Stabilizer.
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: The Stabilizer.
Post by Бисо » Mon Nov 24, 2014 14:07
Hello,
I think that we have the opportunity to make a great Stabilizer, only through the application of a matrix on a concrete floor and want to clarify a few points. Where I live in the vicinity there are several concrete slabs that were part of no longer existing buildings, and now children play on them. I have a large basement, which is empty, and can also be useful.
1. The stabilizer needs to continue to work after erasing matrices. ( the process has already started and the presence or absence of matrix does not matter )
2. Using these concrete slabs for the Stabilizer, it will not affect their strength.
3. Michael wrote that "the Stabiliser is more sensitive to external attention." Well, if the matrix is worn after a while, no one will know that there's something unusually and not be excessive attention and external influences.
Thank you in advance.
Re: The Stabilizer.
Post by Михаил_ » Mon Nov 24, 2014 18:50
be cool if children play in areas of the stabilizer - it may badly affect the health.
Бисо
Re: The Stabilizer.
Post by Бисо » Mon Nov 24, 2014 20:34
Hello Michael,
If I'm not mistaken You wrote that you can make a Stabilizer on the beach, on the sand. This implies that the beach is located and they will lie or play on areas of the stabilizer. This brings me to the judgment that the Stabilizer will not impact negatively on children playing.
If I understand correctly the whole process, in this case, the sand will retain the structure in a short time.
Remains of the concrete slab in the basement and I will look for other suitable places.
Once again thank you for the clarification.
Re: The Stabilizer.
Post by Михаил_ » Mon Nov 24, 2014 21:27
Well, a beach is an unstable structure... there may be something, but not as efficiently...
just some areas are not useful for long stay.
Аиша
Has thanked: 56 times
Been thanked: 14 times
Re: The Stabilizer.
Post by Аиша » Wed Nov 26, 2014 9:06
Michael! Could you elaborate how the "protection" from the stabilizer. Like about her extraordinary nothing is written, and I have 2 days of nightmares "catch", maybe something is not properly done or so blocks out. Please explain about "protection" :oops: Thank you for your answer! While waiting for your answer, will remove all anchors with stabilizer.
Re: The Stabilizer.
Post by Михаил_ » Wed Nov 26, 2014 9:52
nightmares in what way ? it is not clear... perhaps You began to feel what was freely staring at You (realize) it's good...
but this is your personal specifics...
in General, here and to speak there is nothing - protection works how protection.... add not a word comes out, what is the actual question ? little input data
Аиша
Re: The Stabilizer.
Post by Аиша » Wed Nov 26, 2014 10:32
Because of the specificity of nightmares, to describe in detail even uncomfortable.
Михаил_ wrote:likely You began to feel what was freely staring at You (realize) it's good...
I will understand... thank you so much for the explanation, :o there is more work to do! :)
Has thanked: 112 times
Been thanked: 71 times
Re: The Stabilizer.
Post by АндрейКо » Mon Dec 08, 2014 0:50
Good day!
Can I use dish - perfectly round, thick, steel, new - s TEFLON COATED) ?
PS - a skin or coating is necessary to tear off?
Евгений В.В.
Re: The Stabilizer.
Post by Евгений В.В. » Fri Dec 12, 2014 0:19
On the stabilizer printed on the sheet and realized that it's the most amazing device that I can think of. I always thought that it is complicated, the description is weak, need to be picked. But it turned out that you need to take and try at once. I intuitively started working with him and realized that in principle it is physical, and particularly the need, well, maybe just for the sense of confidence that he is, and it can feel. In my opinion from a variety of things, just need a stabilizer and 3.0, well, maybe the amp yet (just my freestuff toys not pull more than a couple of trends). Want to make and paid to try.
Re: The Stabilizer.
Post by Михаил_ » Fri Dec 12, 2014 12:08
Well, the paper work of course, but while the trends are similar....
Simplified understanding about the Stabilizer and 3.0 - is too simplistic. It is advisable to start with 2.or panacea and slowly moving on. Otherwise everything would have come to a screeching halt and stop. Because that won't work because of the pile of internal stuff, which is all we have and for other reasons. In short on a defective car to drive at the speed limit - I could fly. And 3.0 just keep to normally would (the state)
So it's not so.
Well, the usefulness of things (in t/h/ homemade) described in detail many times. Not just.
I would be steamed to do something new if it is not needed? :)
интересующийсябж
Re: The Stabilizer.
Post by интересующийсябж » Mon Dec 22, 2014 4:53
The question of anchors, I want to consult before you put the anchor
"I don't see all of the branches of the probabilities of events and want to reduce the “barriers” that happened, happen or can happen in life. But if the end result is all happening in harmony in the world and I I prevent the emergence of barriers in the decision which I will “grow” and learn. Remove those barriers that are created ilyuzornom or for that would take away my energy, time and distract from the “important” and those which I just oblamayut. "Growth" and "important" are defined at the subconscious level and dynamic."
I'm going to make 3 of these anchors (with the same number) and put them in the (1) development, (2) twilight (3) between creativity and inhibition.
Whether to integrate the 3 anchors are the points where they put a stabilizer in one?
This is not a specific protective purpose, that is, it is infinite ... it's normal for me, is that really true?
Thank you.
Мариомар
Re: The Stabilizer.
Post by Мариомар » Mon Dec 22, 2014 16:09
интересующийсябж wrote:Question by anchors, I want to consult before you put the anchor
What if it is?
1. The harmonious development of all possible occurring events and resolution of adverse situations in the best way. - in development
2. The maximum and effective learning experience in the short and long term - in the chaos closer to NATO, then move in fact :)
3. All possible podlucky, barriers, pendulums describe and bust in the stop and stop-magic/anomaly add.
I just don't get what you mean by "barriers" himself invented and why are they so important? :(
upd. Why not highlight a few trends in its development and each not to beat precision anchors? Makes it more interesting and more quickly the answer comes, sometimes within a few hours. I had a problem with sleep, for example, after anchoring immediately broke the bed and had it thoroughly repaired. Now that problem is no more :lol:
интересующийсябж
Re: The Stabilizer.
Post by интересующийсябж » Mon Dec 22, 2014 16:31
Simple and clear. Thank you.
Петр.
Re: The Stabilizer.
Post by Петр. » Sat May 09, 2015 17:48
Michael, I don't know what branch it is better to write, so I write here.
Interested in how and with what products work best with search engines Yandex, Google, to sites are better displayed in the natural search results.
How this product works, and how to register are needed for this algorithm? One drugstore is bent, get them all ASD 2 in any quantity, it is necessary to help them.
ОлегЧ
Has thanked: 2 times
Re: The Stabilizer.
Post by ОлегЧ » Sat May 09, 2015 18:44
Peter Artifact feedback these issues are dealt with
Андрей С.
Been thanked: 4 times
Re: The Stabilizer.
Post by Андрей С. » Sat May 09, 2015 19:33
I would advise the goal to put the one that is really needed, not the method of achieving it, which you for some reason think is optimal, because often we are not able to logically evaluate such things. That is, put on the harmonization of business processes of the pharmacy as a whole and not on the results in the search engines. If necessary, it can catch up, sometimes in unpredictable ways. It's just personal experience :) I've been through this for their projects.
Re: The Stabilizer.
Post by Михаил_ » Mon May 11, 2015 23:48
Options lot of work, but if we think of the Internet, you should start with the material (to think and read part of the Mat that affects the natural search engine results :) ) and then to the shaman.
In General, all comments are true. Although that's about the drugstore is not clear in the sense of well bent - probably bad. It is not clear why is this in your area operatorsthe and in such a distorted form helps. :) I just didn't understand. T/e/ sounds - will gather many orders for ASD and pharmacy will feel better :)
on the one hand ASD a cheap tool that way, it is useful to take from wholesalers, where prices are lower :) A drugstore there for a change and it ( not on the same ASD the same), m/e/ a feeling that You are some kind of wrong problem is solved....
Петр.
Re: The Stabilizer.
Post by Петр. » Wed May 13, 2015 2:24
The fact that a lot of - it's wonderful :) and wonderful and that the material and Mat are required that can generally be done with search engines, have already been made and the beneficial effect is obtained. Another issue is that the effect is not enough support to secure, due to frequent fluctuations and pressures from the system itself and its larger inhabitants, therefore, there is a need for a shaman now.
In General, all comments are true – I agree and still looking from what side to look... still having issues. And as people do not mind the time to complicate things, because everything is much easier than it seems. :)
Why is this in our area of operatorsthe? The answer is already in the question itself: Thanks to the forum mindmachine, openmagic and positions of Michael about ASD, as well as advice on its use. And here we sincerely notice what a world we ourselves create around themselves. :) But it's not about that! and that usually vetapteka around town ASD to get is not easy, it's almost impossible to find, buying cleaned! And time is a pity and then that really was a problem, plus mark-up of the store. Manufacturer of Armavir releases the SDA only vetapteka and veterinary clinics, the exception is only the fact if You have your own personal contact with them directly. In connection with the situation on-site operator and display your familiarity with private veterinary clinic and its Director-doctor, who now became possible to get SDA directly from Armavir in any quantities. And as you quite rightly pointed out, the weather from orders ASD 20 people from Peter reading Your forum and bought Your product, for of the drugstore absolutely no. :) The drugstore is staffed by good people who just do a good job in terms of helping others, but just slightly behind in information development and maintenance of its activities in the new time, and the competition between them monopolist is under huge pressure, the problem is widespread now. And so was born the quantum of energy to thank them for giving us the opportunity to use this feature in the future.
To work with trends on the stabilizer issues yet. Andrew S. Thank you! :ay About products feedback Oleg to complete the picture I Your commentary is not enough. :?
Do I understand correctly that the product pushes the right flow of information not only for the operator of the product, but also for all those people that will find information of the operator network, while not having this product? (in the context of this problem)
MichaelYou recently created the Context 2 and many other good products that work perfectly! from the stabilizer and other products, simply because they have very different principles and specifics of work, that's why there are questions. Is there a way, how else would it be possible to kick a process of this kind?<
Свитлана
Re: The Stabilizer.
Post by Свитлана » Wed May 13, 2015 6:03
I don't understand it honestly .. BUT yesterday went to the College website and came across the stabilizer.. started reading .. nechalim some strange feeling.. today I went again and as I just started to read the stabilizer again , I started having headache .. hmm .. ?
Re: The Stabilizer.
Post by АндрейКо » Wed May 13, 2015 11:09
Свитлана wrote:I don't understand it honestly .. BUT yesterday went to the College website and came across the stabilizer.. started reading .. nechalim some strange feeling.. today I went again and as I just started to read the stabilizer again , I started having headache .. hmm .. ?
Maybe to start BJ 2.2 worth a try? (or samodel )
Свитлана
Re: The Stabilizer.
Post by Свитлана » Thu May 14, 2015 0:39
Thank you! want BJ and drawing rooms, because after finding this site and just reading about the parlor, in me and in my life started changing .. then stopped to go to this site and everything stopped .. I really want Svetlitsa Blaga , joy and supper , but not yet obtained myself this is all to enable .. :'( a strong strip of failures in life .. but the day before went and found the stabilizer , started reading , started having some strange sensations and then had a headache , again yesterday and now as soon as you think about the stabilizer and write a headache .. really want to understand everything , because I feel this is very strong !!! and most importantly it really works !!! I have one problem , I can't concentrate on reading, really want , but can't from school, I'm an Indigo child if anyone knows what it is ? dyslexic and super sensitive.. there is a spiritual gift to see what ordinary people cannot see .. the problem is that I want to read the description , but no concentration .. in General, the problem with reading .. the stabilizer may help me in concentration while reading ? as I understand it you can draw ? how to use it for this ? and that would go a shift in cases to the best work , there customers and the financial situation has improved accordingly.. really want to buy a chamber and BJ.. can someone in a nutshell explain what this is and how to use it, I'm blonde-so take it easy .. :aa thank you :ay
Re: The Stabilizer.
Post by Михаил_ » Thu May 14, 2015 15:30
Svetlana.
1) please note that all "Indigo children" until they "break" the system of education/training, or rather all have all abilities and no "ordinary people" - exactly, exactly....
just the degree of komandosi and conditions of upbringing/childhood a little different and condition at birth. And all this is easily replaceable.
2) a headache because though You consider yourself an "Indigo child" your ability to sleep, not used to being used, reading the branches touched them and went to work in the head including the growth of circulation (the basic "mechanics") - this gave a headache. Eventually pass. Yes, the stabilizer can simply draw (will be very weak, but will work), read the topic about handmade on my forum.
3) don't need to start to buy anything. Do yourself (BEFORE stabilizer) usual homemade BJ a Panacea. It is very very simple. from any strap/bracelet/rope. Popolzuyutsya them time going the recovery process, it will be easier to learn everything else.
Almost all of my section can be done in the form of diys, so if Finance is not - does not matter.
4) look at life and wider society, do not restrict your capabilities to simple expected changes.
Петр.
Re: The Stabilizer.
Post by Петр. » Thu May 14, 2015 16:28
Свитлана wrote:no concentration
On the website mindmacine section drives Andrei Patrushev is the section: Set "Theta meditation"
This section is a CD-Concentration.
http://www.mindmachine.ru/audio/teta_meditation.htm
Gave this CD to friends who work in the administration in one of St. Petersburg universities.
In their segment of work is very high turnover of work with documents and different kind of attention. And the problem with the focus at the time was extremely relevant. After a week of listening to the disk performance has increased 4 times and the working time reduced to 2 hours, later they were very happy.
When wearing BJ (even the simplest versions) is more for a long time, concentration also improves and becomes comfortably manageable.
http://www.mindmachine.ru/braslet/index.htm
Аннаель
Has thanked: 36 times
Been thanked: 3 times
Re: The Stabilizer.
Post by Аннаель » Fri May 15, 2015 16:15
I have worked Stabilizer just printed from this website! Cut a circle of paper, something suitable painted or numbered, this circle, a wish was recorded in a notebook, and a circle off to the appropriate sector of the Stabilizer! Worked great!
Свитлана
Re: The Stabilizer.
Post by Свитлана » Sat May 16, 2015 7:14
Михаил_ wrote:Svetlana.
thanks for the reply !!!
100% agree that was "broken" in my childhood .. and I'm still a warrior .. well represent, in General, childhood and youth .. hard .. haha ))) and the fact that I'm Indigo and all your extra sensory and paranormal abilities and talents, I realized uzhe in adulthood he moved to England , what is most interesting .. I think with the past life to do.. it was in England found their own kind and started to practice their "spiritual" as they say talent .. much work .. !!! until that stopped the rain for the desired time .. it was seen by other people , so do not suffer from hallucinations .. haha..)) still charged water so it was hot and she was taste like soda.. the crystals energizing, people were saying that they could not their hands to produce and that they somehow give power right.. even gave people information vhodil in a light trance ... I wasn't trying, it just happened .. during a conversation with a person.. well, a lot of things supper "paranormal" was in the experience , it's a long story , but something may scare the readers .. haha.. kidding .. :wink: .. then it so happened that I threw the whole thing and moved to Greece .. and here uzhe 3 years, you are doing nothing.. it is all around me have , see , feel .. but as you say , don't use their capabilities , and therefore a headache when I read your page .. there is a cleansing.. OOO.. now in the region of the solar plexus, the sensation of pressure locks.. breath.. hot.. pressure on the ears and neck .. in fact you have incredibly strong page !!!
when I hand over the front room or bracelet hold very strong energy flow feel ..
while going to use your miracle devices..
Thanks, I'll try to paint the stabilizer and to make the bracelet yet .. but I want now to take in hand , can you imagine what will happen to me .. :wiz
about simple people don't exist - of course they all have as they say a sixth sense .. but talents are different .. such as the talent to draw and sing .. someone nice draws, someone sings.. and with spiritual talents .. or ekstrasensornykh, paranormal , as you have called .. ? I English is easier in this respect, the terminology .. clear-seeing, clear-hearing, clear-feeling, psychic, channeling, TRANS-canaling well, etc.
I do not use it and just don't know.. or as in my case overlooked .. yet .. I understand that hard so I found you .. it's time .. and it's uzhe another level.. !!! :wiz
thanks again for the reply ..
tomorrow I will try to make homemade and report if it works ..
:aa<
