Tranlate - remote virtual artifact(test dir)
ПрактикОМ
Re: Tranlate - remote virtual artifact(test
Post by ПрактикОМ » Mon Oct 14, 2013 3:49
Today paid broadcast, at first nothing happened. And now, some hours later, again covered. Even stronger than the day before. The feeling that quite soon I will be fully restored, despite the fact that the current state is very far from ideal, all will be restored very easily, quickly and naturally. View.
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Mon Oct 14, 2013 5:25
Михаил_ wrote::) well, the fact is that else, especially with PC mode and 6... from 6th and 2.2 will be Oh.
Here misunderstood, in different ways to reproduce. "Oh" will be at:
PC+6 PC+2.2
PC+6 and 2.2+6
The latter option?
and
if paid semi-annual period 2,3,4 modes can be somewhere in the middle on a sample to make a month with additional 6th "oops" and then revert to your normal?
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Mon Oct 14, 2013 8:53
week 2 is not reported...as it all passes quietly enough, except for the fact that the company in which I work is recognized as a loss and decided to preserve...so the head as it is another busy, in fact all
resources going to throw a positive work...
for the actual broadcast - I understand - Michael I never switched, all sorts of situations like this work-
thanks to 3.0 are perceived as detached, calm. Head immediately begins to calculate the options, probabilities, pros cons and all that. Other colleagues nervous, bustling, constantly asking each other what they think to do.
Post by bofara » Mon Oct 14, 2013 9:33
Dimych, here:
Михаил_ wrote:Experiment (inhuman :) :) :) ) showed that sometimes the 6th mode is not the best thing, in particular when a person needs an active social contacts, and under 6m mode, as someone here wrote, well, just as a joke - "doctor, nobody notices me"..
IMHO the explanation is given about your situation, and as you can see from your example the effect applies not only to one person, but many around /by the way, I saw a similar, but the effect of 'benefit distribution' is superimposed on 'others', i.e. 'person hood means and all will be good', and people from the sample does not even know what BJ, i.e. conscious operation even it is not :) /. Of course the solution to cases of this kind Danno back there:
Михаил_ wrote:..the Effect is really manageable, but management requires the active attention of the operator (the deduction of the here and now). Keep in mind this aspect of it (to accept).
I certainly knew about it, but it is not always possible to guess that this may bring inconvenience to people.... however the brightness of the manifested effects strongly depends on the personal characteristics of the person.
If I understand correctly - this process is the reduction of enterprises, etc., oddly correct, to some extent, although people do not notice..
Two weeks after the beginning of the broadcast: you notice a pretty good gain effects of specchietti /visible and perceived by me/. The speed surprised.. but I'm not often used technically /ie using a computer/ the last time, although scheduled one 'project', but while 'geomancy' works /masab although the project is quite small, at least on the first look/ hands all do not reach to prepare photos for processing.<
Post by Михаил_ » Tue Oct 15, 2013 1:07
PC+6 PC+2.2
PC+6 and 2.2+6
The latter option?
and
1. I usually after 1 hour I can not remember what and to whom I wrote (otherwise my head will be buzzing with these memories :) and what for...)
I had to go back and reread the chain of posts... it meant following the man's PC (a very powerful product) and the 6th mode. - Oh.
And 2.2, I mentioned how the relatively "weak" product line and told him the 6th mode will give effects that will be Oh, if to use them.
Indeed, in 6m mode, the person receives special access "to peep" and information.... and very smartly to work with the past and the present and the future and not be tied to here and now and so much more... it's just the fear that the regime :)
Most still do not understand-have not experienced or do not have the ability to fry, to use.
2. Yes it is possible to make the inclusion of a modifier, for example for a month.
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Tue Oct 15, 2013 1:33
Михаил_ wrote:, and can be very possible to work with the past and the present and the future and not be tied to here and now and so much more... it's just the fear that the regime :)
So, I caught some very unknown aspects of my life from the past, put it on the shelf and periodically make attempts to disassemble
Post by Михаил_ » Tue Oct 15, 2013 1:43
1.about switches, Yes, nothing changed, catastrophically do not have time, very busy the last few weeks....
2. and the server with the test group is not controlled for a number of reasons remotely and I'm far from it (the rest are controlled remotely).
3. with 6m mode not all "that bad" in the sense of social relations, a review of the posts above (mine) is more likely associated with vysokovolnoy activity (socializing in large groups, etc.)
at least harm for negotiation and business among my immediate friends, using the stream from 6 were not detected (without any artificial control of attention), and use - a lot.
There probably talking about the fact that the crowd of strangers under 6кой might not notice relatively speaking, even if he will stand out like a red rag to a bull
ie if the person himself controls the process of their social relations, under 6кой everything will be in place, and if he is for example a street artist waits for him to approach passers-by will, under 6кой he will need to implement this process by the consciousness and fix it (it is a panacea for instance).
Петрос
Post by Петрос » Tue Oct 15, 2013 3:41
Михаил_ wrote:1.about switches, Yes, nothing changed, catastrophically do not have time, very busy the last few weeks....
Maybe it will be better. There is a feeling.
Post by bofara » Tue Oct 15, 2013 3:53
I think so too. The HF component is kept much more time, and then even to work and not to sleep... but there are still a lot of work in this direction.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Tue Oct 15, 2013 21:49
Hooked up one person:
modes 2 and 3 only 2.2
effects the same - to physically connect the Hoop on the neck...
Generally, 2.2 to 2 and 3
everything seems worn and 2.1(I actually slept on the map transfer) and panacea - and there are effects going...
Dream about all sorts of horror again...(Nenashev of the world... and long-dead relatives with radiant eyes...)
(on the field around - I take it as a light bulb - read about the bites of fish...)
I have:
Appeared effects that all look the part (I suspect that it's not 3.0 but how would a buffer zone.) the field began to feel the lunar light(or transmitted 2.2 respond to him)
What's next on yet not decided - or 6 add(2 and 3 modes), or the panacea connect.
Post by Михаил_ » Wed Oct 16, 2013 0:04
well... you can't get from physical products of some effects.... which are obtained from the transmission, but physical products are other advantages.
ПрактикОМ
Post by ПрактикОМ » Wed Oct 16, 2013 16:09
Last night knocked out sleeping. And in an unusual time for me, around 11 PM, usually 3 - 5 nights do not lie down. The first dream was a dream that I and a few members of the forum, just remember druid, others not, came apart somewhere outside the city in some great big mansion with a high solid fence. There we waited for the greatest Bank Michael. We went there, looked around and got acquainted. Then he gathered us in a circle at a Playground in the yard and we started discussing/learning something, and it all happened in a joking playful manner, remember that all jiving somehow over the druid, but he wasn't offended at all. By the way, the first time I had Michael in this body, they were in some other. Then all night dreamt of any adventure.
I slept until 8am, slept, were just fine, did HS, engaged in the Affairs. About the hour of the day again passed out, slept for about 3 hours. Again, been having some adventures. Woke up, went to the mail collection, look, and there is a message from MM that today the stream was included. Now I do not feel anything, as the usual-usual.
Here is such a report.
Post by Михаил_ » Wed Oct 16, 2013 16:17
well, actually I got it working on the day before the application for inclusion of mm forum post (don't normally do this, but here it was written that the decision is final and so I felt it and there was free time included)
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Wed Oct 16, 2013 16:44
I also have the first day of the connect broadcast had a dream in which Michael, in the mountains held a training seminar for members of the forum.. it was very realistic and detailed.. :)
Post by ФилиНН » Wed Oct 16, 2013 20:03
ПрактикОМ wrote:...About an hour again passed out, slept for about...
I remember You in another thread expressed confidence that soon will recover. Whether again picked up the wave...
Also in the afternoon NAP for half an hour and in some space(mental, that is, black, and has bright blue numbers-the labels that are not considered - do not read.) yelling in full force: I was born!(in the full sense of that it has recovered). Several times and trying all the louder.
Figase, a brazen claim... :) Twinjet only what under Col. dreams and with 3rd, time, the mode modifier. :)
ПрактикОМ
Post by ПрактикОМ » Wed Oct 16, 2013 21:01
ФилиНН wrote:Ouro in full force: I was born!(in the full sense of that it has recovered). Several times and trying all the louder.
Apparently an echo from the future))
ПрактикОМ
Post by ПрактикОМ » Wed Oct 16, 2013 21:02
Михаил_ wrote:well, actually I got it working on the day before the application for inclusion of mm forum post (don't normally do this, but here it was written that the decision is final and so I felt it and there was free time included)
Thank you!
Post by bofara » Mon Oct 21, 2013 15:51
Quite deeper /and from the inside, not only the visible 'glam-for-all' :) side/ prorabatyvayutsya stuff. I etim satisfied, rather satisfied and the speed with which it happens, even would add more speed /doing it mentally and, oddly enough - and to become the way I want, mean ukorenennosti but later.
By the way Simoron should help to accelerate this development, as I see it..
АКВО
Post by АКВО » Tue Oct 22, 2013 16:51
Michael, switching does not appear? :)
Post by Михаил_ » Tue Oct 22, 2013 17:39
in the next couple of days along with some updates mode and other surprises :) the test group will find still a lot of new "adventures" in the study of interesting broadcast....
СтАвР
Post by СтАвР » Tue Oct 22, 2013 17:47
mmm...we are waiting for new adventures and surprises
how interesting :)
Post by Михаил_ » Tue Oct 22, 2013 17:48
yeah... me too, apparently, because some new items I don't know exactly how it works for ordinary people.
The Chronicles of amber still reading this? guess what is missing to complete?
СтАвР
Post by СтАвР » Tue Oct 22, 2013 18:11
Михаил_ wrote:ordinary people.
the unusual means already checked :)
Михаил_ wrote:the Chronicles of amber still reading this? guess what is missing to complete?
I'm just friends with fry to Zelazny has not yet reached the :?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Tue Oct 22, 2013 18:16
I don't know :? The wheel is , BJ -Picardy. Tracery and Maps Dworkin is. Left is a Maze of Teleport - Type move through the Worlds)))) And of the other "tales "....you can ? For example Lukyanenko - to get and hide in the Cold, reminiscent of the principle is to get out of the crack. Or is it different? To always and with him-SAFE with the right))
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Tue Oct 22, 2013 18:17
The skill of walking between the two Reflections? :)
