The Program Of Andrey Patrushev Raduga
Andrei Patrushev
Maybe autumn, but is not typical for me... the Strange thing is that fatigue occurs as confusedly: two days were squeezed, today hearty! ) well let's see! )
And for the program again thank you so much! Works great!!!
Re: The Program Of Andrey Patrushev Raduga
So, finished work with the program and after a few days disappeared, the lack of energy! Very similar to what it is connected still with the program. However I still at this time Svetlitsa Super appeared so that the purity of the experiment are not met... ))
And what three Windows displaying the text? And do file:BSFF text in центр.txt?
Not three, but nine.Райдер wrote:And what the three Windows displaying the text?
It is not mandatory.Райдер wrote:And is required file:BSFF text in центр.txt
When working on 21 days of the scheme it is necessary to take the same affirmation the whole 21 days, or every day can be a new place?
Once I looked at affimation "I love and accept myself just as I am", after 10 minutes eye stuck together and as it sought to revokeservice and then again sought to return to its normal condition, is this normal?
As anyone - some one time is enough, others need three, and the third and the 21st is a little...Райдер wrote:When working on 21 days of the scheme it is necessary to take the same affirmation the whole 21 days, or every day can be a new place?
In this world everything is fine.Райдер wrote:'ve already looked at affimation "I love and accept myself just as I am", after 10 minutes eye stuck together and as it sought to revokeservice and then again sought to return to its normal condition, is this normal?
Ryder
You can not work.with one affirmation, and start immediately.a.list.
as I understand from discussions with the launch of several affirmations of the effectiveness of each will be equal to 100% divided by the number of affirmations, so the list is not run.
You not correctly understood. Read the discussion again, and the link to the faq on the program here somewhere were there are a lot of issues covered.Райдер wrote:as I understand from discussions with the launch of several affirmations of the effectiveness of each will be equal to 100% divided by the number of affirmations
Ryder
No, affirmations can work on the blocks and their efficiency does not become less. But if one and the same affirmation is to be found in various formulations, its effectiveness can even be improved.
Ie you the standard affinati at the same time with the same affinities from Sedona to work?Ярый wrote:Ryder
Ryder
Of course! Recomend to read articles about Andrei Patrushev affirmations and affirmatsii: http://www.mindmachine.ru/articles/affirmations.htm and http://www.mindmachine.ru/articles/afformations.htm
I personally worked with Rainbow, I had to improve one particular quality, I wrote affirmations in various formulations to improve the manifestation of this quality, then wrote the corresponding affirmatsii, and in the beginning was Sedona (standard text) for removing blocks and negative attitudes. Worked as the course in 15 days, 2 times a day for 15 minutes. I want to say that the program is VERY noticeable and elaboration of the blocks is also very good! So good Luck! )
indeed, your method is effective.
This method is not mine, and Andrei Patrushev, so all thanks to him!
my regards to Andrew.
Sensible program, I'm a bit synthesized a way of working with it and goes pretty well. It's certainly not for everybody but maybe someone will be useful, I have a card "Mirror of ISIS" the mirror cut to size card. Cardboard to make a kind of shell that the card can be clipped to the mirror. And display on the screen two sided tape, or like something neat with the wire to hook over the edge of the monitor, is too long.
In General, a mirror placed just above the Central sector, where one word is displayed so that it does not close the text. Well then as usual, held the attention of the entire screen, at speeds in the mind comes pleasant silence and do not even want to stop such contemplation. The most favorable state of mind for such self-programming!
I would also like to add that it is desirable to work with the program to use emotions as motivation for achievement is characterized by emotional upheaval, so to speak "plus-experience", it is necessary during the session to stimulate feelings of confidence, inspiration, etc., in its sole discretion. And of course the power of experiences the same need to measure, and instead of contemplation will fly on the "treadmill".
Today, once again rainbow has saved me from migraines.
Andrew, thank you!!!
Understand that offtopic, but still think properly to find out...
Today was looking through affirmations recorded on the disc A. Sviyash "My charisma" and saw the following phrase:
I can do anything!
I allow myself to be special and different from others.
I am free from the opinions of others.
Similar phrases in combination with psychoactive audio is not dangerous (a colony of strict regime, for example, or razrulivaniya bare ass in the city centre
I can do anything!
Ryder
Well, as they say, - who had studied...
Ie, moral principles do not change. How, then, do affirmations, if our internal approval and morality are on the same level in the subconscious?
Ryder
Yes, and work - flow, so to speak...
