Homemade session
Installation and discussion
Путешественник
Homemade session
Post by Путешественник » Wed Dec 03, 2008 23:53
Post the library sessions helps in mastering the art of dreaming and astral projection. In this library you will find 3 different tools:
1)LucidDream - the first level of development. At this level you will learn easily enough to reach the Theta state from the normal state of wakefulness. When listening to this session it is important to keep the mind in a relaxed state throughout its duration. Signs of development at this level is the intensification of dreams and the emergence of a certain number Osov.
2) 4HzStimulation - will allow you to learn how long to keep the Theta state without loss of consciousness. It is assumed that in order to use this session you should already be pretty easy to know how to log in alpha condition without the help of the device. A sign of good development is even more powerful intensification of dreams and uvelichenie number Osov. It is also possible to first exit ostalnogo body.
3) OtherWorld - the final stage of training. If you possess a controlled entrance to the Theta the condition and can remain in it for quite a long time without losing consciousness, you start to use it. With proper motivation, you will succeed and learn to control your dreams, and deliberately projected outside the physical body.
All sessions I recommend to listen to just before sleep at a comfortable level of sound and light. Let your body relax while listening. Should not be while listening to think about something specific, let flow freely your thoughts. You should also not resist the action of the sessions in order to keep the mind, you will achieve this automatically.
Comments and suggestions are welcome.
Good luck to all looking for!<
Соловей
Post by Соловей » Thu Dec 04, 2008 0:38
Sounds good. Thank you!
Пардон
Post by Пардон » Thu Dec 04, 2008 1:45
The library is, atlichna! And where do the session?
or even I do not dagnal?
Путешественник
Post by Путешественник » Thu Dec 04, 2008 2:06
Session in the library. To download you need a program lslib.
Пардон
Post by Пардон » Thu Dec 04, 2008 2:13
In the library file AstralProjection.LSL has only this text:
#N:AstralProjection
#C:04.12.2008
#M:04.12.2008
#D:
#T:none
D:\MindMachine\Session\ВТО\4.12.08\Session\LucidDream.LSS
D:\MindMachine\Session\ВТО\4.12.08\Session\4HzStimulation.LSS
D:\MindMachine\Session\ВТО\4.12.08\Session\OtherWorld.LSS
and pahodu LSS file you have on disk
Путешественник
Post by Путешественник » Thu Dec 04, 2008 2:43
Yes indeed. She thought of the archive packages:oops:. All corrected, it is possible to download :).
Пардон
Post by Пардон » Thu Dec 04, 2008 13:24
Thank you. Try
Post by Guest » Fri Dec 05, 2008 17:57
Not swinging with the Rapida
:cry:
Путешественник
Post by Путешественник » Fri Dec 05, 2008 19:00
Posted this on another file sharing.
Стас24
Post by Стас24 » Sat Dec 06, 2008 22:15
All great, but I would like plus recommendations.
Such as, how much time to do, how often, how many go to the second session and the third?
damn, I want to realize a dream and to go wherever I want to become air, wind, and not know any shackles.
:D
Путешественник
Post by Путешественник » Mon Dec 08, 2008 3:39
It's simple. To listen need a full length session before bedtime. Before listening, you should not listen to anything else vozdeistvuya on consciousness. To not listen more than 2 times a day. To move from one session to another should be as you progress.
Good luck!
Been thanked: 2 times
Post by ЗОМБИ » Mon Dec 08, 2008 10:58
the Traveler
Thank you bi bi bi
But I'm still repressing the exits. Scary, unknown... Blah, and pretty easily :cry:
Sho to do something first? Me all the time for generation of horror pulls out of this and stop...
Master, help :roll: 8)
Идущая вперед
Post by Идущая вперед » Mon Dec 08, 2008 16:30
I identity all the time inhibit the outputs.... I believe that the time has not yet come before another ( trips to the astral eat kolosalnoe amount of energy) are going to go back to school to Michael Raduga... I have enough and HAVO a regular basis... often enough and very bright...
escho I really don't like predmostnaya.... when the heart begins to pound and the shaker...
Post by ЗОМБИ » Mon Dec 08, 2008 21:18
Going forward
I to M. the Rainbow has already moved. After his seminar in General pipets. But when you have to go to the seminar feeling uverenna, there will be a debriefing, support.
Alone, scared... damn...
I predmostnaya not too much. But the more DM I "to write" when in the light phase and of the type necessary to delve... such a wild raging force attacks and begin to Wake up. I am inclined to direct outputs :) In childhood very long time were written by Freddy Krueger. That's it, Gee. :evil:
There are times when I could not sleep nights, and makes everyone here, and also want to sleep...
By the way, this fear is likely to speak about attachment to the physical body(for Eugene Mow) and not wanting to let go of some problems(I even know what)...
Post by ЗОМБИ » Mon Dec 08, 2008 21:20
Идущая вперед wrote:I identity all the time inhibit the outputs
let's be friends, let's crush together, haha :cry:
Стас24
Post by Стас24 » Mon Dec 08, 2008 21:24
Today was 31 minutes of the first level.
First impression... very very strange.
Going forward wrote here that starts the heart pounding and pounding!
I thought only I have this. After the session, heart oddly thumping about 45 minutes or about an hour. Bud, I was waiting for something, scolded me, or do I have a fight with someone close to you. I measured blood pressure and pulse (and pulse 116/59 69). This is the only unpleasant feeling which prevents in General to achieve something, type exit to other dimensions :?
I am familiar with such sensations, as saws of different fat burners during sport (caffeine aspirin and ephedrine) To 3 o'clock in the morning, you can awake, heart like crazy will knock. And more not like myself heartbeat. When it becomes very outlives, as if his whole body strengthens unpleasant.
I for all time was relaxed. Kept repeating to myself the wording soothe the body. But the heart of dick uspokoili and otvlekaet great.
This session is very different from the usual i01 Improv
By the way, at the expense of the session before sleeping! Don't know whether it is possible after these responses of the heart to listen before sleep, and if you increase the duration of do not want.
I asked for more information about the sessions and reactions.
To keep the mind relaxed and body just to think about anything I seriously had to use auditory training.
Although 3-5 fleeting images I saw. Saw movies. As soon as tried to touch his mind to the images once they shazali. I tried to come up with images that did not help. I realized I didn't need to try to invent and get into the images in these films, but only to be their audience.
I don't want any outputs from the body (astral outputs).Don't believe it. It's more like esoterica. By the way fears are well founded. I read that during such eksperimentov consciousness is very open to... strange things and phenomena (for supernatural phenomena) As you know, the souls of the dead often come in dreams, we are open to them, open our minds and subconscious. Open and unprotected. Shamans also leaving the body gain knowledge or spirits inhabit in them during their astrologo out-of-body.
I think the psychology of psicologia, esoterica let it be separate. The fact that in another state you can see yourself lying it's just shaped memory and visualization.
I don't want to meet another me or another consciousness during class with MM. I have already met with the other, not anymore.
Seriously, I think before these outputs do not put tasks in search of some creatures and consciousnesses, inadvertently to meet them and then home to poltergeist, I think it is necessary before occupations safe to cross and to pray. In fact, I do this in order to better be able to upravljati sostoya of consciousness (to be able to quickly relax and see the bright dreams, the OS, to be able to reprogram myself to program on something good, to be able to quickly get rid of any problems such as pain or itching or heat in the body or depression).<
Post by ЗОМБИ » Mon Dec 08, 2008 22:41
Стас24
uh... the souls of the dead, the souls of the deceased, share a room, check...
I wonder how do you separate psychology and spirituality? :shock:
on what parameter?
if you want (intend) to pump - will have to go through a lot... and don't want of course begins to suck.
where to get personal nagual, Schaub is my mortal energotel guarded until I get feathers in a proud, blah, the bird? :aa :wiz :evil:
Стас24
Post by Стас24 » Tue Dec 09, 2008 2:09
Just.
Who says hypnosis is evil, who says pure psychology. I am from books on the psychology part is not perceived. For example, mental hypnosis... it's esoteric. Believing in what is possible at a distance to influence someone for almost unprovable. Not twice to repeat the experience and get the same result. Can you explain the result of the fact that in the distance someone helps you, not you doing it. Shamans, for example, speak directly to them helps the spirits! People are proud, ascribe it all to yourself. I know one thing that many shamans, psychics, witches, etc. themselves say that they help, but who does it think you know. So here it is the dividing line of psychology and obscurantism. All that on a physical level, does not go beyond the psychology and physiology, and what is transcendent and beyond them is not ours, but someone else's.
So the astral... a matter of choice! I do not put the goal Out. And then will come and will not come or much better will roll Neruda or will meet someone better not to meet.
Actually I want to learn through heartbeats. It's supposed to be or it will pass in a few days, and that will then actually exit? Why wait? Not to be dumbfounded by.
Post by Guest » Tue Dec 09, 2008 5:32
ЗОМБИ wrote:where to take personal nagual, Schaub is my mortal energotel guarded until I get feathers in a proud, blah, the bird? :aa :wiz :evil:
Later, friend, you are the proud bird, singing quietly! That company does not suffer... I still Stratou...
Соловей
Post by Соловей » Tue Dec 09, 2008 5:43
Стас24 wrote: Actually I want to learn through heartbeats. It's supposed to be or it will pass in a few days, and that will then actually exit? Why wait? Not to be dumbfounded by.
Like it should be. I'm so in some cesiah clear dreams faced. That much as not to suffer, I listened to seciu morning - woke up, had lunch, read and then with headphones dreaming. Around 9-10 o'clock in the morning poluchaetsya. And the dreams in this case richer - that I came across it, and then found by someone such recommendations(this on the morning of dreaming, and not about the session).
Post by ЗОМБИ » Tue Dec 09, 2008 10:05
Соловей wrote:Where 9-10 a.m. poluchaetsya. And the dreams in this case richer - that I came across it
I am also after a meal, when waiting for transport to work, was buried in a pillow, but sleep, in order to jump on the phone earlier.
Dream very high quality, however with a deviation in the well-known erotic side... such :evil:
Probably because I'm on my stomach practiced :lol: :lol: :lol:
Путешественник
Post by Путешественник » Tue Dec 09, 2008 14:39
Стас24not twist the self. Outputs to the astral plane is always associated with uncomfortable sensations, often unbearable :) The inexperienced often feel a strong threat to his life, panic attacks. For this reason, a Fig drop the case. And usually the problem just the palpitations and heaviness in chest, hard to breathe well, sleep paralysis of course. Nightmares also likely will have to go. Later, when people get comfortable, he is able to pass this barrier and to control the frequency and intensity of vibrations. Then the "crackdown" takes place almost instantly, and all these symptoms disappear almost completely... But there are other signs sometimes not the most pleasant. But fears for the lives they did not cause :)
PS: afraid of wolves - in the woods not to go.
Стас24
Post by Стас24 » Tue Dec 09, 2008 15:54
Путешественник wrote: However there are other signs sometimes not the most pleasant. But fears for the lives they did not cause :)
What priznaki not the most pleasant, explain?
By the way on account of nightmares, I wrote in the topic about Theta sessions, that on the contrary I do not have nightmares. The dreams became brighter and somehow more realistic!
I don't want to drop the class, but I want to know what stage will be held before a beginner will reach that which you mean.
Please describe in order what States can occur at the beginning (which States you have passed before reaching the end).
Explain on account of the phrase is to control the frequency and intensity of vibrations. What is this vibration? The type of ticks in the feet and hands, or epilepsy, what I don't understand.
(Remember how I wanted to see the beginning of a dream, to see hard. But now I know what it is. Dark wall, which quickly kills all, all your images, Bud lights, wall quickly moves at you, can be a little backwards, I think I had to go, but everything happened so fast. She was caught, a dark mist enveloped me and I blacked out into sleep.)
Идущая вперед
Post by Идущая вперед » Tue Dec 09, 2008 17:09
I also didn't understand at first what was happening to me.... no reason not to like this Wake up in the morning starts wildly pounding heart and the body begins to vibrate i.e. elementary to shake... all break into a cold sweat and covered wild fear and constant presence of something unknown (possibly cheat myself) several times the corner of my eye caught some strange movement something unknown... psyche was red-hot to the limit... the phantom was separated almost completely except for the head (head[SPAM] doesn't want to move in the direction of the astral) but I see WASPS all the time.... and work with it for your yoga is called astral projection... with the purchase of MM astral moved 2 plan and how it is not much but now I take courses of Michael Rainbow, I will still go... he's on this topic there is an excellent forum ING
Путешественник
Post by Путешественник » Tue Dec 09, 2008 20:08
Numbness, tingling in the body, like pins and needles. Very strong, so much so that it becomes impossible to tolerate. Well, that for me, in turn, means that it's time to get up and me waiting for a little walk :) The main thing is away from the body to retreat, otherwise will not go far :) But I later came first... and Yes: odsee, sleep paralysis, abnormal heart rhythm, a rough vibration.
Yes, there are some stages may be :)
I do through hard depressnyake was... very hard. Here I have the whole set were: felt concern for life, for sanity, horror and euphoria, nightmares and dreams are very realistic. Osov was so much that false memories are often, the benefit do not mix with daily. The dream and reality now recall equally vividly. Dreams I am quite learned to control, by the way, even a couple of different things to do can. Practice long...
Vibration is like a current passing through right through you. And feelings that lie on the transformer. :) But the vibrations are localized outside the physical body. Their frequency and amplitude can be sufficiently controlled. But it's all words... you have to feel to understand. Over time, they change a lot.
In General, if there is any doubt - do not do it. Those worlds hardly more friendly toward us than this. And do not test about it any illusions.
