Stabilizer.
Свитлана
Re: The Stabilizer.
Post by Свитлана » Sat May 16, 2015 7:16
:aa
Свитлана
Re: The Stabilizer.
Post by Свитлана » Sat May 16, 2015 7:17
Петр. wrote:
Свитлана wrote:no concentration
On the website mindmacine section drives Andrei Patrushev is the section: Set "Theta meditation"
This section is a CD-Concentration.
http://www.mindmachine.ru/audio/teta_meditation.htm
Gave this CD to friends who work in the administration in one of St. Petersburg universities.
In their segment of work is very high turnover of work with documents and different kind of attention. And the problem with the focus at the time was extremely relevant. After a week of listening to the disk performance has increased 4 times and the working time reduced to 2 hours, later they were very happy.
When wearing BJ (even the simplest versions) is more for a long time, concentration also improves and becomes comfortably manageable.
http://www.mindmachine.ru/braslet/index.htm
supper !!!
thank you so much!!!
:aa
Свитлана
Re: The Stabilizer.
Post by Свитлана » Sat May 16, 2015 7:36
Аннаель wrote:I Have a perfectly working Stabilizer just printed from this website! Cut a circle of paper, something suitable painted or numbered, this circle, a wish was recorded in a notebook, and a circle off to the appropriate sector of the Stabilizer! Worked great!
Anael, thanks for the reply !!! :aa
could you tell me please , and in which sector to put the circle with the desire ? :ay
Свитлана
Re: The Stabilizer.
Post by Свитлана » Sat May 16, 2015 9:04
Михаил_ wrote:start with a panacea, we suggest.... 5 minutes is necessary. And then to add translation map "Pandora 0.5" - it is also free of charge.
Michael , thanks for the link! 0.5 how to make I found , but a cure can't .. :cry: found a description of cure of the BZ , but I can't find how to do it .. bc .. :aa
Re: The Stabilizer.
Post by Михаил_ » Sat May 16, 2015 12:22
You'd sites read more .... in detail, and then "circles"....
What do you mean circle? anchor it's called and there should be a print of a mandala anchors;
What does it mean in which sector? for each task in your!
Re: The Stabilizer.
Post by Михаил_ » Sun May 17, 2015 13:22
Anchor is a special thing with a special image, stabilizator consists not only of the working field, but from a set of "accessories" like chess are not only boards, but also of shapes. So do not rush, there is no need to try to understand, there is simply no rush to understand. All clearly described.
Макте
Re: The Stabilizer.
Post by Макте » Tue May 19, 2015 7:11
last night after work was removed from staba anchor "as a driver" and this morning, 500 meters from the house "moved"! :lol:
photo probably... :cry:
PS: thanks for the quick traffic police inspector
Re: The Stabilizer.
Post by Михаил_ » Tue May 19, 2015 14:02
and why was removed the anchor?...
Макте
Re: The Stabilizer.
Post by Макте » Tue May 19, 2015 14:29
Михаил_ wrote:and why was removed the anchor?...
yesterday was a "little" overweight on health (according to my records - day in this respect very different from the usual "everyday life") - decided to "zero out" and take a break for a week. I'm all anchors removed from staba (and SC "suspended", and the task of alfavita removed) as the current controlled projects and tasks for a number of reasons right now can't do well, and put yet them all on time, so that resources are not pulled.
ДмитрийКО
Been thanked: 3 times
Re: The Stabilizer.
Post by ДмитрийКО » Mon Jun 15, 2015 9:18
Made his first stab homemade paper, which is one small SW. Bopara posted and it later save Finance will do more and poprawienie. Yet without my friends. Question what their health, I like to work. I have a disorder of hearing, constant noise in the ears-cause the auditory nerve is destroyed. So I anchor sign No. 1 for example -in a notebook put a transcript of the "Destruction and deterioration of hearing I (destruction of the auditory nerve). I put in a STOP-that I did the right thing to stop further destruction or something only to put the right wording.
I'm not quite understand with separate matrices for staba for example "health" (I understand it separately as you can carry), and stabe where to locate or they are alone somewhere and they anchor? Or don't anchor :? Please explain neobessudte.
The stabilizer can be used as a conduit to the experience, ie, the need to intensify their forgotten ability, quality etc.-it is necessary to put the anchor in the "DEVELOPMENT" or "Creativity" may "IN the LAW" -where? While such questions. 8)
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Mon Jun 15, 2015 9:25
A question back such a plan. With my car has anyone worked with staba. Well, in terms of fuel economy, the efficiency of the engine operation, stop the rust on the car (corrosion), etc. Just don't want to experiment with him not knowing the Ford. Does anyone have any positive examples. Just put gasoline in a "stop" to save in our hard time and he will not go.-ie my car. :?
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: The Stabilizer.
Post by Petr99 » Mon Jun 15, 2015 14:13
better to practice on something cheaper
Re: The Stabilizer.
Post by Михаил_ » Tue Jun 16, 2015 2:27
I have been working with panzanini and pantomime programs with it. Stub but I don'T recommend. Because in addition to the fuel may indirectly affect other aspects of the drive.
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Tue Jun 16, 2015 10:11
It is clear, and interesting Michael panzanini programs it is as if it is not a secret. :oops:
Re: The Stabilizer.
Post by Михаил_ » Wed Jun 17, 2015 2:46
Well, apparently, quite simply, describes the process (it should be) influence on the process of engine operation, the combustion of fuel and so on.... in General, it is possible to grasp the figurative reading, for example, about the impact of the same on the turntables and car owner :) reading the descriptions of the products working as space harmonizers car with the result of saving fuel.
I'm not talking about "Stripping" other people's ideas, there are basic principles - they are General. To them can be different come with different ends. I mean, seeing that in different examples, the basic principles, you can understand where to act. Pan-KO is taken as the energy Converter and the active principle. Although pandorea TO this plan much more powerful.
The program is written based on the understanding of the "physics" of the process. And forth. The program is a mental algorithm of how TO should behave, how to take energy and what to do. Like everything prozrachno :)
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Mon Jun 29, 2015 22:06
Can basic mandala with a length of 7 cm, placed in a metal tray with a diameter of 30 cm, i.e. the mandala is taken from the file available for download, and it is there in a reduced form, or it is better to increase proportionally to the size of a saucer?
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Mon Jun 29, 2015 22:17
Stuck basic mandala 7 cm, and poured glue on top of the polymer (which is attached a ceiling tile). Transparent and and cures in one day. Is it possible?
Re: The Stabilizer.
Post by Михаил_ » Tue Jun 30, 2015 1:58
Not very clear question - covering the stabilizer or just mandala? a thick layer of tile adhesive is not the fact that dry, and I would recommend all the same epoxy
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Tue Jun 30, 2015 7:55
Filled only basic mandala tray this glue yesterday was dry, but underneath the mandala of the visible line from marker where I marked a line, and the mandala as if "wet" in aqueous divorce is not critical for its operation and for others?
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Tue Jun 30, 2015 22:23
Did so on top of the small base of the mandala stuck more with saucer size of the same mandala(on the printer a little paint over the color and mandala came out a little bit netogo shade-not critical the main process that is behind it.) caused well as adhesive polymer, dries will continue to work. Yes, like clay is found, with drosou problem, want TO complete to street, what is this amethyst Druze use for charging Panacea 2.9, what other minerals (such as well, it was not mono, i.e., not single crystal) and something else instead, someone that tried it. Thank you.
PS I only Have a crystal of quartz, charged BJ 1.0. And a piece of granite can be used? :oops:
Petr99
Re: The Stabilizer.
Post by Petr99 » Wed Jul 01, 2015 6:36
better a piece of granite
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Wed Jul 01, 2015 8:56
Yes thank you took.
Re: The Stabilizer.
Post by Михаил_ » Wed Jul 01, 2015 13:10
the Druze have a sense that its a lot different (weight of crystals of different type/shape) and not a single mono-crystal... a piece of granite is also fine but do buy druso not a problem - you can look, you can still where. Instead of a piece of granite use granite chippings - also normal.
not recommended for mono-crystals to use.
ДмитрийКО
Re: The Stabilizer.
Post by ДмитрийКО » Wed Jul 01, 2015 19:50
Today made stabilizer No. 2. Mandala glued on top and missed a polymer adhesive, epoxy lacquer on top, a thin layer poured in the middle of a piece of granite loaded by the matrix P and the translated mode 2.9. Clay from the lake, paraffin, Eph. oil "lavender". Now drying. Later will work. :wiz
Petr99
Re: The Stabilizer.
Post by Petr99 » Wed Jul 01, 2015 22:43
essential oil rose or ylang-ylang high-frequency
