I'M BUILDING A PYRAMID
Южанин
Re: I'm building a PYRAMID
Post by Южанин » Fri May 06, 2016 17:06
And what is this miracle? I understand. that IT grows somewhere in the top. Why no explanations?
Викторович
Post by Викторович » Sat May 07, 2016 12:00
астарка
Post by астарка » Tue May 24, 2016 21:37
Верден
Post by Верден » Wed Jun 01, 2016 11:28
Hello
Found the Indian website with the pyramids. Pyramids heaped in one several small
Consider two options
1. with copper based http://acupressureindia.com/productdeta ... oductid=51
2. without it http://acupressureindia.com/productdeta ... oductid=91
I think you put them like this slide http://piramidki.com/nep-14m-i-nep-5m to heighten the effect
I read somewhere that the copper in the pyramid is harmful to health. So?
whether to wrap it in foil, since the plastic good enough?
Южанин
Post by Южанин » Wed Jun 01, 2016 17:59
ASTARO. what kind of magnetometry and what it measures.I have one device. is called the indicator of the electromagnetic field, but it shows nothing.And does the pyramid creates a magnetic field? I'm really not arguing, as I don't know, but I doubt much.
Разгуляй
Post by Разгуляй » Wed Jun 01, 2016 23:39
About measurements of the pyramid field. There is such a good appliance is called the meter of the electromagnetic field. It is often used by ufologists to identify anomalous zones. Want to do the same. Thanks for the video, it's a good idea to measure the decrease of the electromagnetic field near the current pyramid. Cheap Chinese devices only otnoshenie, but it's enough for everybody. The devices show numbers in units of "Gauss" or "Tesla".
Хорошо
Has thanked: 24 times
Been thanked: 19 times
Post by Хорошо » Thu Jun 02, 2016 7:24
for Android there is a EMF detector
Южанин
Post by Южанин » Thu Jun 02, 2016 13:37
RAZGULAY, and the name of this device.I have an indicator of the strength of the electromagnetic field PULSE, but in the pyramid and next to it I found nothing, perhaps not yet learned how to work with him.Although the manual is a paragraph-unit of magnetic field microtesla.Interested and approximately how much are these devices?
Разгуляй
Post by Разгуляй » Thu Jun 02, 2016 13:54
Южанин wrote:RAZGULAY, and the name of this device.I have an indicator of the strength of the electromagnetic field PULSE, but in the pyramid and next to it I found nothing, perhaps not yet learned how to work with him.Although the manual is a paragraph-unit of magnetic field microtesla.Interested and approximately how much are these devices?
And near the El.devices something shows?
Южанин
Post by Южанин » Fri Jun 03, 2016 16:20
RAZGULAY, right near the devices shows and gives the sound signal, the electric field above the norm, if exceeds. But the magnetic field still can't nothing shows.
Разгуляй
Post by Разгуляй » Fri Jun 03, 2016 22:50
Южанин wrote:and I Wonder approximately how much are these devices?
1. http://ru.aliexpress.com/item/Electroma ... 77481.html
2. http://ru.aliexpress.com/item/Electroma ... 60732.html
The second is preferable.
Нездешний
Been thanked: 7 times
Post by Нездешний » Sun Jun 05, 2016 12:06
All good day and good mood. Don't prompt where did the author of the theme? Thank you.
Разгуляй
Post by Разгуляй » Sun Jun 05, 2016 13:56
Нездешний wrote:All good day and good mood. Don't prompt where did the author of the theme? Thank you.
I have sent you PM his contact details.
Нездешний
Post by Нездешний » Sun Jun 05, 2016 14:50
Thank you. Can you tell me what the experience is better? Room pyramid of Cheops or Perepelkinoy? Thank you.
Разгуляй
Post by Разгуляй » Mon Jun 06, 2016 2:08
Нездешний wrote:Thank you. Can you tell me what the experience is better? Room pyramid of Cheops or Perepelkinoy? Thank you.
Personally, I only for classical (Egyptian) sizes.
Нездешний
Post by Нездешний » Mon Jun 06, 2016 2:35
And what is the size of Cheops is preferable? What is better to do? plus the question if for example to do something more than 2-3 mm thick, whether it is necessary to consider and plan for some of the triangles and the base is smaller on the n-tion number of mm? Do I need to trim the top, if so how much? Needless to polyroot (inside or outside)? Where is it best to have and where better not to have? At what altitude? Whether it is necessary to Orient to the North? Is it possible to keep it standing somewhere in the room? Is it possible to move it to another apartment? If you operate on the affected area how long to keep? How long to keep the water in it and at what altitude, the volume of water important? What else should pay attention? Thank you.and
Разгуляй
Post by Разгуляй » Mon Jun 06, 2016 10:30
Нездешний wrote:And what is the size of Cheops is preferable?
About the size, I liked the article "the benefits Of coincidences". Go to the TRANS-portal "VAITMAR". There is a section "the Egyptian pyramids". It contains links to the best articles/sites on the topic. There you will find answers to many questions.
Reference: http://вайтмара.рф
Нездешний
Post by Нездешний » Mon Jun 06, 2016 12:22
And on his own feeling and practice that tell me? Thank you
Нездешний
Post by Нездешний » Mon Jun 06, 2016 19:59
No one made the pyramids? Thank you.
Разгуляй
Post by Разгуляй » Mon Jun 06, 2016 21:56
Нездешний wrote:And on his own feeling and practice that tell me? Thank you
My limited experience covered in the messages above. Maybe you'll delight us with some fresh solution?
Нездешний
Post by Нездешний » Tue Jun 07, 2016 9:32
Good morning, everyone. can and will please. just a lot of information and it is sometimes contradictory. and I would like to hear people who live have experience. Thank you.
Южанин
Post by Южанин » Wed Jun 08, 2016 11:08
A STRANGER, the same information about the pyramids just yet. Each brings his version and what is the pyramid to better understand impossible. You just have to decide what kind of pyramid do you prefer them to do.I personally have long ago started the pyramids now switched to pointed. To me they are more suitable . In the room they take up less space, they are convenient.On the street gathered more pointed, too. From experience I can say that they all work if observed parameters. So the choice is yours.
РамД
Post by РамД » Sat Jun 25, 2016 2:57
Южанин wrote:Horror as interesting.If she still does. And I'm in the garden so much polycarbonate spent.Well, somebody prove scientifically. in the experiments, clairvoyance, etc. that the lining is not needed, I'm in the garden until the clouds build.
Rezultaty have to use- "a liver biopsy showed (cirrhosis)"
Meditation in the pyramid
Recent analysis showed that cirrhosis no!
There are only F2-F3, to say that the credit pyramid for meditation are not entitled, as clinical trials have not been conducted.
my pyramid collapsible, which gives the opportunity to take her and the sea and the forest.
unfortunately I can't put the picture.
Разгуляй
Post by Разгуляй » Sat Jun 25, 2016 3:06
РамД wrote:unfortunately I can't put the picture.
Try to place here: http://ipic.su/
РамД
Post by РамД » Sat Jun 25, 2016 3:24
[imghttps://scontent-bru2-1.xx.fbcdn.net/t31.0-8/13458528_1319558084740778_3520275154951174550_o.jpg][/img]
