. The aggravation has passed two months after the start of execution. But I didn't use Malavit. Finished off the remaining parasites adding to their diet a little Malavit.
I have not seen such little snow Bunny and gland in your whole life!
Good luck!<
Note:
Good luck!<
Addition:
1. In maintenance mode the tonsils Lugol not "picking". Waiting for the first signs of a cold. Slightest. Study tonsils with a flashlight and the situation perform the procedure.
Gradually local immunity (with your help) will kill all of the remaining "tit".
2. Do not press on the nasal septum while using Dolphin. Hrase somewhere near
Идущая вперед
- Been thanked: 6 times
and I use the simulator Frolov... he's in the pharmacy is 500 rubles....
add butter 100% natural mostly juniper pine spruce cypress.... very good for clearing all the breath... PEOPLE IN the MOUNTAINS LIVE a LONG time... it is recognized by all.... because the breath is slow and the lack of oxygen... as well as turtles live for 300 years because the breath is slow... and the rabbits breathe quickly - so they have a short life SUVs
Идущая вперед
Malvina
my life is very stressful and I smoke a lot... so I use the simulator for clean lungs and for removing any rubbish from the respiratory system...
my neighbor for her asthma - she uses it as a tool....
I have dry skin - when I breathe orange or lemon - through the pores of the skin it moistened....
гость
гость wrote:posted: Wed Dec 17, 2008 3:13 am all the illness from parasites and it is scientifically proven
lavka.kiev.ua/litradoni2.shtml
Totally agree MM and no equipment, no exercise equipment will not help You until you do your health seriously
Timely diagnosis of the body, proper nutrition is the key to health.
Below is a TEST to identify the problems of Your health - complete and send in the mail, after analyzing we will give You recommendations.
Make at least a small step toward yourself, respect yourself, be healthy.
Victor
fdens@mail.ru
Analytical test
developed by doctors-nutritionists
"Center of rational nutrition"
If You have recognized at least some of the following condition (feeling) -
check them.
Lack of energy, lack of energy
Frequent illness
Body odour and/or mouth
Difficulties in digestion
Frequent consumption of meat with blood
Painful, irregular menstruation
The frequent use of antibiotics
Alcohol abuse
Frequent mood swings
Food allergies
Puffiness under the eyes
Smoking
Confusion, poor memory
Reduced immunity
Heartburn and flatulence after eating
Frequent stress
Skin imperfections or poor complexion
Excessive consumption of carbs, craving sweets
Excessive consumption of dairy products
Depression, apathy, and depression
Insomnia or restless sleep
Problems menopause
Frequent urination
Hair loss
Swelling, pain in the joints
The difficulties of maintaining a normal weight
Fatigue
Failure to comply with the diet
Slow recovery
Irregular bowel
Lack of appetite
Low sexual activity
Thinning and brittle nails
Dry, dull, damaged hair
Eating fatty foods
The feeling of fear, anxiety
The lack of fiber in the diet
Muscle cramps
Unfavorable environment
Frequent consumption of tea, coffee
Irritability, loss of self-control
Hypersensitivity to chemicals, foods
Fungal
Muscle weakness, bone fragility
Constant anxiety
Irritability, over-excitability
A sedentary lifestyle
Increased sputum
Send a test E-mail fdens@mail.ru<
Идущая вперед
the theme of the parasites discussed here many times...
if the parasites have 90% of the population and this topic is being discussed by medical institutions (they just make a lot of money
cut here 5 weeks triad Evalar - nichrome I have parasites... illusion... wait all and Sundry intimidate parasites...
yeah... the results of "special"-poll will be issued a "miracle"drug.
to drink it had buckets, high prices...
given that the questions in the "special"survey designed to cover all possible variety of ailments, diseases, habits... you can safely enter into another network company... to buy bottles, sell bottles.
vparivayut all in a row, fools vparivaetsya.
and the signature you have experienced holder of the regional representative offices of the company Oriflame
how is the campaign money towards?
by doctors-nutritionists - campaign conventional nutritionists, pediatric
the word food is used you quite often - do you sell mega-protein from the aging-weight loss-obesity and objectone (sorry could not resist)
+1, analogichno. as is too often the case - money for a wind.Идущая вперед wrote:the theme of the parasites discussed here many times...
Amazing...
When I was very young, and a bit later - not exactly small (5-10-12 years) with me with great care had done all of the above procedures. About once a month.
And then - everything is new.
In short, the staff ENT doctor got the parents - to cut a Fig (appealed to many, about half argued that cut is not necessary) - in General, got the doctor, cut (13 years old).
Right now I have a lot, but since I'm just a sick throat colds (and, most likely, not much cold was, how the flu and its complications; all light).
For what has bought, for and sell. In adult age do not respond. For children before to tear, consult your doctor, who you used to be able to trust.
And anyway, where are the glands?
ZOMBIES, better be in detail told how local technologies can help you iron pull, huh?
tonsils despite the fact that every second person asks how to cure the common cold (with or without MM)... may be I have via PM asked... so I'm a greedy man, nothing will neskazhu.
the iron is that it is not to compete... and compete never will be... new will
not in the near future.
So I say that once a month to do the same as to bathe once a year, to complain about lice and to remove all voloshinoi cover on the body
not the type of help your bath...
well, of course... because the load was distributed where it was... heart, kidneys... healthy glands this is the real thing.Гость wrote:right now I have a lot, but since I'm just a sick throat colds (and, most likely, not much cold was, how the flu and its complications; all light).
Sorry, I too plan a "new way", I wonder.ЗОМБИ wrote:the iron is that it is not to compete... and compete never will -- according to the new will not in the near future.
Possible. But it's not showing yet. Generally, of course, I got excited, "advertising" the tonsillectomy. This is an extreme case.ЗОМБИ wrote:well, of course... because the load was distributed where it was... heart, kidneys... healthy glands this is the real thing.
When the temperature 37,5-37,7 permanent, and 38+ very often, and most importantly - really helps nothing.
And I don't even remember what is Lugol - I think it's a "soft antiseptic", but not sure. In General, I don't think mashing the tonsils with their fingers with Lugol and ultrasound every day is a good decision. Again - this is not always possible.ЗОМБИ wrote:so I say that once a month to do the same as to bathe once a year, to complain about lice and to remove all voloshinoi cover on the body type does not help your site.
By the way, it is believed that a good doctor can determine whether you can tear a no-no. The question, of course - where the doctor says that he's a good...
here of fine Chinese grandfather with a beard and a cane I would have believed... and so... on the fence over there is also something written. I'm way to snatch sent a LOR, a good friend of the father... it is the type of vacation left and she was too lazy to fuss... blah.
you mean those bodies who walk through the clinic in white coats? it's not the doctors... it's the mutants, they are all without exception overfed and on his nose, can not see anything...Гость wrote:to where the doctor says that he is good
