If you have any further questions,the topic will be supplemented. Friends,please leave questions below this message. To answer the question,post the application will be deleted and the question-answer moves in THIS post. GO!
How to choose a mind machine?
We have selected the best mind machine in the world. In any case, you will make the right choice.
Model mind machines:
InnerPulse - http://www.mindmachine.ru/photosonix/innerpulse.htm
What you need to for yourself. Price - 8.050 RUB.
Nova Pro 100 - http://www.mindmachine.ru/photosonix/nova_pro_100.htm
For professional work and clients. Price - 15.650 RUB.
Avstim MindSpa - http://www.avstim.ru
Stylish, comfortable, superior glasses. Great for travel. Easy to use. Price - 12950 RUB With two points.
Comparative table of the technical characteristics of the mind machine Photosonix - http://www.mindmachine.ru/articles/table.htm
Comparison and Avstim MindSpa InnerPulse - http://www.mindmachine.ru/articles/foto_report.htm
The InnerPulse mind machine Nova Pro 100 you can purchase with standard glasses or improved. Glasses can be purchased separately later.
What is the difference glasses standard, Premium, ColorTrack and what should I choose?
Points standard with green and red LEDs. Have a brightness of 0.3 Candela. They Shine less brightly than others, but for training brain is suitable, although with these glasses pictures on the internal screen did not appear. Set the mind-machine with these glasses kind of economy version.
Points Premium with white and blue/red (Indigo) LEDs. Have a luminance of 1.4 CD. They are the brightest of all, presented by Photosonix.
When working with these glasses, the visual effects will not keep itself waiting long
ColorTrack Glasses – the latest model from Photosonix. They are considered versatile because of the ability to switch to any of 20 colors, switch directly on the ColorTrack mode,which allows you to automatically switch colors depending on the tone emanating from the device, also these glasses can be used for color therapy.
Moreover, the perception of the same session with different flowers - different. In my opinion – the most interesting and Premium ColorTrack glasses.
Description points - http://www.mindmachine.ru/photosonix/glasses.htm
forum Discussion - http://www.mindmachine.ru/viewforum.php?f=11
How to buy a mind machine?
Write the model for mind machines and the shipping address on http://www.mindmachine.ru/contact.htm
If you order with improved points - enter their name.
Phone numbers for reference: (499) 189-23-78, 180-99-52, and 8-916-164-74-74. Call with any questions.
What are the limitations and contraindications for the use of mind machines?
Not photoepilation sewn into the pacemaker, schizophrenia...And we recommend you to use children after 7 years.
a List of contraindications
Side effects
where would you like me to start, how much time per day do I need to take breaks between classes?
It is recommended to start classes on mind-machine alpha sessions (all sessions is at relaxation, even in the InnerPulse session Impruve 2).
-Time classes for approximately 45 minutes a day, this is a good time to break 3 times in a fifteen to twenty minute break between classes should be at least 3 hours (it concerns the work with a mind-machine, and work with the discs).
Alfa sessions should continue for 21 days to give the brain the opportunity to get accustomed to the external stimulation, then we can begin to deal with other programs (disks A. Patrushev, "Conductor", "the Healing. Down the magic river", "Massage of the brain," "Star traveler", "Hypnotism and self hypnosis", "the solar wind" - also recorded with the alpha frequencies).
The optimal time of each disk 21 days at a minimum interval of 21 days, but best results are obtained with the interval of 3 months, as the brain needs time to integrate changes.
Description of discs - http://www.mindmachine.ru/patrushev.htm
How to extract the maximum benefit
What is better to put the brightness and sound volume?
The brightness on the glasses and the headphones should be comfortable to grasp and not to interfere with deep relaxation.
the Main mistake of beginners
Can I listen to your favorite music in parallel to any session?
Of course you can. One shouldn't make the music too loud.
In mindmachine Navigator has a built-in player. In earlier models with the included cable to connect to player.
http://www.mindmachine.ru/m-m.htm
What drives A. Patrushev should be ordered initially? And where about them to learn more?
for starters it is better to take the disks on which the recorded alpha rhythms. This drives "Massage brain", "the Healing: On the magic river", "Guide", "Star traveler", "the solar wind", "Music for hypnosis and self-Hypnosis".
People with various kinds of depressive syndrome can help drive "Endorphins," but it is written with the use of beta rhythms.
Read more about the disks can be read here: http://www.mindmachine.ru/patrushev.htm
What drives A. Patrushev is possible to translate/convert to MP3?
All of the drives series Theta meditation (5 discs). It is possible to convert the same and drive the Explorer, but the MP3 will cut off high frequencies, which will lead to the disappearance of audiostrobe effect. "Yes, I already wrote more than once: Explorer - can, the first three tracks of Ultramega - can all Theta-meditation - can." In the Converter must be removed checkboxes from the options:
Allow mid-side joint stereo;
Allow intensity joint stereo;
Allow nerrowing of stereo image.
Because these options are "kill" binaural beats.
(A. Patrushev, personally
When listening to CDs A. Patrushev without Mindmachine (CD-player, CD - player, etc.), what requirements must be to the headphones?
Headphones should at least reproduce frequencies from 20Hz to 20kHz. Better if it will be light earphones with soft embouchure, comfortable and not irritating the ear and mind relaxation.
will I lose my effectiveness when listening A. Patrushev without Mindmachine? If Yes, how much?
No, not lost. Almost all drives Andrew P. recorded audiostrobe signal that controls the blinking of points (this requires a mind-machine)...
Flashing points enhance the effectiveness of the drive, but Andrew you can listen to the device, they are self-sufficient.
While listening to the sessions/disc fall asleep. Why is this happening and how it affects the efficiency of MM or CDs?
This is a normal reaction, most likely there are arrears of sleep. On the effectiveness of MM and disks is not affected. Most likely, when You make up the arrears of sleep, You will cease to sleep and You have to keep mindfulness while working with the programs.
What not to do with MM ever, even if you really want?
To listen driving under alcohol/drug intoxication, wash in running water and lick the contacts
What to do if after the first "success" comes an inexplicable reluctance to continue the practice?
To motivate yourself, read the forum
instructions MM is it written that an hour a day maximum. Different people say different -- from 30 minutes for 3-4 days up to 2 hours a day. How to find out your "temp" without any harm?
You should start with 45 minutes a day, having broken into 3 classes. After the 21st day, listen to yourself. The main thing that class was a pleasure.Any session can be ullshit and increase two times in increments of 1/8. After pressing the PLAY button while a 10-second countdown, you can press the SELECT button and the up and down arrows to change the time of the session, then click the PLAY button (the countdown will end and the session will start).
Fundamentally the first time to break 45 minutes 3 classes per day or 2 for 20-25 minutes? (At work still somehow it is hardly possible to deal with such things.) What is worse?
Not essential, but optimal.
whether you need complete silence when listening to the sessions? Bad, if my house except in the dead of night, it does not happen constantly stomp and drill the neighbors, there is construction in the yard, someone behind the wall yelling and loud listening to music, etc.? Or this "everyday background noise", which, existing from day to day, it becomes a healthy person invisible (I do not interfere), will also be invisible and when listening to the sessions?
Make the sound in the headphones louder, so the noise didn't really distract You from studying. The essential element of silence is not, but desirable, Yes.
Have mindmachine session represent only sounds, other noises, music, etc. or there is verbal support?
If it is, it is in English? If in English, how it effectively if we are Russian-speaking people, even if we know English?
In mindmachine active principle are pulsating light and sound. Verbal accompaniment or music You can run in parallel any time, on any playback device via the supplied connection cable.<
