Anyone can specifically answer, if you want to create MM, want to go astral projection?
Thank you!
Competent question!
Re: Competent question!
Existing MM have all the necessary in terms of iron. It is necessary to write the special session. Somewhere on the forum in the relevant subject I have given a structure of such sessions.АстралМэн wrote:Anyone can specifically answer, if you want to create MM, want to go astral projection?
Thank you!
Good luck!
