This is from the lectures recorded at workshopsРаймис wrote:It is in any of the books described? The World Of Trinacria? They are available in electronic form?верунчик wrote:system trinacria
Bracelets Life
should go to sleep for an hour, here is the theory and practice of inscription on the body and skin development
1. mental mark will give many a little more than a faint impression.
2. ideal charging is rarely possible, I suspect the conditions under which it can occur, and these conditions are not compatible with live objects, but the object (small) charge so it seems possible. It's all about charging systems 1.0-2.x
3. nails and body parts, the bad thing is that it turns zonal impact is not very uniform. A possible bias. It is possible TO equalize 2.x
4. the issue of inclusion to, and then create a Lite version for the 2.x is not worth it due to the fact that light on the principle of constructing the matrix it's hard to make the transfer and copying to do and great processes of charging and the creation of new for. 2.x there is integrated in the dynamics of the process.
5. MAG.no, in paragraph 7, the extension will be at the normal 2.0 charger as the links 2.x bracelets without any lights, only it there will be one on every watch with a bracelet, we tried it on some hours earlier (only engraved plastic strap next to the watch case) - it turns out fine. Shift in quality 2.x will not, because there is still the extension will be integrated on top.
6. of course for its intended purpose 1.0 the light applied to the body, clothing and areas of the ACC. on different systems may be the most beneficial assistance in emergency situations for which 1.0 Lite was done.
7. applied to blur slightly when the alignment of the cocoon with the conscious or subconscious desire to remove the obstacle, which can be perceived zonal impact (bias). At least traces of otbrosit I have never faded, even from 1.0, i.e. me with them subconsciously too comfortable. Theoretically, the wipe inside the cocoon is not a problem, it's sort of its own territory, but this blurring should be steady desire and the process will require time and effort (not everyone has that and that is combined), so simplistically we can consider the trace of the bracelet difficult placed, well applied to the body, especially the nails will create not only a trace, something more powerful. The bad thing is that 1.0 Lite is not integrated into the overall system BJ
8. Brasserrie at (watch пп7 from the list) seems to be in the office tomorrow, in a limited quantity, which will be gradually increased. the democratic value of 3500, to change I think not. This is the most weird of the latest developments
because it generated a funny phenomenon.... works but only in the presence of at the base as well, and some бж2.0-2.x
[quote="Michael_"]should go to sleep for an hour, here is the theory and practice of inscription on the body and skin development :
So after 2.X has not been canceled.
And zonal effects if the body is sick, it's the bias? From effect to cause
2.x is not at all, and the light .0 actually conceived as a means of first aid. Draw matrices can be a lot, but consciousness 1.0 full charge too much, but probably much less. I tried once on how much I can take, actually when we developed the module "printing" with automatic selection the purpose of charging the person.
so I have described above... just version 1.0 do not integrate with each other and 2.0 -2.x integrated.
1.0 Lite Express system of records 1.0 with a shift to more direct and powerful influence, for urgent applications - the most it.
in other cases - not a fact, but have already found ways - bath charge... soon the oceans and seas
I did all the night erase from the sternum of his mental records..., overdose happened.Малика wrote:Nuuu.. if that.. then Zap, erase, wipe out, unless of course have
Happened to dissolve the recording only in the morning.
In General, Michael is always right, don't need to crawl across farther.. but so want to try...
Probably most of us on this forum with the spirit of the experimenter
remember Monosov has a favorite joke that all is learned from experience, but some experiences can only be obtained once in a lifetime.... that experience was not the last extreme is not necessary. from BJ certainly do not think that someone much sproket, but overload is also not needed. By the way nails will erase harder, because there the fabric is more specific, her record will be stronger than in other places.
Much EASIER, if you really really want to stick the patch, if you want to the big "territory" of the body - that a lot of small.... easily removed.... the trace of the BZ will remain, but it no activation behaves differently (quietly).
Малика wrote:I did all the night erase from the sternum of his mental records..., overdose happened.Малика wrote:Nuuu.. if that.. then Zap, erase, wipe out, unless of course have
Probably most of us on this forum with the spirit of the experimenter![]()
I body experimented
Малыш wrote:bath then let is
Michael_ how reflects the size (and number) of the charging matrix 1.0 L (or the area of the coating matrix) and location (inside/outside contact/back-side) for large and massive objects?
Tableware (glasses etc.) is possible (useful?) charge 1.0 L
You do not want in the category of experimenters book. please:)...
Sincerely, MAG.no
