Machine Dr rife
All kind time of day!
Sergey P, want to make the KPE itself as the price on the factory too much http://mirradio.ru/product_info.php?cPa ... 3fbh0u7bu4
Could You give the settings of your variable capacitor, namely:
1. The thickness and size of al.plates
2. Material tightening stud bolts for stator and rotor
3. The dimensions and material of the distance bushings. I read on the forum that you can use a bushing from a Bicycle chain.
Re: Machines of doctor rife
Hello !!
KPE consists of two sections that are deployed relative to each other 180* for the weight compensation. Because the weight plates of the rotor turns out decent and if the plates are not balanced, the rotor of the variable capacitor under the weight of the plate itself starts to turn. If the plates do in a row, you will need to do some locking of the rotor. Rotary plate in the form of a sector with a radius of 45mm. The stator is a rectangular 45х90мм. Only 40pcs. stator and 42sht. rotary. All plates carved from duralumin with a thickness of 0,5 -0,7 mm rail templates and annealed in the package is clamped between a flat thick iron plates, at a temperature of 350-400* (for alignment of plates, and stress relieving of metal). The distance between adjacent plates is 1.2 mm , the capacity of each section 800пф - 25pf. The total capacity 1600пф - 50pF. The rotor shaft without bearing, carved from iron, leans with one hand on Protochny on the shaft cone (90*) from the end is preloaded by a screw with a cone on the end. The current collector of the copper narrow strip, coiled coil and soldered one end to the terminal on the rotor, the other to the terminal fixed on the insulated side of the plate. Side plates of 5-mm Plexiglas, all the holes are drilled in both plates at the same time. In the center of the plates inserted iron sleeve and pulled nuts. One spigot with a cone in the rotor shaft and the two hammered into the holes with pins to limit the rotation of the rotor. The other on the inside with M6 thread under the set screw. After Assembly and adjustment of the variable capacitor, contra resistant screw lock nut M6. The diameter of the rotor shaft under a duralumin plate of the rotor is 6mm.
Of the rotor plate are tightened with the nut M6. Other sizes are arbitrary. Tightening the studs to the stator plates of iron wire 4mm with M4 thread. In places on the heels, which will be located to the stator plates, preferably the thread is not cut for a better alignment of the plates. After annealing and cooling the stator and rotor plates, packs neatly sort out what would not bend the plate (if a little stick together, they can resedent blade from the razor) and carefully collected first rotary, and then into the studs of the stator. After Assembly of the variable capacitor plates are necessarily centered what would be a rotation of the rotor the gap between the plates remains the same. If necessary the plate can be evenly bend. This whole process must be done very carefully, otherwise you can ruin the plate will be off !! The spacers I sharpened iron rod, aluminum can, and (one that is), their thickness is necessary to withstand very accurate !! I don't know about bushing from a Bicycle chain, but if their thickness is suitable, and very precisely designed, then why not. The thickness of the spacer bushings uisitively: if you need the gap between the plates is 1mm, then take this 1 mm + plate thickness + 1 mm. If the thickness of duralumin plates of 0.5 mm, the thickness of the spacer sleeves is 2.5 mm. If you need a gap of 1.5 mm, the sleeve will be : 1.5 mm + 0.5 mm + 1.5 mm = 3.5 mm. my bushings a 3 mm thickness. With increase in the gap between the plates, the desired capacitance of the variable capacitor will decrease very rapidly.
Of course, the process is very time consuming and not everyone's strength, but if you wish, you can do everything.
http://uploads.ru/RpmSl.jpg
Good luck !!<
Good luck !!<
http://uploads.ru/OPNwk.jpg
duralumin plates of the rotor and stator and their metal templates
http://uploads.ru/VGf7v.jpg
and this plate for annealing
Sergey P, thank you for the detailed information. I will try.
found drawing http://uploads.ru/1JfWL.jpg
only the rotor plates 50 mm and 45 mm
Similar to mine, only the plate thickness of 1mm very big. The optimal wafer thickness 0,7-0,8 mm.Числово wrote:found drawing http://uploads.ru/1JfWL.jpg
Here are the exact sizes of my plates:
All good time!
Sergei p1)a 20 page You casually mention the rife device with a fixed carrier of 3.3 MHz and a low modulation frequency. You've collected? What's wrong?
2)Who was engaged in the manufacture of analog panatron,tried to add 1-2мгр of mercury to create the best conditions for burning plasmas? As is done in the manufacture of neon signs.
Hello !!АлексДроп wrote: Sergei p1)a 20 page You casually mention the rife device with a fixed carrier of 3.3 MHz and a low modulation frequency. You've collected? What's wrong?
Bother far the chosen carrier frequency from the operating range !! If you work on this carrier, then the ordinal number of the harmonics get very far and the power and efficiency of these harmonics is very low. That is, if the schema of the output stage is collected on a single lamp. Looking through the photos of the car №5 ,,Report, , we can see that the chassis is still not being used the holes in the panels of tubes. The fact that the extant rife machines have already been converted, we know about it. I got the idea that the scheme was still on the two output lamps and two circuits. And GRL included between them (by the way this also is the same ,,Report,,). And now for some reason I thought that was two generators in one housing and two bearing - 3.3 and 3.8 MHz, and their frequencies are added to GRL. The result is four frequency - 3.3 and 3.8 MHz and their difference and sum frequencies - 500kHz and 7.1 MHz. The frequency 500 kHz is the frequency range of the PESTILENCE. When a modulated carrier of one of the generators of audible signal desired frequency can be any harmonic of the desired frequency MOR in the side lane. Given that 500 kHz is close to all the MOR frequencies, harmonics will have a maximum amplitude !! Additionally, the sum of all these frequencies will give many other frequencies that also will benefit.
At first all was not clear and I started to make the oscillator tunable circuit is simpler ! Now it does not want to go back to fixed frequencies.
Mercury cannot be added to our GRL for two reasons :АлексДроп wrote:2)Who was engaged in the manufacture of analog panatron,tried to add 1-2мгр of mercury to create the best conditions for burning plasmas? As is done in the manufacture of neon signs.
1. The biggest reason - there will be strong UV radiation.
2. A discharge in mercury vapor occurs a little differently and you will need to change some of the parameters.
In discharge lamps, neon signs mercury is added for better combustion conditions of the plasma, and for the powerful ultraviolet radiation that causes luminescence of the phosphor.
Mercury discharge lamps are lit worse.<
Alexpal Hello, carefully read your recommendations on the rife machine, I have medical education and I now have a heavy patient with lymphoma 4st, applied frequency in the Oncology unit at Radiant, there is no result, help me with the rife machine, I will not be able to collect it, it is possible to order? How can I contact you?
Alexpalemail me at my mail odintcova87@gmail.com
LidoLido Dear friends, can anyone have contact with Alex pall? please write me an email, the sister of the patient, we want to help, and the Radiant only lipostat got... Maybe someone can help ??
DeltusDeltas, and you had to buy tubes from Lex pall?
LancelotLancelot, and you've got mail Alex pall?
AlexpalAlex pall , you are offered you have to buy the lamp? Where and when?
Lido no failed to buy .Although almost immediately wanted to order .
Hello, I am also a specialist in the manufacture of GRL to order. Write to the PM or e-mail:chislovo2013@yandex.ru. I will be very happy.
Where it was. But it is encrypted, the type of mail is not him, and whether his wife. whether sisters. Replied, until I slipped him a drawing of the lamp. Muddy it, in the furnace of such.Лидо wrote:LancelotLancelot, and you've got mail Alex pall?
Bodalki with the car yielded nothing, the wife died, the second patient Onco-cat too. May not have enough time, can greatly all started. Different alterations the machine was made, as you know the more incentive to butt with it. However, there are ideas that may be implemented. Thoughts such lamp is not particularly important, lizh was burning well. Frequency is important, but bacteria and mushrooms in the bowl dead at any frequency, I think coincidence or ultraviolet light. All of this requires finishing and fitting the theoretical basis otherwise it poking a needle in the sea.
I wish you all success in work, health, as found out is the most valuable.
Budmo!
Budmo!
- ЯркоПапайко
Дельтус wrote:Lido no failed to buy .Although almost immediately wanted to order .
I have problems with buying a GRL too.Числово wrote:Hello, I'm also a specialist in the manufacture of GRL to order. Write to the PM or e-mail:chislovo2013@yandex.ru. I will be very happy.
I asked in Econika (Odessa) http://www.odeconica.narod.ru/RifeBareeng.html to TIE 150W lamp, price is 200 USD. Well, I ordered, waited, and after my further notice, the answer came that they leave to stand for two weeks. It was in late July, the u since then, I have not seen the answer. I'm not in a hurry (now I heal from my Lyme healer by car RPZ14), but before the end of the world I don't want to wait.
Bill Cheb (Canada) http://billsplasmatubes.com/ told me that his thanatron 8" at a price of 615 USD + shipping around 150 USD. I think that could use and Mansi than 8", but I was not asked on others.
So looking for other options.
Yes, do not bother you on such purchases. make yourself from liter cans and buy the vacuum pump. they will pump out air. in and out it's 50 times cheaper. I already checked it on my own skin. everything works and works perfectly. I read a report from one user on another site who ordered panatron this American and he came to him broken... and then this man proved to the Americans that broke panatron mail,and not himself.. as a result, the American sent him a new one free of charge, but time was lost a lot... and about how to make a GRL from the jar or the jar in this thread a lot of information. panatron not the main thing... the main thing is to give it the right signal. and discharge will work in any gas in any capacity. the main thing is to keep the distance between nickels in GRL at least approximately +- 10mm and everything will work.ЯркоПапайко wrote:So looking for other options.
Welcome the the forum !!
Something topic completely stalled, and soon the anniversary will be.
Maybe someone already has some results (any) treatment share.
I want to share my observations : after the fundamental frequency from the table, I have gained frequency is half of the primary, ie, if, for example, we dialed the frequency of carcinoma 1,604 MHz , turn on for five minutes, then dialed 0,802 MHz is also five minutes. Why do so ? I think GRL goes out and lights up two times for one period of the sinusoidal oscillations. And it turns out that it emits a frequency two times greater than expected on the table. And again, the intoxication starts on the second or third week of treatment and it is better to clean from toxins, drugs (in the hospital). This will reduce the load on the liver.
Алексей В.П.
- Has thanked: 1 time
Hello!
For those who want to continue to experiment with tube stages I want to remind you about the so-called "hybrid" amps (with a transistor in the cathode, such http://sneghana89.moy.su/forum/28-173-1 and so forth). Should be well coordinated with release some DDS generator, eg. MHS-5200P. To work on in advance known ("table") frequency couldn't be easier. And if you want, then on the generator enable sweep +- 1 kHz is possible, with such a conventional detuning and P-loop, the signal will flow without a significant reduction at the edges. It is proposed just as an idea, yet he will not do that, there is neither time, nor special desire (in light of the lack put. reviews, noteworthy).
