It was the topic of holotropic breathing
Drain off all negative, but with the hope that something good will sprout...
Been thanked: 2 times
Post by ЗОМБИ » Fri Nov 07, 2008 22:37
Vladimir Nikonov
Topic "Holotropic breathing method Siberian shamans" slashed?
Return subject :cry:
Remove the not acceptable message. The theme is not too shabby.
Not my fault - he came az
More seriously I will not discuss not discussing it.
ЖСЛ
Post by ЖСЛ » Sat Nov 08, 2008 0:18
ЗОМБИ wrote:Vladimir Nikonov
Yes, let them cut what they want. Absolutely not think.
Post by ЗОМБИ » Sat Nov 08, 2008 11:20
Vladimir Nikonov
About people think. The topic has links to the breathing technique, not a standard harp.
Not the same one MM brain buzz itself.
To me personally she even bothered. No diversity. And headphones with glasses as a foreign body on the head hang.
Because I felt that many things on it will not pump. Need externally oriented and intention. AND THAT'S ALL.
(says Eugene Kosh - my here and now). az
From the long sessions in General sucks, it's easier after asanas patetica not to pass out completely, and something to do in your head, if you really want.
Post by ЗОМБИ » Sat Nov 08, 2008 18:20
No, no way.
At least the links from old threads here place. On breathing technique. A harp mind-blowing.
If I'm not here to provoke - I'm white and fluffy. Sometimes I wonder, theoretically, something to discuss :?
Post by ЗОМБИ » Sat Nov 08, 2008 23:53
Post by Андрей Патрушев » Sun Nov 09, 2008 14:08
Anonymous wrote:
Андрей Патрушев wrote: Yes, You gesami Islam with her and messed. How much can be prevented already?
And where does the rest of the theme and the rest of the people?
I do not understand - you will dig it when the thread in an elementary thing - surfactants discuss any esoteric forum as they are an integral part of personal and spiritual growth. We discussed the lawful surfactants.
Well - once again...
Here is not an esoteric forum. I warned that ALL discussion on chemistry will be removed. And I will continue to do the same.
ЖСЛ
Post by ЖСЛ » Sun Nov 09, 2008 17:06
And what? What is MM?
Андрей Патрушев wrote:I warned that ALL discussion on chemistry will be removed. And I will continue to do the same.
Actually discussed things of plant origin only...
Камуи
Post by Камуи » Fri Nov 28, 2008 17:47
Buenos Dias.
Gentlemen, the owners of the forum, humbly asking... :)
And you can return to the topic cut it on my last post. And zapreev adding new messages to it?
The topic is really interesting...
Камуи
Post by Камуи » Sat Nov 29, 2008 3:50
Damn. I wanted to share "holotropnoe to darmowych", what would the hospital not to wander... the Complaint was "expensive", "no go" And everything turned out as always...
No sooner had the corpse of Gautama Sakyamuni to burn on the fire as there were 32 schools of Buddhism. (C) Osho
this is to ensure that followers are evil...
Return at least the first few posts of the topic...
ЖСЛ
Post by ЖСЛ » Sat Nov 29, 2008 11:17
Kamui - ask via PM of Mr. Nikonov. If the current subject it is from the base vykovyrit :(
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Sat Nov 29, 2008 13:55
Kamui, the first message remains in the source topic http://www.mindmachine.ru/viewtopic.php?t=1289
Камуи
Post by Камуи » Sat Nov 29, 2008 20:28
Oops. Looks vaguely put... I meant the first message of the topic "Holotropic breathing method Siberian shamans".
I am against "chemistry", etc., and in General, the criminal code honored and respected. Two months was not on the website, decided to see how the theme of what lives. And it is already there :(
Abidna became...
