Who can help with the repair of the NOVA PRO?
Good day! I have a mind machine NOVA PRO 100 (bought in USA), but there is a problem: the machine stopped working. Can someone tell me who to contact to repair? Thank you
- Has thanked: 1 time
- Been thanked: 182 times
Re: Who can help with the repair of the NOVA PRO?
The manufacturer can contactТабби wrote:Good day! I have a mind machine NOVA PRO 100 (bought in USA), but there is a problem: the machine stopped working. Can someone tell me who to contact to repair? Thank you
PHOTOSONIX
2420 Gundry Avenue
Signal Hill, California
90755
Toll Free Number: 1-800-258-2566
International Telephone: 562-981-8800
Fax: 562-981-8810
Email: info@PHOTOSONIX.com
[/quote]Табби wrote:Thank you! And here in Yekaterinburg, someone can help?
And You have determined that it at You broke? There is a possibility that You drained the battery, or did this several times and You have it "died". In this case, the device will not work even from the network (by the way, there should be checked) until you change the battery (or just throw).
PS Batteries are on sale there for Gagarin (near Lenin Ave.)
Торит
And You have determined that it at You broke? There is a possibility that You drained the battery, or did this several times and You have it "died". In this case, the device will not work even from the network (by the way, there should be checked) until you change the battery (or just throw).Андрей Патрушев wrote:Табби wrote:Thank you! And here in Yekaterinburg, someone can help?
PS Batteries are on sale there for Gagarin (near Lenin Ave.) [/quote]
I have a similar problem with the inner pulse: the batteries are dead and also flowed inside the machine. After the replacement, MM is no longer included in any way. It is possible to do anything (warranty repair for example) or what to hope?
Do not insert more batteries and not plugged in. If not a warranty repair, you can try to take to any repair shop for electronics (life technology, honeycomb phones). But the main thing on sharazhki not to run...I Have a similar problem with the inner pulse: the batteries are dead and also flowed inside the machine. After the replacement, MM is no longer included in any way. It is possible to do anything (warranty repair for example) or what to hope?
гость X
Soviet engineering genius.Андрей Патрушев wrote:There is a possibility that You drained the battery, or did this several times and You have it "died". In this case, the device will not work even from the network (by the way, there should be checked) until you change the battery (or just throw).
Current batteries, and dying batteries in devices for poltyschi have.e. just should not exist as a class.
Александр1
гость X
The battery, like any other thing that requires careful and proper treatment. Acid batteries (even cheap, though expensive) really do not like full discharge on a regular basis.гость X wrote:the sherpotreb![]()
It is strange that no one this case is not surprising. All reacted, as if it should be.
What kind of batteries are such that cannot be safely discharged? Nonsense.
No, maybe someone that level of quality usual, do not dare to insist...
For example, in my machine the same exact battery worked for 10(!) years. By the way, in the message Tabby doesn't say how much he worked his machine with this battery.
As for batteries, their every purchases based on their perceptions of feasibility.
