Accuracy
Вычислитель
Accuracy
Post by Вычислитель » Mon Apr 28, 2008 19:04
You want to raise the accuracy in mathematical calculations. How this can be done using discs?
Do I understand correctly that you can use:
1) Conductor, setting itself the goal of raising accuracy (by the way how can I put it).
2) Like Star traveler also contributes to accuracy?
Does it make sense to use both? (the wanderer and the Explorer in the morning in the evening)
Мирта
Post by Мирта » Mon Apr 28, 2008 23:00
If you have a machine, use the session activating the left hemisphere, if the course is passed the recommended course alpha sessions. If not passed, use alternating ( interval at least 3 hours ) an alpha session and listen to discs: Star traveler ( the track "Star Flight" ( sumarno day for no more than 45 min.), preferably in the morning, activate...), Ultralong ( by special request ). Read branches about any of these disks. Success !
Offered the option of disks has been discussed and could certainly be recommended, judging by read in the forum. ( To the Conductor has not yet reached. Feel that thing apparently serious, requires preparation...) :oops:
Post by Dimas » Tue Apr 29, 2008 12:14
Calculator
I think you need to improve your attention-IMHO this is an alpha session...
Re: Accuracy
Post by Андрей Патрушев » Tue Apr 29, 2008 16:03
Вычислитель wrote:is Required to raise the accuracy in mathematical calculations. How this can be done using discs?
Star traveler improves short-term memory and attention, and therefore contributes to any purposeful activity. And the Conductor is not quite what You think...
Of course, the alpha session mindmachine will also contribute to Your problem.
Вычислитель
Post by Вычислитель » Tue Apr 29, 2008 21:25
The wanderer enhances the period after listening or after a course of auditions this effect is fixed? Why Explorer will not work? Like there you can set yourself goals than improving accuracy (calculation errors ) is not the goal?
Thanks for the replies.
Мирта
Post by Мирта » Tue Apr 29, 2008 23:29
And what you compute without errors? Maybe this can be your goal?
Вычислитель
Post by Вычислитель » Wed Apr 30, 2008 0:05
Short-term Yes. Control/tests/exams must pass, and yet too many computational errors such as 2+3=6
Post by Guest » Wed Apr 30, 2008 12:15
Вычислитель wrote:wanderer improves the period after listening or after a course of auditions this effect is fixed? Why Explorer will not work? Like there you can set yourself goals than improving accuracy (calculation errors ) is not the goal?
And immediately after and fixed with regular listening.
And who told You that the Explorer will not work? :)
Вычислитель
Re: Accuracy
Post by Вычислитель » Wed Apr 30, 2008 23:55
Андрей Патрушев wrote:a Guide is not what You think...
Well put, that's who said... :D
But I do not understand why will not work, and what I think is wrong.
Re: Accuracy
Post by Андрей Патрушев » Fri May 02, 2008 9:50
Where does it say that it is not suitable??? :)
Вычислитель
Post by Вычислитель » Fri May 02, 2008 15:31
So. I'm confused :shock:
And how you can use Windows Explorer for my purposes. In fact the whole essence of the question.
Post by Андрей Патрушев » Fri May 02, 2008 18:33
Вычислитель wrote:So. I'm confused :shock:
Yes, as You wanted, but to shoot from a gun on sparrows? :?
Вычислитель
Post by Вычислитель » Fri May 02, 2008 22:28
And what better to use?
Post by Андрей Патрушев » Fri May 02, 2008 23:08
Вычислитель wrote:And what better to use?
Can Music for hypnosis and self-Hypnosis can Theta Hypnotic Trance.
