Other programs on the principle of "25 fps"
Евпатий55
The Network found a few other programs running on the basis of the "25 frame":
http://mshapkin.narod.ru/m25k/m25k.html
http://dmitriyo.narod.ru/
ДмитрийО
Идущая вперед
- Been thanked: 6 times
bend for 25 frame
and by the way absolutely free
1. the program is called 25 fps
2.http://youryoga.org/med/sssp_med.htm
3.http://youryoga.org/med/mas.htm
4. rainbow-arch - the most effective program penetration into the subconscious
5. still an amazing setup http://www.mm229.ru/av/dvd2.htm
6.http://youryoga.org/med/podsoznanie.htm
this is the most effective... there are a lot of eco...
it is not obligatory to pay money
Горас
It seems to me that Dmitrii is the author of that "Kodirovanie" sorry, full "bullshit".
Just go to the website of this unique, a bit to read (including the reviews that he writes himself) to be treated with caution to use this program.
As for the programs, working with the subconscious mind of the individual, it is possible to pass on the link http://psyberia.ru/soft/softschool#wheel3 and look at Wheel of Time 2.0 SP1
Someone can and will do. At least the man did with knowledge of the subject, i.e. professionally.
ДмитрийО
Goras
Watched "Wheel of Time" is not impressed by.
My program "Kolerovochny 1.779"
http://www.dmitriyo.ru/
much easier and more productive.
Горас
Dmitrio, not for me to judge the effectiveness of the programme. Convenience - the property is subjective.
Wheel of Time 2.0 SP1 specific "stuffing", which, incidentally, is discussed. Author, the psychology of the familiar, not by hearsay.
If to speak about effectiveness, then, usually begin with statistics. Ie all is as it should be, with a serious approach.
The sample should be representative, well, I hope, you know? Otherwise, allegations are unsubstantiated.
The text visible at any frequency. The question is - can you read it or not. In my opinion, after 10Hz any sense in all this (except for the case where you are trying to drive his head one very short sentence). Same with a presentation on the background of other programs.нина123 wrote:You probably misunderstood me.I meant the frequency at which the text is not visible to the eye!At 25 it can be seen...
http://zvukom.com/menu.php?form_id=58
I mean...There the text is not visible at all,on the background of the program to work on the computer.Very convenient.So in the "Rainbow" to do?
ПОЛОТЕНЧИК
Re: Other programs on the principle of "25 fps"
Kolerovochny." Thanks for the program! Thanks to her I quit Smoking and drinking.
I believe the most effective at the moment the program at the suggestion of installations.
Experience smoker for 20 years. Cast immediately, and not easy of course, but I am absolutely sure she couldn't go back to these two poisons and helped this program. Did not look systematically, so the result is received immediately.
don't smoke for three years. 459217919 my Asya, if you have questions.
