Stabilizer.
Has thanked: 112 times
Been thanked: 71 times
Re: The Stabilizer.
Post by АндрейКо » Fri Apr 04, 2014 0:28
Хаст wrote: Or maybe better just to describe the process it to stop?
The simpler the better/more reliable.(did so - works!)
АМарта
Has thanked: 2 times
Been thanked: 2 times
Re: The Stabilizer.
Post by АМарта » Fri Apr 04, 2014 21:27
SW.Michael,I have a question for the manufacture of the Stabilizer:1.is it possible to amplify the power of print "stabilizer base" maximum(dish)diameter?2.How many layers of prints is allowed to do(again, to gain power)?
Re: The Stabilizer.
Post by Михаил_ » Fri Apr 04, 2014 22:40
this is all you need to do.
АМарта
Re: The Stabilizer.
Post by АМарта » Fri Apr 04, 2014 22:45
Michael,thanks for the reply.
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Re: The Stabilizer.
Post by МерКаБа » Sat Apr 19, 2014 1:14
Michael_tell me, please, what area is better to put the anchor on the son (1.5 years old). Constantly hits his head. Today only three of the fall wiped the blood chin, broken nose and bump, actually. And so almost every day. Not already know what to do with his wife.
Thank you.
Re: The Stabilizer.
Post by Михаил_ » Sun Apr 20, 2014 14:03
can slow down a little ? .... generally worth a little poeksperimentirovat or "release arm" on odesanya
АМарта
Re: The Stabilizer.
Post by АМарта » Wed Apr 23, 2014 15:24
SW.Michael,what part of Druze is better to glue 2.0-1копия.?
Re: The Stabilizer.
Post by Михаил_ » Thu Apr 24, 2014 1:15
from the bottom obviously :)
АМарта
Re: The Stabilizer.
Post by АМарта » Thu Apr 24, 2014 10:48
Thank you! Such a serious device had to be safe ! :)
ЕВгений СПб
Re: The Stabilizer.
Post by ЕВгений СПб » Mon Apr 28, 2014 0:33
Michael, please tell me how best to proceed. In the process of curing compound wax floated to the surface and flowed at the surface along the border of law sector Homo. Question:
1. Is it possible to cover the wax with your name with a thin layer of compound.
2. How to locate the top sticker border the law:
and. Strictly above the lower, then the wax will be in sector Homo.
b. Or you can over the wax, then the sector Homo reduced.
Re: The Stabilizer.
Post by Михаил_ » Mon Apr 28, 2014 6:59
1. possible but not necessary.
2. of course strictly on the bottom! wax is not a hindrance to anyone
ЕВгений СПб
Re: The Stabilizer.
Post by ЕВгений СПб » Mon Apr 28, 2014 15:49
Thank you for your answer.
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Fri May 30, 2014 0:05
Good evening all!
Made on Sunday her first Stabilizer for the start drew on paper.
Then I was lucky to buy my grandmother at a flea market a plate from the microwave for a hundred rubles, which I cleaned from unwanted energies and took over the base frame of the device.
After stuck to the bottom of your paper Stabilizer mandala printed with all the mandalas, which were made of Bopara and posted, and then this two-stub stuck under the bottom of the plate at the bottom.
And pasted on top of another the same mandala.
Obtain a layer of the mandala and my stab on the paper below the bottom and the top at the bottom is pasted directly on top of the mandala stab my paper and glued mandalas printed from the same option, but only on the A3 and more and more clearly visible, and on top put another paper with the borders, as it was for stab, just printed out and looked around..
And when pasted NATO in the center of the mandala printed, accidentally pushed the thumb remained in the center of my thumbprint on top of NATO very pronounced, but still, the mandala is not erased.
Even on top plan to stick more of Mandal on the border and put Druse amethyst-charged, and then pour a layer of epoxy or liquid glass.
Amethyst Druze already bought, very good.
But until I read more about Stabilizer, and it is still in process, because I want to do it right and slowly, to get a good model.
As if to add to it right?
Thank You very much dear Michael for the good advice and this great opportunity!
With respect and great recognition, Marat :o
I will write about further work on the results further.
Still weak to understand the operation of the Stabilizer and the technician of management, I want to understand and operatorsthe better.
Now just put yourself in the sector NATO, Heterosexual, neitro and connected relationships..
Watched video Pak Jae Woo, very informative and wonderful, just that much was clear.
Here is a link to the video: http://yandex.ru/video/search?text=%D0% ... gW-Tq1Ts3M
Though the sound quality is poor, but also by the fact that there is just a wonderful material.
Also, found a wonderful shop where you can buy different stones, particularly the amethyst: http://kamnevedy.ru/category/ametist/
However to me the World of good - I managed to buy a nice stone for a hundred rubles, another place. :)
Again with respect!<
Re: The Stabilizer.
Post by bofara » Fri May 30, 2014 0:17
Марат Г. wrote:After stuck to the bottom of your paper Stabilizer mandala printed with all the mandalas, which were made of Bopara and posted, and then this two-stub stuck under the bottom of the plate at the bottom.
Remember Michael pointed out that it is better on top of these images to write the appropriate matrix, if you print "all ready" immediately.
p. S. I must warn You that I do not enjoy BJ for several months, engaged with some of the strangers things, so those things, like Stabilizer for printing, like AMV-light-light a piece of paper, etc./, who have posted before both here and on OM it is better to do yourself.. a Lot of times some warned about me - I'm not going to challenge and defend, just have it in view..
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Fri May 30, 2014 0:19
Though Michael warned from getting experience in certain areas, but right now I just need additionally to the properties of the Heterosexual, so set course with caution and monitor changes.
Can somebody podkorrektirovatj like it was the right thing to do?
In the Heterosexual sector and Neutro I set myself with a target in Heterosexual to improve your personal life, and in Neutro to improve their financial position with the appropriate intentions.
There is some spaciousness in consciousness, but nevertheless, it is still interesting and useful is manifested in the expansion of consciousness, and how would you add something new, not yet exactly figured out..
Can you give any helpful advice on this?
Thank you in advance, respect and recognition, Marat
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Fri May 30, 2014 0:25
Dear Bopara, I think You have much more experience than me and I guess You got it much better educated and more correct than I would do myself at the moment.
So I gratefully used Your work.
With respect and gratitude, Marat
Алега
Been thanked: 3 times
Re: The Stabilizer.
Post by Алега » Fri May 30, 2014 1:01
Marat G. ,be confident in your abilities/skills and you will have happiness.Better personal experience for you nobody will tell.Experiment and don't be afraid to make a mistake.Everything comes with experience.
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Fri May 30, 2014 1:38
Thanks Alak!
Be sure to take Your words note!
Sincerely yours, Marat
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Sat May 31, 2014 3:20
Good Night!
Made as indicated dear Michael,- on the printed mandala is written on top of the appropriate matrix.
So it turned out even better, and most importantly, where the stronger you can feel the energy of my model.
Thank You very much, and also thank Michael himself for the possibility of it all!
Re: The Stabilizer.
Post by bofara » Sat May 31, 2014 10:24
Марат Г. wrote:where the stronger you can feel the energy of my model.
Writing matrices on top of the printed integral Stabilizer is a little tougher, sings and probably perceived You stronger.. and anchor to make contact shootmenow matrix on paper or cardboard.. it is a working thing, and for some who are not with perceptions - it is easier to feel the work your Stabilizer..
Or if we use the example Avtomobilny: "you Can go from point a to point B on foot, but you can on the car" - the Stabilizer /matrix/ - can be considered a training machine, and already the 'older version' of a luxury brand.
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Sat May 31, 2014 13:49
Bofara, thank You for the information!
Well, I'm still learning)
the night finished all of the work and placed in the center Druse amethyst.
Left gain and shading, are all trying to do the description, wrote dear Michael.
With respect Marat
АМарта
Re: The Stabilizer.
Post by АМарта » Sat May 31, 2014 15:45
SW.Bofara,and you can link to the matrix.Thank You in advance.
Re: The Stabilizer.
Post by bofara » Sun Jun 01, 2014 2:08
Ангел wrote:a reference to the matrix
Herein PDF-the cal files..
Re: The Stabilizer.
Post by bofara » Sun Jun 01, 2014 2:36
Марат Г. wrote:Michael warned against gaining experience in some areas
By the way, Mikhail warned and satanisti during the manufacture of the Stabilizer, and as I understood from Your posts above - You made some wrong steps..
Better to do ispolnyaya instructions given by Michael..
And what I wrote above can be read and here:
Михаил_ wrote:1. when manually building the field of stabilizer and bonding of its components, runs a specific initiating process. When you print a paper, not so much. But will work anyway. Just more efficient to glue (not that there are a lot of elements). You and another. Can be printed box to put on top of stickers for their letter matrix at a time, this will also trigger the initialization of the fields - something like ripples on water, to acquire the system operating equilibrium...
I would say:
Михаил_ wrote:..to acquire the system operating equilibrium...
If you want BALANCE in Your Stabiliser /but otherwise I will not be Stabilizer/ showing You do not invent anything superfluous, despite how much interesting, useful, etc it's to seem in Your understanding..
Марат Г.
Re: The Stabilizer.
Post by Марат Г. » Sun Jun 01, 2014 17:43
Bofara Dear, Good Day!
Thank You for the clarification.
I corrected, taking into account the explanations and made all the rules, as pointed out by dear Michael.
It remains only to strengthen and fill.
