About the parlor
Yeah, did not specify cold.
Re: About the parlor
If you work for yourself and receive a pittance, then maybe you have a strong evil eye and spoilage from someone. Need all this mess to clean up. I had the same thing. This woman blocked me all the flows, including cash.Жако wrote:Also this hypothesis is plausible, it is not always easy to understand what you really want.
What I can say is that are years that I'm working on my problems / desires without results.
I studied and practiced regarding.
I did the courses of Matrix Energetics (Richard Bartlett by).
I received the Reconnection (by Eric Pearl).
I practiced meditation.
I studied and practice TEV (by Roberto Zamperini).
I read all the books of Vadim Zeland and much more.
The results are very positive when I work on other peoplebut when I work on myself the results are always little or nothing
When for the first time I read about Svetlitsa devices, attracted me the word "normalize", this effect should be independent from the intentions/desires, so I thought maybe this is a good way.
From the years that I'm working on my problems / wishes with no results.
I studied and practiced Radionic
I did courses to Matrix Energetics (by Richard Bartlett).
I got Reconnection (by Eric Pearl).
I study and practice the TEV (by Roberto Zamperini).
I read all the books of Vadim Zeland more.
The results are very positive when I worked for other peoplebut when you work for yourself, the result is always little or nothing
The first time I read about devices Svetlitsa attracted me is the word "normalization" , This effect should be independent of intentions / desires, so I thought it might be a good way.
How long will the property chamber for structuring water?
From several hours to several days.Нездешний wrote:How long does the property chamber for structuring water?
It all depends on the quality of the structures of the environment. If the environment does not introduce distortion in the water structure, then this structure would remain for a long time. However, in our time to find such an environment quite difficult. The use of the Parlor Windows for rooms allows you to create a structurally homogeneous environment in which to comfortably reside and in which the structure of water will not be distorted.
