Newbie wants to know
анатоль
Post by анатоль » Tue Jan 29, 2008 14:28
Hello! Can you please tell a newbie how to record the audio program from the machine to disk so that it can be on a normal tape recorder to listen to?
If you can, then technically explain step by step.
Thank you.
Re: Newbie wants to know
Post by Андрей Патрушев » Tue Jan 29, 2008 16:25
анатоль wrote:Hello! Can you please tell a newbie how to record the audio program from the machine to disk so that it can be on a normal tape recorder to listen to?
Thank you.
If the tape recorder, the output from the machine to stick the headphones to the input of the VCR (with cable included), set the volume level and the recording level not to scale - all. :)
And so to the disk, then the machine should be connected the same cable to the line input of sound card of the computer, any recorder to record in WAV format, then saved the file using "Nero" to burn to the CD-R.
анатоль
Post by анатоль » Wed Jan 30, 2008 3:07
Thank you.
Константин2
Post by Константин2 » Sat Mar 15, 2008 15:21
Health and prosperity to All :)
On the forum I'm the new ,new theme did not raise ,I think this is right?It has been for newcomers.
I understand that :-I wear glasses,the headphones,turn on the machine
see nature and listen to the sounds of nature,right?
All of this in three dimensions,right?
Please explain :oops:
Malvina
Сотрудник mindmachine.ru
Has thanked: 5 times
Been thanked: 12 times
Post by Malvina » Sat Mar 15, 2008 16:24
With headphones You will hear a sound like a buzz. Glasses will be flashing LEDs and through closed eyelids, You will "see" most likely colored fractal patterns. Depending on the selected session, it will last from 5 to 45 minutes.
Константин2
Post by Константин2 » Sat Mar 15, 2008 17:03
Thank you :o
анатоль
Post by анатоль » Thu Mar 27, 2008 16:46
Good afternoon.
Andrew, can you please tell me such a thing. Write books, productivity high, but I want to improve, of course. What default program PRO100 is better to use? The waves create a balance of logic and literary inspiration? Better to lean on theta frequency or beta?
With respect. Anatoly
Post by Андрей Патрушев » Thu Mar 27, 2008 17:12
анатоль wrote:Good afternoon.
Better "lean" on the alpha frequency, as they join Your creative part with nebistinsky. :)
анатоль
Post by анатоль » Fri Mar 28, 2008 1:44
Thank you for your answer, but I want to clarify this point: I spent 12 years practicing magic, neoshamanism, go on anomalous zones with theta frequencies familiar to various overloads and strains on the psyche and energy used. In this case, it is better for literary creativity alpha frequency to use? Or is it, theta deep pump? It's also an art, and how! Especially when other forms of intelligence are present.
Thank you. :o
Post by Андрей Патрушев » Fri Mar 28, 2008 11:05
анатоль wrote:Thank you for your answer, but I want to clarify this point: I spent 12 years practicing magic, neoshamanism, go on anomalous zones with theta frequencies familiar to various overloads and strains on the psyche and energy used. In this case, it is better for literary creativity alpha frequency to use? Or is it, theta deep pump? It's also an art, and how! Especially when other forms of intelligence are present.
Thank you. :o
Until the accumulated alpha is useless and may even lead to, say, several unpleasant consequences (nightmares, bad mood, bad synchronism).
анатоль
Post by анатоль » Thu Apr 03, 2008 14:07
Hello.
While more time working with alpha on the subject of creativity, but rezultati, visible.
Vsvjazi with this next question.
How to sharpen logic and datecache? Is it possible in the alpha, for example, in session G11 to achieve this operation, or to use some standard at About 100, the program?
Thank you.
Post by Андрей Патрушев » Thu Apr 03, 2008 20:31
анатоль wrote:Hello.
Thank you.
Logic can "sharpen" only the exercise of logic is not a state, and the ability.
In machine have a session on visualization in section "C".
Джим
Post by Джим » Fri Apr 04, 2008 1:59
Anatole
not guys You are a beginner... (sorry)
About alpha sessions -- for me personally (that's me) is not impressed not one relaxation of NP-100. But all session of AP, posted on this site work just fine (well, if without pathos - the work is good :) ).
Anyway, if we bought the machine Photosonix-IT Must at least to try (session == the text files, they have comments, they are helpful to read).
анатол
Question
Post by анатол » Sat May 03, 2008 14:02
Please tell me such a thing. That all said alpha calms etc I listened to it, listened to a couple of weeks and then it became such an aggressive, arrogant, brown. All yelling, lashing out. Very scared. What is the matter, do not understand?
Re: A Question
Post by Андрей Патрушев » Sat May 03, 2008 21:31
анатол wrote:please Tell me such a thing. That all said alpha calms etc I listened to it, listened to a couple of weeks and then it became such an aggressive, arrogant, brown. All yelling, lashing out. Very scared. What is the matter, do not understand?
Alpha, except for the fact that calms and even allows communication with the subconscious mind. So take care of yourself "and You will be happy". Currently, the so-called "boiling" - all on different lasts, but not forever...
Post by Dimas » Sun May 04, 2008 11:40
Anatol
Passes,don't worry,the same thing happened..leaves.but slowly(for me at least).
анатоль
Post by анатоль » Mon May 05, 2008 10:44
THANK YOU VERY MUCH.
And I have a question Andrew, do you have programs for MM are the same as on your drives? In order to pay and not discs in the mail to wait and download into the machine and listen.
Post by Андрей Патрушев » Mon May 05, 2008 11:54
анатоль wrote:THANK you very much.
Software for MM - they are free on this site, but where to look for them here I don't know - I never found. :? Maybe the admins will tell...
Post by Dimas » Mon May 05, 2008 12:16
In the articles section,where a bend for mind-machines to download)))
анатоль
Post by анатоль » Mon May 05, 2008 13:32
I was not referring to alpha coaches, of which there are three, but some programs that the drives have, the type of dreaming, theta state etc.
Is there?
Post by Dimas » Mon May 05, 2008 13:41
Anatole
no,unfortunately not,only on disks :)
анатоль
Andrew
Post by анатоль » Wed May 07, 2008 14:06
Andrew, you a personal message.
Re: Andrew
Post by Андрей Патрушев » Wed May 07, 2008 20:31
анатоль wrote:Andrew, you a personal message.
Thank you - I thought... :?
анатоли
Post by анатоли » Sun Jun 01, 2008 15:07
Hello.
Here's situeyshen, and need advice.
To me the other day in the street, and recently began to work actively with tettey. And sick: runny nose, cold, state is on the verge of flu, although the external stimuli (not inflated) was not.
Is it possible that the occurrence of the "disease" SWAT in tettau?
In this case, the program PRO100 - C8 (dreaming images).
Thank you.
Карил
Post by Карил » Sun Jun 01, 2008 15:14
I think it's much easier.
Colds are transmitted by vozdushnokapelnym. Enough in public transport a few moments to breathe with the ill person. And not necessarily catch a cold.
I'm no expert, but I think that cold should be a period of maturation, when a person is sick, but it it is not visible. That is you can catch from someone else close to you that is feeling pretty good.
