СК1М
Post by Михаил_ » Mon May 23, 2011 1:04
1. no, no such program, there is another, but until it no access (it the server), but the gist of it is somewhat different than manifest.
The point is that in the UK the programme is integrated into the device (in the algorithms of his work)
2. рад2400хд has a conventional mains power supply. If we are talking about strengthening the energy of f-tion of the device, the SC can serve as Wasim amplifier being connected to the output рад2400хд.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon May 23, 2011 7:30
Михаил_ wrote:Michael! could you explain to the device СК1М have a computer program like RAD Manifesto?
Experience shows that the program is similar to the Manifesto of the IC is not needed, there's plenty of algorithms for change.
As far as I understand (so far, only in theory) have announced a program with the ability to share with the UK is more correction settings of intentions, but does not change the algorithms of the achievements in the work of the UK's preliminary "test taste" the effects of installations for final korrektirovat. The correctness of the installation intent greatly increases the efficiency of achievements, even without additional devices, but for devices also a very good helper (to hang out).
Sincerely, MAG.no
PS Started a "coincidence" - quote Solomon, and in the post it turns out Michaela, I will not fix, how can this be?
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Mon May 23, 2011 10:40
All, Hello. :)
Faced anyone with the fact that when you try to organize something to promote their personal interests through СК1М or Radionics, did you run into furious resistance, I wanted to write the world, but most likely egregor.
That is, want to solve any problem, and it is only getting worse, and:
This happens after you connect the device
The circumstances are organized as if in the opposite direction.
If someone has had a similar experience, it would be interesting to hear.
Post by Маг.нет » Mon May 23, 2011 10:45
Hi! :)
Face sometimes (good result - response of increasing the tension) to adjust the direction or path and keep going.
Sincerely, MAG.no
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Mon May 23, 2011 11:31
Resistance as such but a stopper, then re-read the record, correct helps.. :)
рыжая
Post by рыжая » Mon May 23, 2011 21:55
MAG.no Malika, thanks for the response. :o
Димонъ
Post by Димонъ » Thu May 26, 2011 2:07
Encountered. One of the options is adjusted, as mentioned above. The second is to wait it out. Sometimes, "resistance to peace", just a hint on those tasks that need to be addressed to the case moved from the dead point. It is appropriate to break the task into components, for example. Or just "bounce" when instrument with a situation which it is necessary to wait. I so obtained.
Post by Михаил_ » Thu May 26, 2011 14:07
well, actually, to write "the world" would be quite right, I think it's sometimes even a positive indicator of a high interaction potential and serious future changes with the right actions, but we need to be more careful.
арте:м
Been thanked: 8 times
Post by арте:м » Wed Jun 01, 2011 2:32
Is it possible to place on the object table additional programs from the Stabilizer (for example cartridges from the Modulator)?
In addition, it is permissible to combine the location of the cartridge and the water tank? Let's put the "General health" and on top of the jar of water? Whether it's "modulate" the extent and quality of its "charging"?
Thanks for the replies!
Смелый
Has thanked: 2 times
Been thanked: 79 times
Post by Смелый » Wed Jun 01, 2011 7:44
рыжая wrote:Everyone, Hello. :)
May be Boris Berezovsky will answer You:
As Pushkin wrote: “the less we love a woman, the more she likes us”. The same can be said about the money, because the principle is the same. I don't know of any businessman who LOVED money. Businessmen use money cynically, and, and the love of money has ruined them. You know for profit first, you need to invest a lot, i.e. to part with their money, and more ruthless than this separation, the better the result.
Love money, ironically, it is poor. They over dry them, plucked them, procrastinate in hand, value them - and therefore do not receive reciprocity: money to them is always enough. Hence, the motto of the business you heard!: “To save really a large amount is impossible, you can only earn it.”
What the salt is? The universe, together with our application by lust gets an extension application to the inaccessibility of the requested. If you lust after (and not just casually want), then on your bid broken the terrible label: “wishes to, with great difficulties”. Then again, no one to blame. You ordered a cake with problems, you own it.
So, you have desire. It can be written for self-control - or have a good memorize in the memory. It should be (i.e. seem) realistic, not too dramatically change your life, to be very cold and rational without any admixture of desire.
Suppose humble servant receives 8 thousand roubles a month. One day he picked up alpinists paper (placebo) and wrote the PA it: “next year I will get 10 thousand rubles a month, or 120 thousand rubles a year.”
Now think what kind of placebo can be used to achieve the goal? What actions will convince You that you can earn more? What rates have to do in hope for good luck? It does not need the Universe for which Your request is nothing, You need to samarbeidende. You need to realize that the universe will give you please and without any action on Your part, unless lust will not submit an application for the treacherous “difficulty”. The more complex it seems to us to achieve any result - so it is in reality complicated for us. Some easily, effortlessly get high school diploma, others with a great screech. Some jokingly become candidates of Sciences - in other to protect out a lifetime. Some lying on the sofa make millions, others in the eternal bustle and bustle and bread to scrape together.
Not modelate! Don't tell yourself, “I wish” - you know that there is something waiting for you something, and try to bring this knowledge to the maximum of tranquillity. You're not worried about stash in the closet because I know where she is and how much it. The same knowledge about the future as about the past - without the experiences and emotions, with clarity of a chronicler - that's the top of voltinism.
You wish for the future like remembering the past. According to the scheme: “Oh, by the way, next week I'm going to find unaccounted tyschonku! On what it to spend? Can put in the Bank or buy a gift to his wife?” To get rid of lust, the painful fear of failure desire to recommend my personal method is “a shift in priorities”. This is when a person not to think about money, for example, obsessively poured, say, gardening (very important for Russia). The whole day he had a headache - where to get seeds than fertilize the garden, how to grow supercycle and somewhere on the edge of consciousness on the periphery, hanging the idea about “by the way, those 300 thousand in the next month, they suddenly fall... where to place them! Ah, not to them now, the seedlings wither..-”
If you're in the garden, a sports team or some kind of a scientific Department, then things are going horrible - because the principle of “unrest for...” provides “the complication is...”. Let you fade seedlings - but 300 thousand will come at the right time. Maybe, of course, and Vice versa-the seedlings will grow to fame, and the money will not come. So you failed to stop his fear of devouring another object, the fear of poverty was stronger.
This is from an article, the authorship of which is attributed to Boris Berezovsky.
Personally, I try your desire to build exactly the opposite. (Though you can't always follow the plans, so we are trying to think in line with the desire of obtaining).
But from the mailing Andrey Belyakov:
Hello, Alexander.
When Andrei Belyakov.
Today I want to talk to You about the strange phenomenon. Personally, I very often run into him when I was a student at the Department of mathematics Yaroslavl state University.
Imagine... Before the exam is a week, and You know that you can have time to prepare well. But You can't force yourself to sit down for textbooks.
Not in the mood, brains boiled, You read one page and understand nothing.
And on the night before the exam, when ready seems to be already pointless, this block disappears, and brain begin to work very well. It is a pity that the time has already been lost, and
well prepared will fail.
With me this happened often.
How can you explain this? Why then, when something really "need" to do the brain and body often refuse to work?
With complete clarity the answer to this question may or may not work. But it seems that it is in a certain psychological PRESSURES that create such situations.
And our brain, body and creativity refuse to work under pressure. As said by Brian Tracy: "can Not be forced to call creativity".
Where does the pressure? It arises from the expectations of concrete results, sense of urgency and the need and fear of failure.
Example: if a man goes to a disco with the idea to find yourself a girl, he probably don't have the time and nothing happens. If he goes with the goal is simply to relax and have a good time, his chances to achieve something becomes much higher.
It's all about okay.
A much more interesting question – how do I remove this most harmful pressure?
Here are my tips:
1. Spit on the end result and focus instead on the goal to obtain the maximum pleasure from the process, have a good time.
2. A starting point for discussion, try to make it not as well, and as bad. This immediately destroys 110% of the pressure (actually, 80-90 percent figure 110 I have used for dramatic effect) and creates a light and humorous attitude.
This technique, which is very much helped me to work on my info-business, I first learned from Azamat Ushanova.
And much later I learned that this technique is a particular version of the method of "paradoxical intention", coined by psychologist Viktor by Frankl.
Try these techniques tonight (I know You probably have something that is long overdue to start) – You will ENJOY quick results.
Working out in the Deir, I found out why. But this is not always possible to do so.
Probably on the principle: "bodlivoy cow horns, God has not given".
That is, finding a "Closed road".<
рыжая
Post by рыжая » Wed Jun 01, 2011 9:46
Bold, thanks for the post. I must say, to money, my desire has nikago relationship. Rather, local "politics," so to speak. :) What I will not write, because as much as most ridiculous that swung things scary because the "enemy" bigger than me is in the energy sense of the word, and the possibilities it has more. :)
Actually speaking, the ideas that I had, in order to achieve the desired - exhausted, but it was an interesting observation, and it is here that this is similar to what you wrote above. Not to focus on the end result. It was interesting in the process when trying to influence a little global thing "unconventional ways", then it is very hard, but the consequences of your actions manifest themselves directly in the eyes.
This phrase very timely, very well. :)
арте:м
Post by арте:м » Fri Jun 03, 2011 1:46
I read in the thread about making bracelet 3.0 N warning about the risk of playing on СК1М file g3.mp3 of "charging kit" because it can "erase" the "main program" of the UK. I have the player such a file there (for headphones). But once it was discovered that a player (either inadvertently, or under the influence of the SC) - switched mode "shuffle" (i.e. played everything files from memory in random order.). Since then, concerned with the question how to understand has not violated anything in the "stock firmware" in the UK? Is it possible to install, say, a picture of him? And if such fears are justified - maybe to specify about the ban on playing certain files right in the device description?
Post by Маг.нет » Fri Jun 03, 2011 7:40
Itself g3.mp3 accidentally severely damage can not, but can "pull" IC in his side (3.0) if the stress is not critical, then SK harmonizes this shift in worker process, if critical, on top of the structure "napravite structure 3.0". To determine just what and the consequences by comparing the resonances SC with 3.0 and 2.0.
Sincerely, MAG.no
арте:м
Post by арте:м » Sun Jun 05, 2011 0:56
Well, what will happen if on the stage to place a piece of paper with a matrix of 1.0 L ? All the space of the room "soaked" ?
Post by Михаил_ » Sun Jun 05, 2011 1:09
nothing will
and it is not necessary to do this.
The UK is not designed to work with BJ charging systems and matrices.
арте:м
Post by арте:м » Sun Jun 05, 2011 19:20
SK is not designed to work with BJ charging systems and matrices.
Understood! Thank you.
Тучка
Post by Тучка » Tue Jun 21, 2011 8:23
Nebol'shoi otchet 8) Na dniah poluchili posilku s brasletami i sk1m.
Umerla russkaia klava :cry: Business vpal v polnii stupor. Fizicheskoe sostoianie 99% otlichnoe. Vremia ot time zabolit to tam to tut, cto-to chinitsia navernoe. (2.1 + 2.5 u menia)
Vskore after prihoda sk1m zapisku nacelenuiu napisala na popravku material'nogo polozhenia. No vse kak budto usugubilos'. Segodnia reshila peresmotret' formulirovku. Sniala zapisku s sk1m - v komnate virubilis' nekotorie elektropribori (ne vse)- comp, babymonitor, holodil'nik. Kucha ostal'nih prodolzhala rabotat'. Napisala novuiu zapisku, polozhila sk1m na - vse vkliuchilis' :? Cto takoe Oshushenie nado chto-to delat srochno', a chto poka neponiatno... :roll:
Post by Маг.нет » Tue Jun 21, 2011 9:02
This occurs by increasing the amplitude of energy.
1. In a similar case, I would .set language in the UK and BJ -
.harmonisation of me and around me and the World in the most favorable way and .released >>>
2. Yes, and the Stabilizer (even in printed paper version) with Anchors (and. appliances and other equipment; b. I like the energy facility; V. I, as a system of interaction, etc.) and Stabilization (can be more than one for each Anchor) may contribute to the early stabilization of harmonization.
3. With SK it is better to first "meet and negotiate" (will constraits), to obtain the response of the effective interaction, and then to instruct a serious problem.
Of course plenty of other options, it's just "one of...".
You favorable interaction with tools, BJ and SK!
Sincerely, MAG.no
PS the Chattering happens when the attunement many passes...
Тучка
Post by Тучка » Tue Jun 21, 2011 9:37
Mag-net spasibo ogromnoe za soveti, a to ia tut sizhu i zhdu - chto mozhet kto podskazhet. Ia a s SK oznakomitel'nuiu rabotu nemnozhko provela, mozhet nedostatocno konechno. Situazia, kak eto chasto bivaet, podzhimaet SIL no. A vot so stabilizatorom ia kak-to opasaius' rabotat' yet. Nuzhno eshe mnogo prochitat' chtobi V ehat' :oops:
Poprobuiu postavit' na zadachi dlia garmonizaziu i SK BG (uzhas kak pisat' ne udobno :roll: ) Spasibo ogromnoe esheraz.
Post by Маг.нет » Tue Jun 21, 2011 10:07
...stroll through the woods or to a natural water at least for an hour, relax.
And at first (for a week) a long chat with the UK in close direct contact probably wait to... to pick up (with a sense of interchange energy) for 10-20 minutes per day and preferably only to You, well, at least the first week. And this week 2.1 and 2.5 must be postponed to the side, it is better to use only 2.0 (if any). Perhaps you described the effects of the strengthening quality 2.5...
Sincerely, MAG.no
Тучка
Post by Тучка » Tue Jun 21, 2011 10:39
Ok, poidu guliat' utrom, vecher u nas uzhe. S i SK tak postupaiu, navernoe time eshe ne proshlo dostatochno - men she prishel kak week. A brasleti kak zhe ih teper' sniat' - oni mne uzhe such rodnie stali. Do etogo bilo ko neskol'1.0 kamennih odeto. Vidno chto nuzhno vremia-b eto vse priterlos'. Krome menia muzh i i deti odeli novie brasleti. Vidno much all razom v dome okazalos' :oops:
Довольный
Post by Довольный » Thu Jun 23, 2011 12:02
On the amplifier to SK every week a bulb burns less brightly. Then went on vacation, come to light almost does not burn, barely noticeable.
The amplifier is SK. Spinning purpose through audio.
Why falling capacity? What to do with it? Soon the light goes out completely judging by the trends.
Post by Маг.нет » Thu Jun 23, 2011 12:36
??? :? and there is no monitoring of allocation "adhesive mass" from under the stage?
On the fall of the power of the judge according to the light or feeling?
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 23, 2011 14:38
Happy - light reacts to a bunch of factors and IS NOT indicative of POWER!!!!
it has no direct connection with the electronics of the amplifier, illuminates when there is signal not spent. When the light is weaker, then part of the output is consumed on business (or on You personally, in the growth of consumption as addiction to Have).
Cloud - I absolutely do not like this approach. Buy SK due to some emergency situations and immediately expect some improvements - it's a dead end. Because maybe the situation is a your the lesson your subconscious is synthesized to change YOU. SK can pugibet as the only correct scenario is faster to get out of it. I'm not saying necessarily so, but that in some cases it is possible. Again - a lot has been said that the constant expectation of some positive changes due to the intervention of the device is a blunder that can impair their credibility. Ie, I recommend in such cases the IC or do not use. or put it on a flexible definition of a series of "decision situation .... (fill in the blank) the best and most harmonious for me and my family, and also for the harmonious flow of the other processes I have and my family way in the short and long term", remove the instrument away and forget about him.
All your jokes from immediate desires change, perhaps where we need different changes. SK as an instrument of corrective and harmonizing, can be a solver of problems in the direction of the course, which will then be potentially harmful to You (and You are unable long term to foresee the consequences of one or another scenario).
In short I really don't like the rush. A week well.
Тучка
Post by Тучка » Thu Jun 23, 2011 15:38
Mihail_ spasibo. Pozvol'ia vse te zhe otreagiruiu svoim translitom :? All Delo ne v tom chto ia speshu za skorim rezul'tatom. Prosto opisala prikoli proishodiashie u menia na dannii moment. Zhe... Chto Interesno nedelia srok tozhe ne ponimaiu, soglasna 100%. Zadachu poprobovala postavi't - potomu kak ruki cheshutsia :oops: no k proishodiashemu otnoshus' otkrito. Sovetu Po Mag-neta, smenila na zadachu "garmonizaciu" k i SK ne prikasaius'. Vot navernoe, 2.1 poidu snimu :cry: poka na. Proshu proshenia za translit. :?
