The Program Of Andrey Patrushev Raduga
Райдер
Re: The Program Of Andrey Patrushev Raduga
Post by Райдер » Tue Jan 08, 2013 1:31
Thank you :) alert released.
Райдер
Post by Райдер » Wed Jan 09, 2013 3:01
I forgot to write. When used the rainbow after the 3rd times got sick sinuses started horrible cold, when I started to let go of the throat began to ache. I certainly don't want to associate these events, but it was too weird I was a disease...
For sinus: (was once a genyantritis, frontal sinusitis) this time everything went easier than the commonly used chemicals for the treatment was not used (whereas usually had). About the throat generally are not particularly worried, as often happened, but the most unusual that I had no temperature at all (earlier in these troubles jumped to 38), so I could not help think that rainbow "voodoo" to me this condition. Then we still warm it was, so that the weather is also not inclined to blame.
александрхром
Post by александрхром » Wed Jan 09, 2013 3:54
as I can not run the program all the time error :
List index out of bounds (1085)
what could it be?
Post by Андрей Патрушев » Wed Jan 09, 2013 9:21
alexandrinum
Check out how the look of Your texts in Notepad.
Райдер
Post by Райдер » Mon Jan 14, 2013 23:41
What audio file it is best to reinforce the effect of the rainbow?
Post by Андрей Патрушев » Mon Jan 14, 2013 23:43
Ryder
Hypno-trance.
Райдер
Post by Райдер » Mon Jan 14, 2013 23:59
this out of theta meditation, and if the alpha still has not worked (not managed)?
Post by Андрей Патрушев » Tue Jan 15, 2013 0:01
Ryder
Then Music for hypnosis and self-Hypnosis.
Райдер
Post by Райдер » Tue Jan 15, 2013 0:29
Thank you :)
Another question, listened to a bit of this music and did not hear the third sound of the beats, in the story about masini said person hears a phantom "third" sound beating in the head, and for some reason I can't hear what is the reason?
Post by Андрей Патрушев » Tue Jan 15, 2013 0:32
Ryder
With the disguise of music. :?
Алия Султан
Post by Алия Султан » Tue Feb 05, 2013 11:43
DD (good day), Andrew! I would like to thank you for this super program: I do not charge for such great energy: for a half-day can in the house and window wash and all the house "progenerate" (sorry for the details). Highly-charged the program!!!
Then I wanted to change the settings when viewing a Rainbow-arc and to climb on the Internet, watch movies. Is it possible? if Yes, then how to change the settings? and could it interfere with the subconscious while viewing the Rainbow arc?
thanks in advance.
Post by Андрей Патрушев » Tue Feb 05, 2013 12:06
alia Sultan
This mode is useless, and these settings do not work (programmer not completed). :?
НОР
Post by НОР » Thu Feb 07, 2013 15:23
Good day to all! Downloaded the today programme. Did everything as in the instructions. Prescribed, has preserved the names, prescribed ways, all in text format. Doesn't open, it says File not found. Please help!
Post by Андрей Патрушев » Thu Feb 07, 2013 16:35
NOR
It is not necessary Nitsche manually register, :) just click on the three dots and browse to the file. You are surely at the residence made a mistake somewhere.
НОР
Post by НОР » Thu Feb 07, 2013 20:24
No, never made a mistake. Put the old version, put those same files works fine. Andrew, thank You very much, this is really the best program without a doubt.
Post by Андрей Патрушев » Thu Feb 07, 2013 20:27
NOR
Another option is the program folder not in the root directory of the drive.
It is also possible that You have not saved the names.
АП
Post by АП » Mon Mar 04, 2013 21:25
Hello. I can't run the program, rainbow. Displays the message "cannot determine the device type for the specified file name extension"
What could it be?
Post by Андрей Патрушев » Mon Mar 04, 2013 23:05
AP
UN-check all external players.
Нателла
Post by Нателла » Thu Mar 21, 2013 14:27
please tell me, downloaded, installed...
what to do next, where to register? the names entered and the error invalid filename
Post by Андрей Патрушев » Sat Mar 23, 2013 8:22
Natella
It is not necessary Nitsche manually register. For each file open (if you click on the three dots) vindovsky standard window in which you select the file You want.
Акела
Has thanked: 28 times
Been thanked: 64 times
Post by Акела » Tue Apr 09, 2013 11:11
Not realized as a. jpg image in the background to insert, and then all the working background Kagit?
But my idea of fun, how would the stereo images to use as background and good it will be the eyes relax, my mind clear and positive attitude. If not then have the movie mold!
Post by Андрей Патрушев » Tue Apr 09, 2013 11:35
Akela
While (I still do not lose hope to find a programmer :)) this can be done using Zep... :?
Run the Rainbow, removed a tick with "built-in" background (top right), then in the "background" (bottom) put a tick and write in the string, for example, the number 1, then minus Rainbow, find your favorite picture unfold on the screen, then fires a Rainbow. :?
Акела
Post by Акела » Tue Apr 09, 2013 11:39
And thank you!
СветланаС
Post by СветланаС » Tue May 21, 2013 23:49
Poskazhite, please. I have stars in the background scatter from the bottom of the screen instead of the middle. Although a year ago out of the middle of the screen.
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Wed May 22, 2013 2:05
In the file Raduga.ini is set to the offset from the center of the screen, he probably just wasn't in the program folder at startup - this can be corrected in the right margin or in the text editor (if the field Height=0, then the stars fly away from the center, more zero - offset down), and easier will probably be to download the program again.
