A couple of questions on mind machines
Пророк
Post by Пророк » Thu Sep 04, 2008 12:45
I read on the inte about the mind machines in this regard, several issues have emerged
1) what is the difference between goggles, Standard, Premium ColorTrack?
2) What is the structure of the visual impact? Is it possible to write to a virtual reality helmet(for the LCD screen on the eyes) to create similar actions?
3)What is the best car InnerPulse, Nova Pro 100, Luma 10?
Post by Dimas » Thu Sep 04, 2008 15:31
the Prophet
1.About it in the FAQ section
2.in this world everything is possible.Try it!
3.Cars different.For private use is more suitable InnerPulse.
Post by Guest » Thu Sep 04, 2008 18:25
3) then why Nova Pro 100 more expensive? By the way is written there is still Avstim MindSpa...
Post by Guest » Sat Sep 06, 2008 0:37
And a few more questions
Can I apply to the session recording of the speech?
If sessions, Nova Pro 100 to InnerPulse, and if appropriate, where to get them separately?
Пророк
Post by Пророк » Mon Sep 08, 2008 15:09
So, is it possible to download the disk image, Nova Pro 100, or buy the disk separately, to listen to InnerPulse session?
Re: Couple of questions on mind machines
Post by Андрей Патрушев » Mon Sep 08, 2008 15:24
Пророк wrote:I Read on the inte about the mind machines in this regard, several issues have emerged
1. In brightness and number of colors.
2. Of course, you can (already written).
3. Luma 10 - nothing more. :)
Post by Андрей Патрушев » Mon Sep 08, 2008 15:26
Anonymous wrote:And a couple of questions
Can any audio recording.
Suitable after simple transformation (to upload into the editor and resave it).
Пророк wrote:So, is it possible to download the disk image, Nova Pro 100, or buy the disk separately, to listen to InnerPulse session?
Can.
Post by Guest » Tue Sep 09, 2008 2:31
of Course you can (already written).
Where to get?
Can.
Similarly :)
ТожеГость
Post by ТожеГость » Tue Sep 09, 2008 10:49
Where to get?
Can.
Similarly :)
1.Search taxis
2.Similarly. :)
Пророк
Post by Пророк » Tue Sep 09, 2008 13:46
I don't think you were looking for? About the helmet BP on this forum nothing.
The drive from the Nova Pro 100 is not in the directory, the image on the forum, too, failed to find.
Post by Андрей Патрушев » Tue Sep 09, 2008 15:32
Пророк wrote:I don't Think you were looking for? About the helmet BP on this forum nothing.
Helmet fit all programs from a network: BWG, Shrink, etc., etc.
The rest is here: http://www.mindmachine.ru/sessions.htm
Пророк
Post by Пророк » Tue Sep 09, 2008 23:14
And about these programs heard, but they are only audio effects, visualnode no.
Thank you for the Sessi :)
Пророк
Post by Пророк » Wed Sep 10, 2008 13:43
I was already tired probably :) a couple of questions:
Is it possible zanimatsja with MM in CCT?
Tell me what articles to read, to understand the terminology, what wave is what, etc., in the future to make their record.
Post by Андрей Патрушев » Wed Sep 10, 2008 16:24
Пророк wrote:And about these programs heard, but they are only audio effects, visualnode no.
You are wrong - all of these programs have a visual impact.:)
Post by Андрей Патрушев » Wed Sep 10, 2008 16:26
Пророк wrote:I was already tired probably :) a couple of questions:
After a traumatic brain injury to engage with mindmachine can be no earlier than 3 months and you should start very carefully - in any case not to put energizing session (alpha only) and not to exceed the duration of the session 15 minutes.
Post by Guest » Wed Sep 10, 2008 20:40
You're wrong - all of these programs have a visual impact.
Really, you are right, there is. Interestingly, there stereovideo supported?
:( Opensource projects, eh. Just today I bought a MM before the head is attached well, the truth about TBI XS. Che will be if you listen?
Post by Андрей Патрушев » Wed Sep 10, 2008 21:10
Stereo is not supported.
There can be significant health problems, especially from the light.
Пророк
Post by Пророк » Wed Sep 10, 2008 23:26
:cry: :cry: :cry:
Well as:
Пророк
Post by Пророк » Thu Sep 11, 2008 0:20
The disks also can not listen?
Нервный
Post by Нервный » Thu Sep 11, 2008 9:21
Hello!
I'm another newbie with his stupid questions portion :)
Rented the Lum for 2 weeks, I use one, the effect is small, in the morning to get up easier, feel more organized, thoughts are not jumping from one to the other, the inner dialog became quiet.
Use only in the evenings, put session section R.
And here's the stupid questions:
1. As I understand, the lume duration of the session can not be adjusted? Although the catalog says that the Lum and innerpulse possible. There is the long session for 33 minutes, it seems - not too long?
2. My childhood was a TBI (brain injury), I have scoliosis - is there any restrictions on the use of MM?
3. The rule of two glasses is only relevant to listening or using MM it also has to be fulfilled?
Post by Андрей Патрушев » Thu Sep 11, 2008 15:10
Нервный wrote:Hello!
1. "Too long" starts after 45 minutes. :)
2. Does not affect value.
3. For mindmachine this rule is desirable but not mandatory.
Post by Андрей Патрушев » Thu Sep 11, 2008 15:21
Пророк wrote::cry: :cry: :cry:
Well as:
The site has a section "Articles". :?
Post by Андрей Патрушев » Thu Sep 11, 2008 15:23
Пророк wrote:Disks also impossible to listen to?
It is not desirable. Listen To Mozart. :ay
Пророк
Post by Пророк » Sat Sep 20, 2008 22:27
Which mode is better to use points, ColorTraсk or colored if colored, what color?
