Binaural beats
Андрюша
Binaural beats
Post by Андрюша » Fri Nov 21, 2008 9:06
Found in the Internet program in which the music, you can add binaural beats with the installation of any wave,i.e., Hz. Question to Andrey Patrushev. Tell me, is there any sense from this program and can it be used at all?
Идущая вперед
Post by Идущая вперед » Fri Nov 21, 2008 11:25
such a progressive lot... for example the app is called Altered States of consciousness... but in comparison with the MM and drives these programs rest... I long ago deleted from the computer .... still a good prog AURA of the FOREST.... really relaxes the sounds of the forest as a bear's roar and wolf howl :D :D :D ... and NATURE...
Compared to MM all of these things sophomoric...
Андрюша
Post by Андрюша » Fri Nov 21, 2008 12:14
I want to buy fast MM! While at this time there is no money to buy. And I 6100 including delivery . My wife has some kind of fatigue syndrome. Can not rest,to sleep,the child is also very exhausting,nervous often. I think MM might be great for her! What do you think?
Post by Андрей Патрушев » Fri Nov 21, 2008 12:20
Андрюша wrote:I want to buy fast MM! While at this time there is no money to buy. And I 6100 including delivery . My wife has some kind of fatigue syndrome. Can not rest,to sleep,the child is also very exhausting,nervous often. I think MM might be great for her! What do you think?
Yes, I can remember several women have successfully coped with this problem in a similar situation. But You can be a two disk Explorer and Healing (although it is longer:)).
Алексей Кузнецов
Post by Алексей Кузнецов » Wed Feb 11, 2009 1:03
Andrew, I got your CDs , but still have not solved the problem of headphones. Than further delve into this issue, the more I have questions. Olin of the most difficult issues of CL. Where should occur the created sound picture in your head or in space? Does one or another illusion on the effectiveness of treatment.
Post by Dimas » Wed Feb 11, 2009 12:27
Alexey Kuznetsov
It is best to use quality headphones.Sound waves (binaural beats) occur inside the skull.Effectively listening ONLY with headphones!By the way,we have a full line of headphones ultrasone...but with them the perception of programs in General plague,as they say.You can see them in the catalog.
Post by Андрей Патрушев » Wed Feb 11, 2009 12:28
Алексей Кузнецов wrote:Andrew, I got your CDs , but still have not solved the problem of headphones. Than further delve into this issue, the more I have questions. Olin of the most difficult issues of CL. Where should occur the created sound picture in your head or in space? Does one or another illusion on the effectiveness of treatment.
With headphones there may be no problem, because any suitable in the average price diasone with characteristics not worse than 20Hz-20kHz. :)
Audio picture and its localization is a purely personal phenomenon...
Алексей Кузнецов
Post by Алексей Кузнецов » Wed Feb 11, 2009 22:11
Andrew and Dimas, thanks for the advice. Though I have not purchased headphones, but one experiment this past weekend did. Launched disk space wanderer on a conventional portable stereo radio and leaning his forehead to her was to listen. It was in the kitchen, whose Windows overlook the bustling street. Listened standing up. On the 2nd track I already heard the noise of the street. Listened to all the tracks and in a few hours, I noticed that I began to see better. I have a decent (-5,5 diopters) myopia. Got old glasses (-5,25) and now I use them. There was another "moment" is interesting. In recent years, began to notice that the vision in some situations "switch" in one eye, usually the right. Now it is almost gone. Just for a moment this effect appears and immediately disappears. There was still some elusive things like detachment, and even today the idea, not do on my drives just lying in my room? It is very much appeared of nuances, some can not describe. On the headphones I started to read a lot and understand that each person is different, but in General there are some General conditions for the appearance of the impulses from the ear to the brain. My friend reasoned, people are a predator and he needs to clearly define the positioning of the sound source (or sacrifice, or danger) and therefore, probably, the spatial appearance is more suitable to the formation of signals, but on the other hand, it is also possible that a more clear and deliberate signal to certain areas of the brain may be a more appropriate manifestation of sound in the head. As engineer of course, I want to remove the EEG before and after application of disks (any), even without a thorough decryption (was – was), but until finances do not allow these measurements. And the opening picture is still messed up.
As you use the disks I will share. And I'm bragging to the right and left.
Thanks again for the reply.
ММозг
Post by ММозг » Thu May 14, 2009 14:13
I have headphones with a range of 20Hz-10kHz, not 20Hz-20kHz. Are going to listen to?
Post by Андрей Патрушев » Thu May 14, 2009 15:59
And You confuse nothing? :) This range handset...
ММозг
Post by ММозг » Thu May 14, 2009 17:36
ММозг wrote:
Андрей Патрушев wrote: With headphones there may be no problem, because any suitable in the average price diasone with characteristics not worse than 20Hz-20kHz. :)
Oh no! White on grey a frequency band and written 20Hz-10kHz, the impedance is 32 Ohm, sensitivity (1 kHz) 104 dB. The manufacturer of TDK. They are really still with a microphone. What to change headphones?
Post by Guest » Fri May 15, 2009 1:17
ММозг wrote:Oh no! White on grey a frequency band and written 20Hz-10kHz, the impedance is 32 Ohm, sensitivity (1 kHz) 104 dB. The manufacturer of TDK. They are really still with a microphone. What to change headphones?
if INDEED it is written - in the trash. Definitely. Low-end, which however is usually successful - small AKG (K414P or type, i.e. possibly closed - no phase inverter). External sounds jammed bad, but relatively inexpensive, foldable (fold up and fit in a bag from the kit, fit into a pocket) and at the same time sensitive enough to work with any player. OK. 1200 RUB (my copy, now, probably, more expensive). Of the most expensive options - it seems the best.
Павел Чита
Post by Павел Чита » Fri May 15, 2009 12:43
I want to boast my ears hi end/cal
SONY MDR-7509 HD
Category wired
Noise isolation noise-isolating(closed)
The principle of dynamic
Frequency response 5 - 80000 Hz :evil:
The Resistance Is 24 Ohms
Sensitivity 107 dB :evil:
Sound pressure level(SPL) 107 dB :evil:
Headphone weight 300 grams
Color Black
Jack plug 3.5 + 6.3 mm periodic
Cable twisted unilateral 3 m
Fit to ears covering
Folding Yes
Speaker diameter 50 mm :evil:
Detachable power cord no
The SONY MDR-7509 HD / SONY MDR 7509HD
The SOUND is of COURSE MAGNUS/EC OH/LNY super
маста
Post by маста » Wed Jul 01, 2009 3:11
Paul Chita Headphones of the highest!!! Cost about 9 Tr it is worth It!!!
Post by Guest » Sat Aug 29, 2009 0:52
Strangely, the topic of binaural beats and not a single post in the topic.
I have a specific question for Andrew Patrushev about the effectiveness of binaural beats. On "the cube" is a book in your translation called "Rediscovery" or "re-Open the technology of audio-visual stimulation". The author claims (гл9) that binaural beats produce very small potential in the auditory region of the cerebral cortex and are inecient to synchronize brain waves. It is also claimed that binaural beats with alpha frequency produced more alpha waves than listening to the surf. That is, for synchronization of the waves Mohsen no use of them
Nevertheless, you widely used binaural beats and almost every MM under them sharpened. How do you explain this contradiction if they do not work why they push everywhere.It would be interesting to hear your comment. But if the author is not right and there is more recent research demonstrates their effectiveness, that could you a reference to throw.
Post by Андрей Патрушев » Sat Aug 29, 2009 16:57
Anonymous wrote:Weird, the topic of binaural beats and not a single post in the topic.
It's very simple, - the author of the book does its machinko, which main feature are the so-called isochronous pulsation (trivial amplitude modulation)... :?
Post by Гость » Thu Sep 24, 2009 10:58
So there is the effect of the beating or not, has anyone removed the ECG?
Post by Андрей Патрушев » Thu Sep 24, 2009 11:47
Гость wrote:So is the effect of beating or not, has anyone removed the ECG?
Probably You mean EEG? :)
There's a couple articles confirming the effect of BB. One even saw Russian... :?
Post by Гость » Thu Sep 24, 2009 12:21
Probably meant EEG. Thanks for the reply, and then me the owner is also alerted. Listen - like was the effect, not a self-suggestion is...
