СК1М
Re: СК1М
Post by Михаил_ » Fri Sep 23, 2011 19:31
Um.... stop.... there's something overly confused :)
1. СК1м you can just TAKE back and get money, even if it is a reasonable return, then it may slightly change Your status as buyer in the future, but nevertheless, it's always a possibility.
2. Radius СК1М is not limited. I there did not read carefully in the text above, but understand that MAG.there is illustrated the interaction between the device operator in the diagram, and in it sphere is not the distance, and communication. Ie the instrument is primarily related to the operator (at any distance) and then it is associated with goals that are not directly related to the tasks of the operator life. Ie tranlate something to someone is easy. but it is necessary to give the mental command (and all in the simplest case).
3. SK can be used with radionically in any way. Namely, independently (to put the same task to ensure they choose different paths but in General, it may be more efficient). You can connect the SK to the output рад2400 audio cable minijack-minijack (all wisdom), or you can put them side by side, and in the UK to run the track for the gain of the third-party device mentioned somewhere above. Both instruments (IC And Rad) can be in different places, ANY of them can give the mental command to the collaboration scheme and that will be enough to join them. All. All the complexity.
4.
Stream anything with a SC on someone - put it is something in the subject table, and give the task to translate there and then.
Also all.
SK extremely flexible system configurable by the operator.
The only thing - it is designed by default (in the main mode, i.e. the corrector) to mitigate the interaction, and not to breaking on the break. A simple example - if You can see the swamp and prickly bushes, and around them is a good way, then which way will be faster and more efficient to pass?
If you just "break" energy for the direct vector can be in the swamp to get there, and when you try to get out of the thorns.
In General, SC, like Happy mental is fully configurable.
By the way, I do not understand the special meaning output socket customer on radionica - there should be intuitive to put. In addition, Radionics, and SK operate in the off state, when direct mental programmirovanii. They are just more .... straightforward.<
Has thanked: 24 times
Been thanked: 142 times
Re: СК1М
Post by Маг.нет » Fri Sep 23, 2011 20:15
It is simply a question of translating "effect of cartridge" to the Modulator arose, so I answered in the nuances of the way to get the effect. Sharing cartridge SK 1M well, not quite regular. In the cartridge "protection" status (which can cause the effect, not the effect of the "sewn up") Operator and not a program for IC 1M using it with the Modulator, we project that state automatically (TO work and the principle of the Modulator), passing "configuration to the condition" using SK 1M, it reaches the Operator, but does not integrate automatically in the cocoon "default", works as a link and not as a program, i.e. the link for greater effect it is desirable to start (to take state).
Sincerely, MAG.no
Re: СК1М
Post by Маг.нет » Fri Sep 23, 2011 20:40
Шломо wrote:СК1М just might function as information transfer from audio to the operator,but as it turns out from your explanation that the field of action СК1М operator limited,based on my understanding of the instructions for СК1М that it can be used to strengthen the capacity of the RAD,in the form of an external amplifying module connected to the output for Target or Trend,but I do not understand the meaning of the device the capacity of which I want to reinforce is connected to the output,and the device is in the form of amplifier to the input.
Interinos, stream energy, stream status, system correction of reality, according to the concept of IC 1M is not the same and requires a little different approach (not including mental control, but if you understand its principle, such issues do not arise).
Usually, to enhance the source, such as player, amp just connects its output to its input. With regards to SC 1M and Radionics, this is not exactly input-output, it is rather bilateral "information connect" wire, join a system, but the connection can be without it.
Шломо wrote:I Wonder if buying a modern car you in addition to driving skills still had to know how he arranged the engine,the motor,computer equipment, etc., etc.
In the service book Mercedes limited temperature regime of its normal operations, minus 23 degrees, BUT operate at lower temperatures, with the fulfillment of additional conditions, described by the list of required maintenance procedures.
As for SK 1M, full-time, it is as described, in my opinion easy to understand and does not require additional skills, BUT you can get more.......
Sincerely, MAG.no
Шломо
Been thanked: 3 times
Re: СК1М
Post by Шломо » Sat Sep 24, 2011 0:13
Михаил_ wrote:1. СК1м you can just TAKE back and get money, even if it is a reasonable return, then it may slightly change Your status as buyer in the future, but nevertheless, it's always a possibility.
the device is interesting to me and the instructions are all clear,just wanted to clarify whether I understood everything,so as not to make mistakes(the same can I as a buyer to ask the experienced people and the manufacturer,respectively), and outlines how they can in the power of his intellect.
And in terms of the frequency of RAD can be a mode mismatch effects of the device with the task in the program Manifestftion,for example the program is installed on the Boost Energy
and frequency RAD suppose 22.0 Hz(Astral journey) or Boost-Memory c 50 Hz(reduction of brain rhythms)-so Bach and I fell asleep in front of the examiner,or Boost-Sexual-Performance c 523 Hz(fear and panic)-perhaps the girl did not understand-sorry that is not in the relevant branch started the topic,if not difficult move.
Шломо
Re: СК1М
Post by Шломо » Sat Sep 24, 2011 0:20
Michael! I remember somewhere in this thread it seems like the MAG.no you have matched the idea of creating a remote control console to СК1М.You working on it? and how it approximately will look like? or I just heard the sound and don't know where he is? I ask questions to acquire,to practise and write about the results,not to divert you and the members of the forum and clutter up the thread.
Thank you.
Re: СК1М
Post by Михаил_ » Sat Sep 24, 2011 3:05
Remote remote to SK can work extremely effectively at
Шломо
Re: СК1М
Post by Шломо » Sat Sep 24, 2011 3:39
Михаил_ wrote:Remote remote IC can operate very efficiently at
Thank you,that answered my question.Something I because of his carelessness once again distracted,sorry,I will more carefully read the forum and topics products.By the way the first results СК1М-wanted to copy the file to СК1М,the CD player is now in active mode works through the RAD,but still wanted the night to include СК1М audio on cleaning the room from negative thought forms(like put it right) and suddenly remembered a long-forgotten me MP-3 player,and there is found the audio file, the original of which I accidentally deleted from a computer and unable to restore it,since it took half a year,it is clear СК1М helped.
Re: СК1М
Post by Михаил_ » Sat Sep 24, 2011 3:57
SK is really capable of some manifestations of autonomy in the framework of assistance as the program on which he works is a learning organism.
Re: СК1М
Post by Михаил_ » Sat Sep 24, 2011 3:58
By the way, one of the objectives that can actually be formulated for the UK to increase its capacity :) due to third-party resources.
Шломо
Re: СК1М
Post by Шломо » Sat Sep 24, 2011 21:21
Михаил_ wrote:by the Way, one of the objectives that can actually be formulated for the UK to increase its capacity :) due to third-party resources.
You mean to formulate key phrase or there is some adequate mandala?
Please tell me.
Шломо
Re: СК1М
Post by Шломо » Sat Sep 24, 2011 21:33
Михаил_ wrote:Stream anything from SK have put it is something in the subject table, and give the task to translate there and then.
Also all.
Michael,let's say I would like to broadcast using an audio file to СК1М regime capsule for your family,then I need to specify their names and his, and will that be enough? I wanted to clarify and operator(owner) to СК1М still I? or after the termination of the broadcast need to hold СК1М in hand with the idea that I am master?(interested in just such a moment whether, after these manipulations the family members mentally linked to СК1м?)
Саунд
Re: СК1М
Post by Саунд » Sun Sep 25, 2011 20:28
Not long ago I bought a few SK. My personal observations about language.
1. an indication of the time of realization of goals. When I set goals within the framework of any direction, for example, the group "health", picked up the language a different time frame. Here are some of them:
through ... months
through ... months and forever
within ... months
within ... months and forever
- forever
- other.
As far as I know, for such things in various practices or prayers use the expressions from now on and forever, forever and ever... Some tasks do not require time - for example the use of the phrase "most appropriate time". After all the revisions asked a specific time frame in months where you need.
2. Had the text to remove common words, such as "all", "peace"... If I could understand correctly, the device requires specificity in the words often use bindings to something - "my health"...
Spent a lot of time and effort to clarify wording, it seems sometimes even individual words play a big role. Tasks from 4-5 months, look at the results :)
Re: СК1М
Post by Маг.нет » Sun Sep 25, 2011 20:45
My observations:
1. IC 1M with a time frame is not very friendly, he was more like, such as: "...sooner or later, one way or another...", i.e. flexibility in the movement of the result space.
2. On the forum have repeatedly proposed a formulation of the intention to end the "ecological Supplement": "...the most favorable way for me and the World" and there is a reasonable explanation.
:) Greater impact play is not so much words as their meaning filled, sometimes you can just mentally formulate and drawing a "scratch" (drying) fix the thoughtform.
When the task list work will occur to each item individually, so it is best to consider the agreement ("the Swan, cancer and pike"), prioritize (if essential).
Sincerely, MAG.no
Саунд
Re: СК1М
Post by Саунд » Sun Sep 25, 2011 21:04
Маг.нет wrote:My observations:
1. IC 1M with a time frame is not very friendly, he was more like, such as: "...sooner or later, one way or another...", i.e. flexibility in the movement space.
1. I was referring to a specific task... that is a bunch of device-specific task. There is a problem in General, without time, there's clearly a number of months... But, this assumes the ability of the operator to properly evaluate where and what to specify...
2. here is an example. the wording begins "all my bodies..." was vague. Replaced the word"all" to specific types of bodies. "the space that surrounds me the World is harmonized in the best way". Removed the "World", probably the World's too big to harmonize with the instrument difficult, and without the word the World the phrase implies some kind of a small space around the operator, the optimal value of which he will determine himself to be a particular operator.
And what you wrote added to each device :)
Re: СК1М
Post by Маг.нет » Sun Sep 25, 2011 21:20
1. I just my observations have stated, try it, tell.... Everything happens in time....
2. Again, more influence have not so much words as their meaning (the idea).
The world can be global, and maybe others, it can be both a space and series of events and other features of interactions with the World, more important that letters are drawn, but what does this mean. Ie the office of mental device, and "notes" as one of the options of fixing thoughts for tasking device.
Sincerely, MAG.no
Re: СК1М
Post by Михаил_ » Sun Sep 25, 2011 22:22
Please tell me.
Articulate as anything (phrase, mental, team, etc). Special products for this. We assume that this is a reasonable protection against careless inexperienced operator.
Re: СК1М
Post by Михаил_ » Sun Sep 25, 2011 22:31
Also all.
Binding to the operator is always correctly determined by the device in fact, as practice shows, even before admission of the instrument to the operator. This example the operator does not change.
Capsule course can be extended to the family, but it works best for one person. Try it and compare.
For many the mental and commands, and do not have to clarify something. A name is usually enough. I also like to specify the email (it is in contrast to the name, definitely unique).
Device perfectly adapts to the real problem, not for the wording, but the problem is that the operator often contradictory formulated and does not understand, does this issue need clarification.
stom
Re: СК1М
Post by stom » Mon Sep 26, 2011 10:18
Hello. Question to the experts.Help to draw up a treatment plan.Female 73 years old diagnosis of stomach cancer 1stepeni . In the presence of her picture ,ск1м.RF console.the amplifier.RAD2400HD.isn-1.PLAYR.[ I myself am a doctor and her nephew]
Re: СК1М
Post by Маг.нет » Mon Sep 26, 2011 11:15
I'm not a doctor, so the Soviets will not undertake to give, but in such a case would work with probabilities, i.e. the redistribution of the natural energy of the body in normalizing processes, but does not broadcast energy to the patient. A list of normalizing processes You probably known as the doctor, for example priorities in the supply of natural life force of the body's healthy cells over the patient and so on, in General, the work not with the body, and the processes in it, you need to know the mechanics of the processes, as well as work with others processes (the World), the focus on health and so on, but it as an option and nothing more than speculation....
Sincerely, MAG.no
Re: СК1М
Post by Михаил_ » Mon Sep 26, 2011 12:45
You are absolutely right. Devices are not curative. They change something in the world. Onco when the flow of vital energy in General, to person may worsen the situation. So the main thing is avoid direct flow of energy and do not give up on other ways of exposure, more direct.
Now a lot of information is in the network.... if to speak about alternatives (I would pay attention to such things as MWO and ASD, but you know, advise this can not be only to Express their, so to say life observations).
In General, the work with probabilities it will be an indirect impact.
When using for example a homemade (at least on paper) of the stabilizer, you can put one anchor on the beneficial aspects for the body (along with the health program) and the second on the inhibition of tumor cells in all parts of the body (to stop them), but there is (to the stop) to put another anchor on which to pin the cause of their appearance, thereby to turn it off. And the causes can be different. Often a combination of both. Many, including some academics, say infectious-parasitic nature (depending on the shape and type of flow maybe different). And there is not clear, and in a percentage of cases. Official medicine pressure effects and not the cause. All difficult. When the body is in this state, and at the age of even a thin external impact is added to other ways should be carefully weighed and lightly tested. Since the shake is easy to hurt.
And definitely avoid the task of powering with glad. Dangerous as a possible growth stimulant all at once.
All above is my IMHO of course and cannot be taken as a guide to action, but as the theme in different information sources. Well, you know. In a public place, write a response.
stom
Re: СК1М
Post by stom » Mon Sep 26, 2011 13:32
Take a break .Comprehend.
Шломо
Re: СК1М
Post by Шломо » Tue Sep 27, 2011 4:08
Michael! and you could not tell whether it is possible to obtain the effect of both the Sri 1(table) using СК1М?
Шломо
Re: СК1М
Post by Шломо » Tue Sep 27, 2011 4:19
Шломо wrote:Michael! and you could not tell whether it is possible to obtain the effect of both the Sri 1(table) using СК1М?
yeah some dead-end I asked a question,it is easier to buy a Sri and not sweating,I am sorry that at once did not buy,now he's a bit more expensive
Шломо
Re: СК1М
Post by Шломо » Tue Sep 27, 2011 4:36
stom wrote:Hello. Question to the experts.Help to draw up a treatment plan.Female 73 years old diagnosis of stomach cancer 1stepeni . In the presence of her picture ,ск1м.RF console.the amplifier.RAD2400HD.isn-1.PLAYR.[ I myself am a doctor and her nephew]
maybe this audio for СК1М a little help:the structuring of water in the regime of water contributing to more rapid recovery
http://openmagic.org/sk1m/sk1water_iscelenie.mp3
structuring water mode "living water" - water with a harmonious structure, useful for the body.
http://openmagic.org/sk1m/sk1water.mp3
Шломо
Re: СК1М
Post by Шломо » Tue Sep 27, 2011 4:59
more audio for СК1М:4. Capsule http://openmagic.org/sk1m/sk1kapsula.mp3
http://openmagic.org/sk1m/sk1lfuture.mp3 - to reduce the negative probability away from her energy.
