AVS in the workplace
Карил
Post by Карил » Sat Nov 24, 2007 10:02
You can listen to at work to cheer up?
Massage of the Brain, 2 track Star wanderer, Mozart, and more?
And the second question, which program I can make a small 3-5 minute short. wav OK with binaural beats. I want to record myself audio CD and listen to it every half-hour for five minutes at work. But if I massage the brain in the editor somewhere will necropsy to pieces?
Well and accordingly the last question. Where can I read the theory? What frequency, how to move to avoid addiction and adverse outcomes? Don't want to reinvent the wheel trying to imagine everything, because it has long been known.
Mayd car I for work will not suffer. Glasses do not wear, and then go to the boss (he is French, and Russian do not know) and I will be to your mixes English with Nizhny Novgorod to explain to him what a mind-machine... :?
Re: AVS in the workplace
Post by Андрей Патрушев » Sat Nov 24, 2007 20:09
Карил wrote:you can listen at work to cheer up?
Massage of the Brain can only last 9 minutes contains frequencies for awake (by the way, is absolutely similar to the 2nd track Star Wanderer). The frequencies (including the carrier) are pretty much written in my Handbook: "the wounded..."
Reactors Cool Edit Pro, Adobe autdition, Sound Forge all versions.
Карил
Post by Карил » Sun Nov 25, 2007 0:44
Андрей Патрушев wrote:the frequencies pretty much written in my Handbook: "the wounded..."
Thanks for the reply. The question remains at the carrier frequency. What should be the carrier frequency? It definitely needs to change during the session or may be one? There are requirements to the carrier for beta, alpha and theta binaural beats? The range of the carrier frequency must be in a certain limit, or take any from 30 Hz to 2000 Hz?
Карил
With open eyes
Post by Карил » Mon Dec 24, 2007 15:26
Does it make sense to listen Star wanderer with open eyes and this time say something to read or write for example here in the forum? Maybe it's a waste of time?
Post by Андрей Патрушев » Mon Dec 24, 2007 15:50
Special requirements to the bearing no. 165Гц frequency to resonate with internal organs, so it's best this range to avoid...
Re: With open eyes
Post by Андрей Патрушев » Mon Dec 24, 2007 15:52
Карил wrote:does it make sense to listen Star wanderer with open eyes and this time say something to read or write for example here in the forum? Maybe it's a waste of time?
There is no difference how to listen to the effect in any case is maintained.
