Stabilizer.
Been thanked: 10 times
Re: The Stabilizer.
Post by Мастер 108 » Wed Oct 15, 2014 20:21
Stretch is not required.
Аиша
Has thanked: 56 times
Been thanked: 14 times
Re: The Stabilizer.
Post by Аиша » Wed Oct 15, 2014 23:23
интересующийсябж wrote:People - if someone tried to be anchored in the buffer zone twilight then share the result please???
Put into a zone of chaos, the destruction of viruses, bacteria, fungi, parasites ( Michael wrote that in this area they burn faster). As the spring was at art diagnostics, we wrote each baddie. Ached, and depression all rolled. Even the cleansing of blocks and malware. At each stage I can say that the work goes on, while it may still make BJ. Take a panacea for a couple of days, and then put shake in the new. While the presence, or rather the absence of viruses and other has not been tested officially, so exactly, except my feelings,not talking.
интересующийсябж
Re: The Stabilizer.
Post by интересующийсябж » Fri Oct 17, 2014 9:53
Thanks, twilight zone ... after setting anchor in the calm, slowly turned into a "war". Though outwardly I am calm, but the thought failed, I wanted to grab a sword and reshape the world is the opposite of what I expected. Trait track "Star wanderer" helps in this situation.
For some reason when I put the anchor (still a process), the changes I notice on my wife, although anchors are connected with the brand with other businesses. For me it is as an indicator, here in 4 days after placing the anchors in the zone of twilight, my wife did that 1.5 years ago, she denied, and on this occasion there were conflicts, so suddenly and without any apparent reasons at dinner have agreed ...
Before the production of the stabilizer 2 better to remove the anchor from the first (2 days the eraser) or can you not do?
АлексейН
Has thanked: 20 times
Been thanked: 3 times
Re: The Stabilizer.
Post by АлексейН » Fri Oct 17, 2014 11:36
интересующийсябж wrote:my wife did that 1.5 years ago, she denied, and on this occasion there were conflicts, so suddenly and without any apparent reasons at dinner agreed
don't even want to ask what! :)
интересующийсябж
Re: The Stabilizer.
Post by интересующийсябж » Fri Oct 17, 2014 19:38
:) ... and with imagination all right. It's very simple: the wife, parents, parents-wife ... let there be peace on earth (it was the raznoglassiya generations)!
Андреас
Re: The Stabilizer.
Post by Андреас » Sat Oct 18, 2014 1:27
Put stickers on the order in the instructions. After a few hours decided to check correctness. Found that mandalas Homo zone glued upside down. Unstuck them and glued properly. Only then remembered about the order. The question of whether to work or to pull out everything and re-glue in the correct order?
интересующийсябж
Re: The Stabilizer.
Post by интересующийсябж » Sat Oct 18, 2014 3:16
... You have it this here, there was no need to pry anything. Try a pasted label on top of stick once again in the RIGHT order (NATO, heterosexual two sectors, two sectors Homo, two sectors Neutro). You will just have 2 layers of zones (one on another) and then the instructions ...
Re: The Stabilizer.
Post by Михаил_ » Sat Oct 18, 2014 9:04
Андреас wrote:Put stickers on the order in the instructions. After a few hours decided to check correctness. Found that mandalas Homo zone glued upside down. Unstuck them and glued properly. Only then remembered about the order. The question of whether to work or to pull out everything and re-glue in the correct order?
the order affects you and not him... will work - no difference.
Андреас
Re: The Stabilizer.
Post by Андреас » Sat Oct 18, 2014 23:18
There is a risk that the epoxy will eat through the paint on the mandalas. There was a desire to laminate them, and then pour. Is it possible to do so? Will the lamination pripyatstvovat structures that are tied to Mandal?
Re: The Stabilizer.
Post by Михаил_ » Sun Oct 19, 2014 5:26
it is possible, but it does not matter what it will do to the epoxy
Андреас
Re: The Stabilizer.
Post by Андреас » Tue Oct 21, 2014 14:02
Thanks for the replies. Filled. Freezes.
Андреас
Re: The Stabilizer.
Post by Андреас » Sun Oct 26, 2014 0:17
The question whether the Mandal top bottom? and if so, what is the location of Mandal is the most correct? And does it have some meaning?
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: The Stabilizer.
Post by Бисо » Sun Oct 26, 2014 0:47
Андреас wrote:the question whether the Mandal top bottom? and if so, what is the location of Mandal is the most correct? And does it have some meaning?
The Mandal no top and bottom.
I used the words "underlying" in the base oriented in the top to not lose orientation and the right to stick the rest of the mandala.
For me option 1 and 2 are correct, but not the top and bottom, but as simetriya. But this is purely subjective.
Андреас
Re: The Stabilizer.
Post by Андреас » Sun Oct 26, 2014 14:08
Clear. I actually think so too. Just decided just in case to clarify it. I've stood up for two days. Probably due to my above manipulations with the Homo area. In the car sat a battery. Day charged. Cigarette lighter not, because never on this car with such did not face. Then started, went on business. Stood on the railroad crossing for 2 hours. And just braked all things like that. But now everything seems normal. Just do a regulator from the positive effects observed. It seems that on the dark part of my consciousness was in the light and it became visible. Something like you describe. Or like the picture of the world straightened as the canvas and nailed the edges to the wall )). Thanks for the replies.
Бисо
Re: The Stabilizer.
Post by Бисо » Sun Oct 26, 2014 17:21
Hello,
I read that it's possible to mentally transfer ownership of the Stabilizer on the other person and it will work for him. And at this time, the Stabilizer will be physically with me.
If I want to get the Stabilizer back to use it again or transfer to a third person, can I do this or should the person had already been transferred to a mental Stabilizer to transfer ownership back to me?
Thank you in advance.
Re: The Stabilizer.
Post by Михаил_ » Mon Oct 27, 2014 1:16
Need to Get it back.
Петр.
Re: The Stabilizer.
Post by Петр. » Tue Nov 04, 2014 0:57
Aisha, (the destruction of viruses, bacteria, fungi, parasites) and (purification of the blocks and malware) were placed in the same area?
Бисо
Re: The Stabilizer.
Post by Бисо » Tue Nov 04, 2014 15:03
Hi all,
I decided to share an interesting incident that occurred with me.
I started to make a large reinforced Stabilizer and drew a plan of the location of the zones of the qualities on the tray. But stopped further work because I got advice from the forum, not to rush at first, and to do some paper Stabilizers.
Two days after the initial work on the Stabilizer and the adoption of the decision at first to make some paper, started having problems with my cell phone. Problems took place in the following: for the people were need to make several attempts to contact me and was not the guarantee that at the end of time. I also could not contact my family and relatives. Was necessary to make several attempts so I can hold a conversation and not have always achieved success. I had guests for a few days and they too could not contact me and I could not contact them. But they could communicate between them and with other members of my family without any problem.
During this time we have not changed place of residence were not changed cell devices, did not change the provider of cellular services. Everything was as before. We can say that the problems arose out of the blue.
After a few days I made two paper Stabilizers.
When I was ready with paper Stabilizers, I remembered that a few days before the start of work on usileno Stabilizer, I was slightly annoyed and I have a wish that no one bothered me on the cell phone.
When I remembered this and realized that the problem is in my consciously desire for peace and quiet, I formulated a clear desire that I would be available to all members of my family and for all the rest.
Already more than a week no problems with my cell phone and nobody complained that you couldn't reach me with the first attempt.
Michael talked about a similar case, but he was associated with СК1М ( if that is not confusing), when all communications have completely broken off ( cell phone and email ).
For me too is interesting and a good example, as in other cases described at the forum that started it all to the real physical production and completion of the Stabilizers.<
Аиша
Re: The Stabilizer.
Post by Аиша » Wed Nov 05, 2014 20:00
Петр. wrote:Aisha, (the destruction of viruses, bacteria, fungi, parasites) and (purification of the blocks and malware) were placed in the same area?
Yes, in one area. The explanation I wrote above.
интересующийсябж wrote:for some reason when I put the anchor (still a process), the changes I notice on my wife, although anchors are connected with the brand with other businesses
The same situation :shock:
Петрос
Has thanked: 45 times
Been thanked: 9 times
Re: The Stabilizer.
Post by Петрос » Wed Nov 05, 2014 21:37
Michael_ "shot" anchors translational stabilizer. And the connection is still :) . And tangible. Near two improvised with them to another connection. Michael, do I understand correctly that the stream leaves the trail for a long time and they can use it?
Аиша
Re: The Stabilizer.
Post by Аиша » Thu Nov 06, 2014 18:05
The cat climbs in the area where my paper stabilizer. Confused all the anchors. At first I didn't notice that she there got into the habit. Very unhappy that was expelled from this area, began vrednichat! The feeling that "mishandled Cossack" :shock: Alien roots? For all the BJ she reacts badly :)
Tell me whether its "footprint" from the presence of the stabilizer?
Бисо
Re: The Stabilizer.
Post by Бисо » Thu Nov 06, 2014 21:47
Aisha I think there is no trace left. Are you the owner of the Stabilizer and the cat has nothing to do.
To keep the Stabilizer somewhere inaccessible to humans and animals a place.
Аиша
Re: The Stabilizer.
Post by Аиша » Thu Nov 06, 2014 22:07
Thank You, Beso! Such a caveat about the trail do not know. And the cat at night to climb))) Now the place is barricaded flower pots. 8)
Бисо
Re: The Stabilizer.
Post by Бисо » Fri Nov 14, 2014 17:19
Hello,
I apologize if this has been answered or is it fundamentally means.
I wondered whether the tray out of aluminium for the manufacture of the Stabilizer?
I got a few with a very suitable size and almost free.
If suitable for the manufacture of the Stabilizer if there is a difference in comparison with the tray of steel?
Zarenee thank.
Re: The Stabilizer.
Post by Михаил_ » Fri Nov 14, 2014 22:29
will do.... Yes there is a difference, but it is not clear how to articulate it....
I usually recommend the steel is more correct for a typical scheme.
I use the aluminum version for very large SK (there is a huge basin :) ) but there is another technology for manufacturing...
