СК1М
Post by Михаил_ » Wed May 04, 2011 18:45
the programme has its own danger - it can highlight to the end of the lucid aspects of the target, but removes the problem of inaccurate wording. And on the subject soon, I said just yesterday in the thread about the amp..... the problem is not in the program and the network access to her now fundamentally solve this issue, just a very standard situation, such as a part used in its work of psyleron, for some reason likes to "fall off" after a day or more of work... i.e. when it is in manual mode - no problem, but if you want to not cause headaches, it has several interesting everything.
Тоха
Post by Тоха » Mon May 09, 2011 16:41
The day before yesterday conducted an experiment with the participation of SCM and radionica. Put a bottle of tequila was asked to be in the best possible way. For Radionics were specific instructions for the situation for each guest. SKM worked on some wording, so everything was good all who drink. In the evening guests came. 3 a bottle of tequila has always been a lot drink a little. This time it is not so. Sat perfectly persuaded a bottle of tequila and dispersed peacefully. In the morning there are no consequences except for one, all woke bright and cheerful. I'm now all beverages will be put first on the SCM.
Сергей Дельфин
Post by Сергей Дельфин » Tue May 10, 2011 19:35
Hello Michael! Ordered and already paid for device SK 1M, waiting for delivery. Please tell me you can work with the device without BJ and carry it with you because my work involves two types of activities and jobs in other offices. Wear it for example on the NLP trainings to get more knowledge and to improve harmonization with the device operator, the environment?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Wed May 11, 2011 11:41
1.Without you BJ ,but BJ always (easy ) and solve it almost the same tasks as with the SK.
2.To carry a SK (it is quite heavy) there is no need. He mentally linking to you or using the Shuttle a couple.
АП
Post by АП » Wed May 11, 2011 12:49
Tell me whether to write effective goals for b/W laser printing photos SK directly over the image the device? or equally effective would be just to set a goal mentally?
Post by ЛИЛИЯ-Р » Wed May 11, 2011 13:51
Device photo is not necessary. Photo of man and the mental or marker to write or draw-type images, or mandalas, or your picture investing in it what you want (goal ,desire).Easier to imagine a person and what you want for him to draw on a blank page to write. Putting in a picture idea.
АП
Post by АП » Wed May 11, 2011 18:42
I meant the following situation: I'm outside the city, ck city, how to set a goal similar to the goal setting audio connector, turned on and it plays a week or two.
The idea was to take a photo of SK, print it and write the goal on directly on the image of the UK. Goals regarding themselves and situations connected with me. Want to find out if it will work? or simply ask mentally?
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Wed May 11, 2011 20:42
A similar question has already been discussed on the Forum.
...if you need external fixation mental attitudes for the UK, you can simply place scheme (formulation) in Notepad (probably best advanced mental linking this page with the UK, such as "logbook") or in a notebook of phone (especially if it is an element of at). Mental control is, in my opinion more effective when the Operator is present BJ, if "select from...", the function "remote" greater - 2.1.
Sincerely, MAG.no
Post by Михаил_ » Wed May 11, 2011 23:16
Сергей Дельфин wrote:Hello Michael! Ordered and already paid for device SK 1M, waiting for delivery. Please tell me you can work with the device without BJ and carry it with you because my work involves two types of activities and jobs in other offices. Wear it for example on the NLP trainings to get more knowledge and to improve harmonization with the device operator, the environment?
1. With the device without the BJ can work, but not recommended. Will work, but it is better if the operator is "trained" wearable BJ. Improve efficiency and communication with the operator and will soften+and harmonizes the operation of the device.
2. To wear the device there is no need. It works not locally, but remotely. Change if activities put different wording at different times, for example by using task scheduler in Windows or the playlist in the player.
3. In principle, it is sufficient mental control.
4. of course to hold the device in hands it is possible and it can be more effective, but only as a means of energy supply. For the direct operation of the device (task effects) it works not only with the operator and there is no need for his presence near. In General, direct contact can strengthen only energopodachi through the hands, in all other cases the device could be anywhere. Exception - the software works with the room, copier and other tied to the place of the task.
ЛИЛИЯ-Р wrote:1.Without you BJ ,but BJ always (easy ) and solve it almost the same tasks as with the SK.
Lily, a transfer pair are supplied with the modulator and provide a transmission channel configuration or energy in one direction. Operator interaction via the transfer does not work.
Post by Михаил_ » Wed May 11, 2011 23:18
АП wrote:Tell me whether to write effective goals for b/W laser printing photos SK directly over the image the device? or equally effective would be just to set a goal mentally?
Equally effectively.
Improving the efficiency can be in audio playback, due to additional energy being converted from an audio signal. But the difference is not huge, though to see it. Plus there is some dynamics there (yet sounds audio it, i.e., the signal changes in time, setting the dynamics of the process).
Post by Михаил_ » Wed May 11, 2011 23:21
АП wrote:I meant the following situation: I'm outside the city, ck city, how to set a goal similar to the goal setting audio connector, turned on and it plays a week or two.
Yes, at such statement of a question, just a mental command. Or Yes, the notebook. Ideal a file or directory on your phone at. About greater efficiency in 2.1 to confirm.
Post by ЛИЛИЯ-Р » Thu May 12, 2011 11:20
[quote="Michael_"]Lily, a transfer pair are supplied with the modulator and provide a transmission channel configuration or energy in one direction. Operator interaction via the transfer does not work.[/quote
I was a conversation somewhere that you can create to transfer a couple of the type of stones or mandalas ,and radionivka transfer pair someone said that put on the UK.
By the way the cartridges from the modulator tried in the UK .Their quality and across the UK.Or am I mistaken? But the feelings are the qualities and manifested on the cartridge.Put SK cartridge specific and send these qualities to the person (mentally)in the UK. Worked .
Post by Михаил_ » Thu May 12, 2011 12:07
Lily. Don't need everything in one pile. Re-read carefully the description of SK. The operator feels at any distance because distance is just our model of perception.
And SK contains the authorization system screens and extraneous control signals. Cartridges sure can. Yes, wrote about it. And can do many things, but the management is not made using transfers just. The cartridges belong to the elementary program got on the subject table.
And the thing is, by definition, bilateral. I.e. you can try and some effect probably will, but it will be because of a direct (no transfers) management is no screened. Yes, you can mentally register that a transfer subject f-tion of the extension of the governing body, but in fact it will not work due to the fact that he was a tranfer, but because ordered that he accepts control commands.
But "someone said" in this case doesn't work. Works that are stipulated in the program of SK.
In other words, suratensis you can obtain the control via any object, but it will not be better straight. And transfer it or not. To recommend to manage through the transfer is not necessary. Through the at - can.
Post by ЛИЛИЯ-Р » Thu May 12, 2011 12:49
So not a recommendation ,and personal Experimenti :?
And not only mine.
Post by Михаил_ » Thu May 12, 2011 13:06
well, I once again explain - it's not up and running takeaway in the UK per person (no matter who) on my or another Shuttle (in the form of some amplification is not a managed stream quality due to object transfer in the direction from the device to a person), the management always goes through the program. Well, you can to the saucer to tie the mental - will work too or there is the lid made no difference. Transfer to control and significant influence have not. It's not "iron tool" (IC) and more - the program and very flexible. Issues authorization and administration there carefully specified. The program is still in the result looks at the operator.
So even if You have experience managing IC through the transfer, then You've basically made an artificial complication of the way, but it works all the same direct control of the program, what would You about this thought.
Post by Маг.нет » Thu May 12, 2011 15:41
Using anchors (commit) driving is easier - a fulcrum, and transfer a couple or a canning lid as the anchor does not matter, but the Shuttle can still be based on a fixed channel. So what he spelled out in one direction and only for the seizure and transfer of energy, it is possible to catch reverse channel feedback channel and use it to send a mental command. But it is a complication when the connection is wider and without the "artificial channels", while at the initial stage of interaction with the UK, this configuration may give a "fulcrum".
Michael_ You from the first day talked about the direct mental control of SK, but I at first did not feel a connection and needed auxiliary tools, such as transfers, are now being accessed remotely without additional piling and not just the UK. Maybe for the awareness of the connection takes time (experience), and while any anchors, which help to understand this relationship may be useful.
Sincerely, MAG.no
Post by Михаил_ » Thu May 12, 2011 16:53
not here to argue, but emphasize their artificiality to instill a feeling that such supplements are necessary (i.e. to avoid the misconception that without them does not work or works worse communication with the operator).
АП
Post by АП » Thu May 12, 2011 17:11
Everything is clear, thank you for your answers.
Сергей Дельфин
Post by Сергей Дельфин » Thu May 12, 2011 21:20
Михаил_ wrote:1. With the device without the BJ can work, but not recommended. Will work, but it is better if the operator is "trained" wearable BJ. Improve efficiency and communication with the operator and will soften+and harmonizes the operation of the device.
1.Michael, I'm in this business the full zero :roll: It turns out that BJ without the device in hand is not worth taking until you order a BJ? Then tell me what to order? And what else comes with SK?
2. How to put wording in the player, and how to connect?
I am very sorry for my probably very naive questions :oops:
Post by Маг.нет » Fri May 13, 2011 11:21
:) Maybe will add clarity to the understanding of similarities and differences in interactions :)
Zone BZ and IC in the border region of the cocoon (fields) of the Operator from all sides.
The scheme of "artificial" only for ease of understanding.
Comments and corrections are appropriate!
Sincerely, MAG.no
Post by Михаил_ » Fri May 13, 2011 12:46
Сергей Дельфин wrote: 1.Michael, I'm in this business the full zero :roll: It turns out that BJ without the device in hand is not worth taking until you order a BJ? Then tell me what to order? And what else comes with SK?
A simplified diagram of the MAG.no, in General, correctly reflects the essence of the matter.
Ie the first thing they should have to read quite carefully the description and discussion and СК1М and BJ.
BJ is valuable because it activates the subconscious mind and create a skills the best experiences. Your attitude to the use of SK, as a consequence will change. Will work without the BJ, get your hands on as many :)
For all other questions are answered in the thread better to read them than to get again from me, because with them, read and other useful information. This is quite a complicated thing - SK, it is better to spend time on self-education than to fun.
Since the language of our fffse :)
And BJ does his part - he's a bit tidy You like a cocoon, as for cocoon in General, and this affects the situation. UK deals external repair...
If BJ not to wear, that IC, in the performance of any task which rests on You personally, and can not be solved without some positive change You will cause in the UK in the first place, something that most likely will start the processes of the changes. With BJ it probably will not happen at all (to cope BZ).
Version BJ any, from improvised free. If you want faster then 2.1, if softer, it is 1.0 or 2.0 will go. Senior is not just to take I think....
Сергей Дельфин
Post by Сергей Дельфин » Fri May 20, 2011 15:31
Thank You very much Michael! The device came, it works, though 4 days went in a blur, after attunement with the device :) Ordered BJ 2.1, now the tandem will be very harmonious. Experience of working with the subconscious is, so I am sure everything will be fine :ay Tell me, everything's better after it was adjusted from 2.1 to 2.6 purchase because I'm in the thread of randomness is quite high 2.7 or better? And how soon you can go after 2.1 to 2.6 or 2.7?
Post by Михаил_ » Fri May 20, 2011 21:24
2.6 or 2.7 - rather depends on the purpose.
2.7 - much more energy ( I often carry either your 2.7+ - which is sooooo great of larch, or, if it does at hand, sometimes I take another one)
2.7 is a kind of harmonious state itself....
2.6 it more stability
2.6 is more "I'm a tank and drive forward"....
and then it is useful.
for example today I spent a whole day in a pair 2.6
sometimes I have a 2.1 (also usually a pair or 4pcs) or 3.0
depends on the mood and tasks that are different.
The choice of 2.6 was associated with a certain perception of the state of the world as excessively chaotic last 2-3 days (which was confirmed by numerous complaints of third-party people to health)
Шломо
Been thanked: 3 times
Post by Шломо » Sun May 22, 2011 23:43
Michael! could you explain to the device СК1М have a computer program like RAD Manifesto? and whether СК1М serve as an external power source for RAD2400HD?
Thank you.
