The installation and format of the sessions
Installation and discussion
Post by Михаил_ » Sun Nov 12, 2006 20:17
All good day :)
In General, being a proud owner InnerPulse decided to upload it sessions. For two reasons - because if you master the technique, all possible, and in order to load the session Patrushev.
In the end I found the following:
Programme the librarian is generally desirable should be in C:\LS
a session should be taken with rednano site (not this), because otherwise when you try to open the library it will complain that some links are not correct, however when asked to fix will find and fix all the way.
Approximately the same situation with the help file (While the handles do not show where he is, although he probably never needed).
Generally manufacturers normal installer for so many years, do not bother :)
Well, okay...
In General, it's a small problem, pose an Comporta, session load, it worked EXCEPT.
In addition, the file with the sessions of Andrei Patrushev was beaten.
Pumped the archive of the following, unpacked loaded in librarian - he gives eksepsi, appeal at address zero it seems.
Toiled-toiled.... then I realized that the fault is the carriage return. These three sessions saved with "unixovemu" with a carriage return, i.e. in Windows Notepad (in the editing mode, not viewing), the lines coalesce into one.
Replaced (erased spetsificheskii "square"-specconspr and "pasted" lines, enteritis, after the end of each. After that it worked and these three sessions were loaded.
I think the problems are supposed to be like not just me ?
Because the 2004 librarian of the year and probably all one and the same.
Fix archive should...
And archives photosonix sessions, too, where the names of directories are those that are stored in library files (as I wrote above).
Well I guess :) in General, it is slightly beyond the scope of what I have to do just a user of such glands.
Success!
Post by Михаил_ » Sun Nov 12, 2006 20:21
Addition - while the session was in-text links with the recommendation to keep specifying the file type txt, anything is possible and worked, and when they are Packed in the archive - apparently ceased.
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Sun Nov 12, 2006 21:38
shmshm, session will check and if needed fix it.
Post by Андрей Патрушев » Wed Nov 15, 2006 14:16
We had a similar problem with Dima S., when the session is done in the designer for the Nova Pro 100 was trying to stick to Innerpulse, but we just peresechenii in designere for Innerpulse. True session in view of their extremely small size is not archived.
Post by Михаил_ » Thu Nov 16, 2006 2:45
No, I understand that maybe it's a problem of format compatibility, but the librarian that is common to all types of photosonics, and he from the sessions are posted on the website (specifically your three) falls with a fatal error. Session of free photonicsourcing such errors do not cause.
I think this effect not only to me and easy to reproduce. It is strange that only I noticed, or buyers so little.
I have a suspicion that session files can be converted when loading the website in UNIX-style format, and then from Packed.
Since the problem only to not use the carriage return at the end of lines.
But it does not matter :) for myself, I decided the problem, the topic was created in order to help to improve the service.
Post by Андрей Патрушев » Fri Nov 17, 2006 15:27
Can then better the other way around in the weed archive to put them like on the website Photosonics?
Post by Михаил_ » Fri Nov 17, 2006 20:29
so they are now posted in the archive, only it's wrapped broken files, which the librarian does not open.
B&S
Post by B&S » Mon Dec 18, 2006 13:15
session in the archive and not corrected, I just removed the lines with comments.
and then got into the forum and found the topic.
Владимир Никонов 2
Post by Владимир Никонов 2 » Mon Dec 18, 2006 16:30
Photosonix corrected http://www.mindmachine.ru/sessions.htm
Now will make the session of Andrey Patrushev.
Владимир Никонов 2
Post by Владимир Никонов 2 » Tue Dec 19, 2006 21:22
Session of Andrey Patrushev corrected - check, please.
B&S
Post by B&S » Thu Dec 21, 2006 7:48
downloaded, checked, still the same effect, corrected itself. wanted otavite, but the address is not found, kintos in PM, will send.
(rule is simple, open to far, in edit mode, get up to the first character zakomentiroval line is blurring, so that the line jumped to the previous one, press the line, so all strings, then try to load into lslib. zagrujat without errors.)
Владимир Никонов 2
Post by Владимир Никонов 2 » Thu Dec 21, 2006 12:33
downloaded, tested, still the same effect
With all sessions?
Photosonix wait there are links to their website. Andrei Patrushev the originals posted. Weird.
My address is:vlaimir@mail.ru - send - uploaded.
B&S
Post by B&S » Thu Dec 21, 2006 14:08
rocked with the shortcuts above, tried at the sessions of Andrey Patrushev, complains when you try to download session in the program.
Post by Андрей Патрушев » Thu Dec 21, 2006 22:38
Somehow strange it turns out. Previous sessions I downloaded for the job and properly shipped. These also went without problems. Can I have designer library are not compatible. But I loaded everything (including downloaded)... :wink:
B&S
Post by B&S » Fri Dec 22, 2006 7:33
:shock:
well what can I say, we assume that the cases are rare, and are not amenable to study, although the method of solving the problem are known and simple. :)
PS. you can throw a screen :)and then podumaite gotta be kidding me :)
champ0
Post by champ0 » Sat Dec 30, 2006 23:46
B&S wrote::shock:
Please flick the screen and I 3 Petrushevskii session and can't stick in the InnerPulse.
The rest went fine.
In UNIX and in Windows are not particularly strong what to know where there any signs of stopping, and others.
It I really work and do not need.
Or came 3 session by email:champ0@rambler.ru,edik@vesnet.ru,
I would be very grateful.
B&S
Post by B&S » Tue Jan 02, 2007 8:50
Yes, now let down.
About the screenshot meant to show the error, not the method of dealing with it :)
in this case, ispravlyaet error downloading sessions into the program. If there are any others, then we need to understand.
If my will not load, it just can poudalyat the comments (all lines that begin with ";")
Good luck! :)
champ0
Post by champ0 » Wed Jan 03, 2007 1:26
B&S wrote:Yeah, now let down.
Good luck! :)
Thank you these are downloaded no problem.
Now another problem I have them in Ikerre not find OSU I have under the letter u formed sesia and now why would I not loaded like other libraries loaded via CPC,on the Inner lights flash and sesi themselves nowhere.
I guess what I do not do.
Old sesii who were in the Inner work and the new can not find anywhere else.
All with the come New year !
Happiness, love and health.
B&S
Post by B&S » Wed Jan 03, 2007 8:16
Try to add one session using the session Download (clear). Reboot the machine and try to run it, but in General there is very good instruction was, in the relevant forum thread.
Виктор17
Post by Виктор17 » Mon Jan 29, 2007 22:24
Oh, and I also have a problem with these 3 sessions... Not loaded in progrma. downloaded a long time ago. Today peresekaet the same story :!:
B&S
Post by B&S » Tue Jan 30, 2007 7:22
just try to remove the comments.
Виктор17
Post by Виктор17 » Tue Jan 30, 2007 20:30
B&S wrote:how to remove comments.
Removed, but the same story: "Access violation at adress in module 0048D4CB "Lslib.exe". Read of adress 00000000
B&S
Post by B&S » Wed Jan 31, 2007 9:14
well...
let's mail :-)
will throw
Post by Михаил_ » Wed Jan 31, 2007 22:56
Yes no comments need to remove (they do not interfere with) and a newline to put right.
Ie the ends of the symbol rows to delete and re-enter poke. Then save.
It's funny that no one bothered to archive on the website to work to change. How many months the subject :)
Post by Андрей Патрушев » Thu Feb 01, 2007 9:55
Yes, changed, but again for some reason is not posted in the archive, but as it is... :wink:
If rar to put it all together, then generally no problems.
