software NOVA PRO 100
Installation and discussion
Флексей
Post by Флексей » Fri Aug 01, 2008 8:15
GOOD DAY need help!!!!!
I bought the NOVA PRO 100 and a few extra discs if you use the machine everything is fine, but when connecting to my computer ( to load the new sessions) it is not detected, advised me to download app, downloaded, but the result is zero. machine on the computer not defined somewhere in the same program read data of the program under our 95 and Windows 98 and I have XP
What to do?????????????????????????????????????
Post by Андрей Патрушев » Fri Aug 01, 2008 21:33
Under XP everything works fine. Check the operation of the ports, finally read the instructions and try to don't get the session determination procedure... Usually one of these three helps. :)
Уномоменто
Post by Уномоменто » Wed Aug 13, 2008 22:54
I have XP too, everything works fine. Settings the com port settings are important.
Мила
Been thanked: 2 times
Post by Мила » Sat Aug 16, 2008 11:29
As owners of Macs is not "shining" connection? bc
зерва
Re: software NOVA PRO 100
Post by зерва » Sat Nov 17, 2012 23:05
where can I download the rest 100программ dyal "Nova Pro" which Goritsa on the website that they can upload?
what is the frequency range of headphones that reproduce in Nova about?
Post by Андрей Патрушев » Sun Nov 18, 2012 1:37
зерва
Post by зерва » Sun Nov 18, 2012 5:26
thank you),and about the range of headphones in about Nova??
Post by Андрей Патрушев » Sun Nov 18, 2012 10:18
зерва wrote:thank you),and about the range of headphones in about Nova??
20Hz-20kHz
