Small offtopic.
Has thanked: 13 times
Been thanked: 49 times
Re: Small off-topic.
Post by ФилиНН » Sun Nov 10, 2013 15:11
I ka-a-would prove, would be some kind of compensate - neither here nor there.
And I love the furniture-transformer :)
rel
Has thanked: 222 times
Been thanked: 84 times
Post by rel » Sun Nov 10, 2013 15:24
ФилиНН wrote:I ka-a-would prove, would be some kind of compensate - neither here nor there.
damn Yes, that's also fear that)) but what to do..
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sun Nov 10, 2013 15:45
probably like to think))))))) so you can just try....... if you glue layers, a few cm of the wall turns out to be sustainable, and between the insulating shields in the three-dimensional shape can be assembled on the tape at any time to turn back....... the design is very lightweight and the shape keeps the rules. without additional materials.
Sincerely, MAG.no 〠
PS To help you: Cabin Reich (discussion) and "Karl Welz. Magic of the future" (download)
rel
Post by rel » Sun Nov 10, 2013 19:55
It turned out a friend the Pilot was right) - ie I read that the only section of the BZ, and it turns out that in other sections of this two years ago discussed.. the Answer is not found, but the probability of this has increased dramatically. :) MAG.nothank you very much!
Лоцман
Post by Лоцман » Sun Nov 10, 2013 22:11
rel wrote:comrade the Pilot
Remember this face... :)
Владер
Post by Владер » Mon Nov 11, 2013 6:47
Unnecessary and to and fro, means nothing.
Foil to the body. If the body is inside the box, then foil inside.
rel
Post by rel » Tue Nov 12, 2013 5:35
Vladerthank You! Have already understood this, but still, thank You! Now, finally, there is clarity.
MAG.noand You thank you again for the book) This in a new "stable datum" for me.. eliminated a number of issues that are 'drowned' in themselves so as not to get bored there.. and in the book Welz just a wonderful beginning, very much clarifying.. as one of the results, the second day enjoy the vision of energy! swirling and dancing over freshly vodokanali)) is not too "contrasty", but I see!!.. :)
rel
Post by rel » Wed Nov 13, 2013 7:04
By the way, I understand what to put on all the layers Panacea! :) First received in confidence, and now I know why) Do I "build" only "insulation" for self-repair, but didn't know when she will "orgone generator". And by default it pulls everything - good and bad. For "filtering" usually put the crystals twist spiral and MB. something else.. And in this case the role of the cutter or drive to the tow plays a P. she Might not be as natural as crystals (maybe more natural)) - but can more accurately. Of course the krutyak when I'm able to already go back and I.. well, by and go)
Post by ФилиНН » Wed Nov 13, 2013 7:52
Toko "dose" it is better not to overdo it.
I have a blanket OLM-1 on the same principle, it seems(written - metallized polyester inside) There is in the method of applying painted: up to 20 min - stimuliruyushie effect, 40 sedation, if not distorted by memory. "Crash" it happened for an hour and a half, and then 10 minutes lie-Wake up, no strength even to get out, so "orsedative" :)
rel
Post by rel » Wed Nov 13, 2013 8:22
Yes, already noticed the feelings. Fell asleep on the pillow - get up hungover..
Well then, moving away) still rode-worked just fine. But it's better than "borsite", of course.
АМИРА
Post by АМИРА » Wed Nov 13, 2013 21:20
rel , you can look more information about metallic fabric Metakron ( Marichev Anatoliy ) :)
http://www.metakron.ru/
rel
Post by rel » Thu Nov 14, 2013 3:55
AMIRAthanks, it's actually the most it!.. :)
EXT. off.top) - Amazing apart action Technologies Michael (+ Eureka, ASD etc), I was hoping for in the first place, "bonuses" are more and very useful information, there are gifts, tips.. even unusual to experience such "volume" of gratitude just overflows))) and to the developers, and the Community, and in General)) Brothers and sisters, all you Bright and Wonderful!!! =o)
Post by Михаил_ » Fri Nov 15, 2013 3:35
why metallized fabric???? weird... actually need something else.
rel
Post by rel » Sun Nov 17, 2013 8:43
Michael, and You're talking about any kind of metal.fabric? .. not looking info about this?
they there seems to promise similar effects bioresonance, Regency-self healingclinical trials were
can You just outright shallows, not going deep, and suddenly the theme is also fit..
Post by Маг.нет » Sun Nov 17, 2013 22:05
Insulation (interrupted) and directional flow (trend) of different aspects of energy cooperation.
As I recall, about the fabric this Michael_ knows how thoroughly it explored the usefulness and applicability of the I don't know.......
Information technology can often be softer and more environmentally friendly the result, while more efficient, perhaps that is why the properties of this metallic fabric as insulator energy-BJ-technologies were not popular. But still Michael_ can clarify this question better (if you stay the need for response).
Sincerely, MAG.no 〠
rel
Post by rel » Mon Nov 18, 2013 2:08
Oh, once this is known, it is another thing.. about clarity, I do not insist, but would be glad of course.. Because I'm first a camera-profilului-(light) perceived as isolating, and the fact that Orgon's walking was a surprise. And right then, a rough analogy that orgone/heat insulation material is laid is an analogue of ASD, and the insulation acts as starvation, i.e., in the 1st case, external aid, and the second internal restructuring of the defragmentation, i.e. in the first case, the benefit at the expense of excess, and the second due to an artificial shortage? Then I would have both alternated, as with the usefulness of physical starvation sign..
Post by Михаил_ » Mon Nov 18, 2013 2:17
this analogy is not very appropriate, actually I'm talking about the aspects of shielding kind of wrote separately in the subject of EP, if you remember.
do not need to do screen if there is a "organogram", so the fabric here nafig not needed
rel
Post by rel » Mon Nov 18, 2013 2:25
in.. now all merged, thanks.
ie orgone is a "two in one".. then of course.. well))
Post by Михаил_ » Mon Nov 18, 2013 2:33
just effects that someone "caught" on konkrentno "this" fabric is the effects in the first screen, well, people are not studied the topic of screen deep, and I thought that America was discovered...
and in the same ek (physical) I provide a flow through of software on TO well with the desired (useful for celoxica) parameters energy.
Post by Михаил_ » Wed Nov 20, 2013 0:16
a little bit about nutrition http://www.meddaily.ru/article/19nov2013/hlzl
just need a lot of fat I don't really agree, but about the damage to the grain.....
Post by bofara » Wed Nov 20, 2013 2:48
Well, then, here and books of ori Hofmekler, although there is only need the basic idea to learn.
ВикторРусс
Post by ВикторРусс » Tue Nov 26, 2013 21:28
pinwheel bell-bronze (copper+tin), more 15000об/min, disk, glass, spin, water next to the filter to compare, say well, very powerfully came out, somebody says the reason why so..
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Tue Nov 26, 2013 22:21
The resonator you have on top has turned a sickly :)
Post by Михаил_ » Tue Nov 26, 2013 23:50
well here is a bit different principles, but it can also .... impact because we are talking about interaction with sound range (see Valera and Berdina as I understand it)
Post by Нетрезвый Сурдопереводчик » Wed Nov 27, 2013 1:51
Михаил_ wrote:a little about food http://www.meddaily.ru/article/19nov2013/hlzl
I eat almost only cereals and a large amount of vegetable oil or butter. Yes,food falsified for over 200 years. rice is bleached with lime,add in the sugar river sand,treated with acetic acid,butter 10% animal fat and 20% palm oil... accounts for the many evils I choose the least . many years of living,about adhering to these principles
1.63. Goraksha says: you have to get rid of bad company, from warm in the winter by the fire, from sexual intercourse and from a long travel; from swimming early in the morning, from haste and from heavy physical work.
1.64. A yogi can use without fear the following things: wheat, rice, barley, milk, ghee from Buffalo milk, sweets, honey, dry ginger, cucumbers, vegetables and good water. This is beneficial for those who practice yoga.
1.65. Let the yogi eat firming foods-sweet, prepared with ghee and milk - such foods improves mood, improves the condition of the body, corresponding to his wishes.
. About fat, I agree with the author. sometimes I buy a canister of olive oil and "eat" a glass at dinner. Supplements,in my opinion,most of them hooked and used to it.
