Not enough as it is and unclear.
Or to put the problem as something else ? And how does the disk do ?
https://mindmachine.ru/catalog/shop/teta_meditation/
Disk - only assistant. In order to successfully engage, it is necessary to read the relevant literature.Хочу_remdreamer))) wrote:Description: "Lucid dreams" - you need to listen to before bed with the goal "to realize themselves in dreams".
Not enough as it is and unclear.: How to listen to the statement of the problem to be aware of yourself in the dream ? Chant to yourself "I am aware of in myself in the dream" or "In a dream I look at my hands" and try not to disconnect while playing the disc ? . The first phrase I believe to be subconscious incomprehensible , the second may be clearer, but I nepoymu that in a dream I am, because even in the bright dream I think that it's not a dream but a reality.
+1Андрей Патрушев wrote:Taking this opportunity, I would like to draw the attention of all - language - is real magic.
Robert Bruce advises to put at the bedside Notepad with pen and immediately upon waking write down the key concepts of sleep. And in the evening of the same day by keywords on that page to record the entire contents of the dream. Thus activates the ability to get the dreams from the shadow memory, which they leave in a matter of seconds after waking up.ЛИЛИЯ-Р wrote: Why forget the dreams.
At the beginning, and not something else happen. Clearly set goals.Василий$ wrote:->Andrei Patrushev
Welcome!
Listened to it yesterday night for the first time "Awareness of dreams" experience incomprehensible.... Went to bed and immediately went to images of naturalistic and very bright, opened his eyes from the unexpected sensations. Then vsetaki fell asleep and had a dream very real and detailed which went some pieces. And I realized that I was SLEEPING but waking up couldn't although I wanted(due to the fact that the dream fragments not connected feeling was pleasant, like like a head turning). Then I woke up and "freewheeling" Solnechnyi the wind and then slept fine.
Is this normal??
In the dream, You either did not realize or acknowledge it yourself (generally this is a bad translation from La Berra), even if you dream that You are an elephant.Василий$ wrote:Good day!
Maybe someone from the forum gurus advise what could be wrong.
Try 4-5 times already and silence, download the film dreams faded and weird when I Wake up I don't remember any dreams and somehow empty, for the first time the dream was very strong just horror...
Listening to this disk for about 15-20 minutes before bedtime with the objective to realize a dream and put the(work) task, in which situation want to see and try to find a solution.
Can that not do?
Andrew,so right .." I know what I'm dreaming"???Андрей Патрушев wrote:In the dream, You either did not realize or acknowledge it yourself (generally this is a bad translation from La Berra), even if you dream that You are an elephant.Василий$ wrote:Good day!
Can that not do?
Think about what You want and set a goal right in clear and unambiguous terms.
Yes, but better, IMHO, still "aware".Dimas wrote:Andrew,so right .." I know what I'm dreaming"???Андрей Патрушев wrote:In the dream, You either did not realize or acknowledge it yourself (generally this is a bad translation from La Berra), even if you dream that You are an elephant.Василий$ wrote:Good day!
Can that not do?
