1. The period of adaptation.
Has thanked: 31 times
Been thanked: 129 times
Re: 1. The period of adaptation.
Post by к-13 » Sat Aug 26, 2017 0:14
I have no New, but if there is a session on "Alpha for beginners", the period of adaptation is built on it (if not forgotten for 6 years, about the copied graph of the frequency from the time of this session from a set of sessions for fotosnimki machines in the program 7 mindExplorer SW that this forum is laid out). In principle, you can use any session with a pure alpha (without theta, Delta, and other less mentioned bands, only a beta at the beginning and end does not interfere), as in the description of the workshop and indicated in plain text.
Нездешний
Been thanked: 7 times
Post by Нездешний » Sat Aug 26, 2017 7:03
If this type of ( pure alpha) match 4 session of r
This is enough for a change?
thank you
Post by к-13 » Sat Aug 26, 2017 10:12
Нездешний wrote:If this type of ( pure alpha) match 4 session of r
It only takes one.
Нездешний
Post by Нездешний » Sat Aug 26, 2017 11:05
You just wrote that it is necessary different to the brain is not used to one
Post by к-13 » Sat Aug 26, 2017 11:50
unearthlyand I wrote that months silvotti the same file with a thud desired frequency and listen to all of them normally. I tried to help the participants to create the ideal conditions for the development of the program, everything else depends on the participants themselves.
CD Andrei Vadimovich also listen to the courses. One. Several times for 21 days.
Different files only for the fact that the party was not formed associations with specific sounds, then worked all session and audio files and not only this or similar. If You decide to work only with MM, then for You there is no difference - where all the files are similar.
Нездешний
Post by Нездешний » Sat Aug 26, 2017 14:03
Thank you for your answer
No, not just with mm. it is Desirable to re-approach.
Please advice.
Thank you
Post by к-13 » Sat Aug 26, 2017 14:48
Нездешний wrote:Ask for advice.
viewtopic.php?f=47&t=5386
Нездешний
Post by Нездешний » Sat Aug 26, 2017 17:46
Points in Your file will work?
thank you
Post by к-13 » Sat Aug 26, 2017 18:01
Are you sure you read the description?
Нездешний
Post by Нездешний » Sun Aug 27, 2017 11:01
Good morning
I think yesterday morning and this morning listened to alabugin with mm ( where the net alpha) for 15 minutes. Is it possible to start listening to the course or to wait a week?
In order to have sound and light, enough to connect the phone to mm mode Aus, or should I upload like that in it through the computer
Thank you
Post by к-13 » Sun Aug 27, 2017 12:09
unearthlycan only her to hear, most likely this is the same session. In Novo mp3 is not written, only AuS.
Нездешний
Post by Нездешний » Thu Aug 31, 2017 9:08
Using AuS is the only sound as it should be?
That is Nowe as not to run points?
Thank you
Post by к-13 » Thu Aug 31, 2017 11:04
Нездешний wrote:Using AuS is the only sound as it should be?
Thank you
All previous participants with New light was.
Нездешний
Post by Нездешний » Thu Aug 31, 2017 23:20
Using that signal, it does not matter? I served with the smartphone
Post by к-13 » Thu Aug 31, 2017 23:38
unearthlyfrequency control key audiostrobe-decoder - 19200 Hz. Most devices output the output is 20-20000 Hz with some degree of attenuation at the edges of the graph the frequency response. Perhaps You have to overcome the upper limit frequency lower (I have one very high quality player with the release of 80-18000Гц, and he is very nice plays formats lossless music with good headphones on to listen to it much nicer than on other devices). Or attenuated at this altitude is too high. Try it at maximum volume to see. If flash does not appear, change the device, if appears, you can use the headphones with volume control to a comfortable level ears to pick up, feeding increased the volume on the device.
Нездешний
Post by Нездешний » Fri Sep 01, 2017 11:46
And earphones what? Plugs or large better?
Thank you
Александр А
Been thanked: 2 times
Post by Александр А » Fri Sep 01, 2017 11:54
Нездешний wrote:And what headphones? Plugs or large better?
I went to the store CSN (they can be directly through the database to look) and said,"I need headphones with adjustable volume, not the Bluetooth, in the area of 1000R". Quick look, found one suitable. Large, all ear, the cord is really 6m, but it is fixable.
Plus the plugs head to the side to turn. Big plus - they are points in addition fix: you can do so that points will be in front of the eyes hanging, not touching the nose.
P. S. a Little about the practice: realized that my glasses are a nuisance, though, and put on at least: my eyes hurt, constantly looking for a comfortable eye position (gaze direction). Without glasses, just with the player, the result is much better.
Post by к-13 » Fri Sep 01, 2017 11:59
Thank you
Absolutely no difference, just both ears worked :?
Suggest to choose those that are the most comfortable to You personally. I'm more plugs like.
Александр А wrote:realized that my glasses are a nuisance, though, and put on at least: my eyes hurt, constantly looking for a comfortable eye position (gaze direction). Without glasses, just with the player, the result is much better.
This is most likely due to too much computer work or constant fatigue of the eyes for a different reason. Or maybe You're just a rare breed auditory learners, for which the hearing is to obtain information about the outside world is more important than the view. With vision problems there?
Александр А
Post by Александр А » Fri Sep 01, 2017 12:11
к-13 wrote:this is most Likely due to too much computer work or constant fatigue of the eyes for a different reason. Or maybe You're just a rare breed auditory learners, for which the hearing is to obtain information about the outside world is more important than the view. With vision problems there?
My eyesight is the strange thing: I am a programmer for 20 years as. The vision unit (tested a month ago).
Auditory tendencies are not observed, it is necessary to examine this issue.
Post by к-13 » Fri Sep 01, 2017 12:24
Александр А wrote:I Have a eyesight strange thing: I am a programmer for 20 years as. The vision unit (tested a month ago).
Yes I also with the computer closely with the ' 97 (floppy caught, managed to communicate with MSDOS and command-line in Windows 3.1 to work) without vision problems.
Blurred vision is a protective reaction of the organism to aggressive external world. The less he sees the tired, frightened or negatively minded observer, the less reasons for anger, fear or negativity. If a person is all happy, the world is interesting to him and straining the eyes like a occupation, the reasons for the deterioration of view, there is - in fact there is the same muscles are working, if not run, then weaken themselves they have no reason.
Not worth it, we have first)))
Александр А
Post by Александр А » Fri Sep 01, 2017 12:39
к-13 wrote:Quote:
I do not understand? What's the first?
I've already checked. Two tests showed that I auditory. I was wondering why I hate it when people crack knuckles. And the love of the music instruments (of the house there is a guitar, ukulele, I garmoshka and electro drums) :roll:
And I'm a stutterer, a hundred pounds is something to do.
We will develop in this direction.
Нездешний
Post by Нездешний » Fri Sep 01, 2017 23:24
good evening
Bought headphones, earplugs (expensive(( )
They like the buttons, they never work at the exit from Nova, too bad.
Set poweramp. It earned a light. No one knows how to configure it?
Noticed that when, instead of the output audiotrack to put hi-res, the brightness right away is very large, on the basis of the wheel light right on the minimum bet. Who can knows what there settings better put, where it could cut back the frequency you want it or not?
Thank you
Post by к-13 » Sat Sep 02, 2017 0:45
Нездешний wrote:Buy headphones, earplugs (expensive(( )
Well, price is not always an indicator of quality :) .
they like the buttons, they never work at the exit from Nova, too bad.
I suspect that the buttons are push buttons digital volume control? Digital control is a packet - switched resistance through the switch, that is external power required (unlikely in the headphones-even the plugs and the battery is built in). Or mode control of the output ULF in the device is designed for these headphones (typically using a contact microphone, it is only in headsets, not headphones, there are 4 contact bands on the plug instead of three).
It seems to me, You slipped some garbage :?
In Nov no power on headphones or managed through them, the output of the amplifier.
Нездешний wrote:Set poweramp. It earned a light. No one knows how to configure it?
I hesitate to ask, but only the last slider you can't move that light work?
And again. And for sure all the "sound improvers" disconnected (there are all sorts of equalizers, Dolby suround, etc.)?
МаксимАлексеев
Post by МаксимАлексеев » Tue Nov 14, 2017 17:00
Good time of day .
Report : worked with MM in August for about 25 days in a row according to the instructions ( was 1-2) passes , failed to achieve the relaxation effect later began to fall and I took a break in a month . In November continued and finally got the required result is deep relaxation and a certain inability to control the flow of thoughts .
Think you're ready to move on to the next phase of the program.
Post by к-13 » Tue Nov 14, 2017 20:07
МаксимАлексеев wrote:Good day .
Good))) Sending files.
