Advice from Andrei Patrushev
Post by Андрей Патрушев » Tue Jul 28, 2009 21:08
Бона wrote:hi Andrea!
Sorry if I will repeat the question (so many posts, I do not read everything). The bottom line is this: I use the disks almost a year and a half. Love it! Need Your advice regarding the possibility of using disks from a man of 70 years who have had a stroke, a heart operation (all was happening at the same time). Now he was discharged, but there are consequences of stroke and surgical interventions, such as the difficulty of healing of the sternum, the neurological consequences of stroke and various kinds of neuralgia mechanical nature. Want to put his father to his feet. But not to hurt, of course. What would you recommend? Thanks in advance.
Sincerely, Natalia.
Hello, Natalia!
While perhaps better the 1st or 2nd track Star Wanderer, then (about a month) will be Healed...
Бона
Post by Бона » Wed Jul 29, 2009 2:09
Thank you!
Post by Guest » Wed Jul 29, 2009 6:05
Hi Andrew, you have not answered, I dare povotorit question:
are going to do the "Conductor", can't seem to formulate the correct setting, I work a lot with arrhythmia (premature beats), and don't actually know if sense to work with a purpose? How to formulate to get rid of this scourge? Will the discs? I have a "Healing", "Explorer" and "Massage of the brain" - with great difficulty got them, I live in America, you have to somehow get here to sell them. There is also a CD Jeffrey Thompson, I really never listened.
Want to buy InnerPulse but somewhere here on the forum, read the answer that a mind machine is contraindicated in arrhythmias? Thank you. Vadim.
ВадимВадим
Post by ВадимВадим » Wed Jul 29, 2009 6:07
My previous post, for some reason the system did not recognize me.
оуаакун
Post by оуаакун » Wed Jul 29, 2009 13:45
Vadimvon
I tried disc Healing. Any goals I set.
To Healing a few months listening to Jeffrey Thompson drive alpha Medican Systems.
Then Massage the Brain and the Conductor.
Post by Андрей Патрушев » Wed Jul 29, 2009 16:22
Anonymous wrote:hi Andrew, you have not answered, I dare povotorit question:
Zdravstvuyte.
Disks are delivered to any point of the Globe where the Express mail. :)
I think the better Healing with a Guide through the times to listen to, without any purpose. :)
Yes, mindmachine contraindicated in arrhythmias...
ВадимВадим
Post by ВадимВадим » Wed Jul 29, 2009 22:37
Andrew thanks for the reply! if Express Mail delivers drives to any place of the globe, I will try to enjoy the rest of your drives.
Thank you Awaken, I also have alpha Medican Systems and Theta systems Jeffrey Thompson...
Артемчик
Post by Артемчик » Thu Jul 30, 2009 6:30
Andrei Patrushev
I'd like to repeat my question about - is it possible to fully replace some of Your drives sessions MM Innerpulse?
And this proposal to You: since the questions are accumulated as you listen to those or other disks, and the time to browse the whole forum is not always enough, I like a practical man offered on a fee basis through mail to answer users ' questions.
Payment can be made through system "the Internet of money."
For example, 100 rubles per issue. I think the idea is worthwhile. :o
Post by Андрей Патрушев » Thu Jul 30, 2009 11:58
Артемчик wrote:Andrei Patrushev
Some sessions of my production trying to mimic some discs... :) but to completely replace is not possible (for technical reasons).
I always respond on the forum on the same issues :? So you can use it for free :wink:
ВадимВадим
Post by ВадимВадим » Fri Jul 31, 2009 14:09
Hello, I have probably drive the Explorer defective, in 45th minute stops and the player begins to jugati and grating, respectively, all calm and pleasant state of fading, a minute later, playback continues. The question is what is the point to continue the session in this situation? The disk is then still "jumps" a few times, and if CD playback is interrupted several times, how serious the impact this has on the quality of the "session"? I mean not only the Explorer but also Your other drives. Thanks in advance. Vadim.
Post by Андрей Патрушев » Fri Jul 31, 2009 18:01
ВадимВадим wrote:Hello, I have probably drive the Explorer defective, in 45th minute stops and the player begins to jugati and grating, respectively, all calm and pleasant state of fading, a minute later, playback continues. The question is what is the point to continue the session in this situation? The disk is then still "jumps" a few times, and if CD playback is interrupted several times, how serious the impact this has on the quality of the "session"? I mean not only the Explorer but also Your other drives. Thanks in advance. Vadim.
Hello.
It is always better to replace...
If possible, you can try to copy to the hard drive of the computer in WAV format (program EAC, Easy CD-DA Extractor) and rewrite to the disc). At least until the replacement goes, you can normally listen to...
ВадимВадим
Post by ВадимВадим » Tue Aug 04, 2009 6:19
Hello,
decided to listen to "Conductor" in music. center on the player (normal sony discman), the disc skips and stops, I wrote about it before. On muses center the disc plays without interruption, but very much audible hum, I suspect, from the electric motor cd drive? You have to increase the volume to "drown out" the noise, but then the volume level stnovitsya quite uncomfortable... the Question is, can hum to listen, will it affect the quality of the session?
Thank You, Vadim.
Post by Андрей Патрушев » Tue Aug 04, 2009 14:15
Thank You, Vadim.
You can listen to the hum. :)
Андрюшка
Post by Андрюшка » Wed Aug 05, 2009 22:05
Hello, Andrey.
In may purchased the entire set of disks, in July, attended by 12 times the disc "healing" and "Explorer", then there was a break in a week (not had the chance to listen to) it turns out now I have to start counting again.
And another question: reading the forum, came across the information that people with mental disorders it is better to wait with the wheels to cure their "ailments" and offer to consult a specialist of NLP. Can you recommend someone who can I contact? I live in Ekaterinburg.
Have the same problem: occasionally rolls complete apathy, do not want to do. At work, communication with colleagues is not very good, if not in the mood, can get nasty, and then worried about that, go to apologize, but still at heart remains a precipitate; "play on the nerves" not only from superiors, but also the people close to me, and this made it worse, i.e. according to the principle "to spite mom frostbitten ears". Became very lazy, nothing to do hunting or for others or for yourself. I understand that the problem is in me, but I just can't help myself, again because of this laziness; if so proceeds further, it will spoil relations with all, and I do not want.
If possible, advise in what direction I should go: to go to a psychologist or to attend a course of disk Explorer any installation, or both at once.
With respect, Andrey.
Post by Андрей Патрушев » Thu Aug 06, 2009 17:10
Андрюшка wrote:Oh, Hello, Andrew.
Yes, you have to start over... :?
In Yandex you can find nomerovsky party in Yekaterinburg... for Example, Grebnev Sergey Andreevich (was one of the originators :)), may be younger than who came on the forum ask. :)
Андрюшка
Post by Андрюшка » Thu Aug 06, 2009 21:45
Thanks for the reply, Andrew.
So the discs you can listen to. What pleases :)
Соловей
Post by Соловей » Thu Aug 06, 2009 23:23
Andrei
I have 18 to 21. Also full appatov, did not want to do. Developed in cycles, "I don't want to do this, I something else that I like" "I have already scored on you need, and what huchu already perehotelos" - "the Situation is blown because I'm not doing anything, and want that I was just left alone" - "Complete W... time washed off in imaginary worlds" - " adrenaline rush, run, pass, in an incredible effort all tighten; When all on edge, begins to look all the small, vanity, but the world is perceived not as an example brighter" - and repeat the cycle. What can help to lead almost a sport mode(when a lot of sleep, the body releases depressants and it only worsens the situation when not enough sleep - all annoying). To track down what your action starts the cycle of apathy(he may not be big, but he just turns on this program) and try my best not to vypolnyat. Zhelatelno of sment all obstinacy(work, home, town finally) - it would break sablani your behavior, and there is already possible to create others.
Good luck! I have already passed through his hell, I wish you to pass your as soon as possible.
Post by Андрей Патрушев » Fri Aug 07, 2009 18:12
Interestingly, one of the methods of dealing with depression is the forced insomnia...
Post by Dimas » Fri Aug 07, 2009 18:21
Андрей Патрушев wrote:Interestingly, one of the methods of dealing with depression is the forced insomnia...
Probably because then the person doing something, and he had no time to MOPE. And when running out of sleep somehow drawn to "motion" :?
Александ Анатольевич
Post by Александ Анатольевич » Mon Aug 10, 2009 6:45
Andrei Patrushev please tell me is it possible your disks to increase the intelligence in all directions as efficiently strong or weak increase the capacity of the intellect.Tell me how much to listen to audio.Do not tell you how else you can specifically increase the mental abilities of the brain other than the recordings.Or is it the drum that is, what kind of brain a person is born with and so die? or quite the opposite? :?
Post by Андрей Патрушев » Mon Aug 10, 2009 14:24
Alexander Anatolyevich
Intelligence can "zoom in" only the exercises: the tasks, playing chess, reading intelligent literature. :? Drives and mindmachine, unfortunately, only provide some of the prerequisites and conditions for self-development... :cry:
димка_566
Post by димка_566 » Tue Aug 11, 2009 19:51
Andrew, Hello!
The used conductor, has a positive effect.
Not long enjoyed. Now decided to recall
What would you recommend to resolve such issues.
Now need to completely clean the mental. To clean this life. And in the past, too.
I can't let go of a certain situation of life.
Though it was long overdue.
It is also necessary to develop creative abilities.
New disc from theta already ordered.
Post by Андрей Патрушев » Tue Aug 11, 2009 19:59
димка_566 wrote:Andrey, Hello!
Hello!
The idea of clean means that something is dirty. In relation to their brain - is, IMHO, there is a complete disrespect of myself and reducing to zero their personal experiences (what is gained)...
To develop creativity, we need to be creative...
димка_566
Post by димка_566 » Tue Aug 11, 2009 20:58
I understand. I just need to accept and assimilate past experience fully. Because are obsessions and appeals to the past, so something else not until he had written it... Not cleaning and healing of course of this and past lives...
Post by Андрей Патрушев » Wed Aug 12, 2009 15:46
димка_566 wrote:I understand. I just need to accept and assimilate past experience fully. Because are obsessions and appeals to the past, so something else not until he had written it... Not cleaning and healing of course of this and past lives...
They say that "the problem is a function of structure"... 8)
"Healing" is, of course, the exact word, and in particular the subconscious mind is necessary to restructure the personal experience to have the memories brought pain and suffering, and served as a reliable support for further progress, success and happiness in life... :?
