Advice from Andrei Patrushev
Zorenka
When You turned on the device,displayed R01,doun press button 2 times before the appearance of the letters Aus on the display,press play and start the CD with audio media.(remember to sync your music. center the machine is supplied with a cord).The brightness of the strobe signal can be adjusted by adding/the volume down on the audio media.
Hello, Andrey! Thank you very much for the answer!Андрей Патрушев wrote:Of course you can... But you can just sleep under the Conductor.ММозг wrote:Hello Andrey! As I understand it in most meditation practices the main purpose is to achieve so-called "zero" level of consciousness. The same can be reached through MM. My question is the following: is it possible to simultaneously listen to the alpha session or the disk Explorer and meditate as I used to do it, muttering the mantra to herself? I ask because I bought Innerpulse and drives Conductor, Healing Endorphins and solar wind 4 days ago. When listening constantly distracted by some thoughts. Now I use only R-session and guide for the morning and evening. The Conductor can't hear/concentrate on the text or climb different thoughts or fall asleep. In advance of blagodar for the answer.
The thought is good.Just watch them as if from outside, marking the start and end of each...
But now a new "attack". Are Explorer and r-sessions 1.5 weeks. For the second consecutive day dream about vampires. The dreams are vivid and memorable. From a nightmare Wake up with a feeling of anger zameshennogo on fear. Fall asleep and again dream of a new "series" with vampires, but with a different plot. And so 2-3 times per night. The overall scenario, "movies": popadaesh in vampire society, they hang out around you, after some time, I attack them then they attack you. And so the whole night in the struggle. javascript:emoticon(':evil:') This topic has recently been discussed on the forum. My dreams also differ in the feeling of hopelessness hence the anger. The brightness of subjects is comparable with the dreams after receiving a strong analgesic after the surgery, made me in young people age. To sleep, no films, horror stories did not look and did not like. I can't understand the connection between these dreams and my studies. Or is it something out of me?<
Саша 2
Question Patrushev
Andrew, and what session it is advisable to listen to from the Beta waves? It is possible to register here?Anonymous wrote:Андрей Патрушев wrote:Erection directly from the theta condition is not connected (for example, the strongest erections in the morning, just the background theta), and tied to Your overall tone, which, of course, blame an excess of theta waves. All good, that moderate.Саша 2 wrote:Good day! Can help. I've been listening to Theta disks(5 disks) and the solar wind. Impressive. I liked it. The effect is impressive.
But...the body was like a sleeping, lethargic , relaxed. Can the hearing of theta waves to affect the erection. Women like a lot, and even more drawn to them, but with an erection as was not very. Type the body does not want. Can I listen to something with beta waves or something else will advise me.Beta should first be familiar. But you can do it now.
Read please FAQ http://www.mindmachine.ru/viewtopic.php?t=2181Сима wrote:Oh, something no one answers...
Maybe I do not understand the questions asked??
Better to start with "C" then go to "E".Anonymous wrote:Andrew, and what session it is advisable to listen to from the Beta waves? It is possible to register here?Андрей Патрушев wrote:Erection directly from the theta condition is not connected (for example, the strongest erections in the morning, just the background theta), and tied to Your overall tone, which, of course, blame an excess of theta waves. All good, that moderate.Саша 2 wrote:Good day! Can help. I've been listening to Theta disks(5 disks) and the solar wind. Impressive. I liked it. The effect is impressive.
This is the method that created Bert Hellinger. This method of solving psychological problems based on the analysis of relationships within the family (sort of).Андрей Патрушев wrote:please Explain about what exactly You are asking (with a link )?
Quote:
"Family constellation is, in General, very simple method. You choose people for the most important participants in the relationships, set them against each other and so leave. In the process of constellation something hidden shows up, and the person for whom the arrangement is made, immediately sees what has appeared".
http://www.koob.ru/hellinger_bert/ are the books in Cuba. Myself however, haven't read it since recently I learned about the method and tried it.
Сима
Thank you, Andrew, I read.
It says that it's side effects and will go away over time. This is understandable, but what to do while they still have to execute them or to endure? For example, is it possible to change body position and make all movements are what you want, or to wait until.
And the question remains about what disks it is better to listen and when to facilitate the restoration of normal biorhythms of sleep/Wake.
A single Conductor for the night or even enough to add in the morning MM, for example. I ask because I hope that in your practice have similar experiences - you may be able to tell the already proven combination.
After all, nowhere is it written that you need to lie still.Сима wrote:Thanks, Andrew, I read.It says that it's side effects and will go away over time. This is understandable, but what to do while they still have to execute them or to endure? For example, is it possible to change body position and make all movements are what you want, or to wait until.
Sleep well-suited disc Healing (just before falling asleep). In addition, alpha training on a regular basis normalizes good night's sleep.
No, with this method I'm not familiar.Сапфо wrote:http://www.koob.ru/hellinger_bert/ are the books in Cuba. Myself however, haven't read it since recently I learned about the method and tried it.
Dear Andrew. My goal is to transform all the negativity that I created for all my life, in Light and Love, to open your heart to Universal Love and service in the name of Love. Recommend a sequence of programs, please.
Does the Arsenal of Your programs, not only those which cause trance States, but a state of Love for all beings?
Explorer.Зоренька wrote:Dear Andrew. My goal is to transform all the negativity that I created for all my life, in Light and Love, to open your heart to Universal Love and service in the name of Love. Recommend a sequence of programs, please.
Thank You, Andrew. The installation of the update, please.
Unity with God is the only goal that I wish to achieve.
I am constantly, every moment of life feel the divine help and support. What peace and bliss brings this unshakable faith in Your Love and Your Omnipotence!
All that I need for my spiritual growth, raising my vibration, enlightenment, service, You, merge with You – comes to me with love, easily and on time. I'm safe – You're always with me.
You am everything, You're everywhere! What a joy to serve You! Every breath, every exhale I send towards your goal, every moment of my life I'm moving on the chosen path. I trusted You completely and forever. Now and always I'm with You. All the surrounding people and situations I see the presence of the Eternal, everything that happens in my life is the manifestation of the Almighty.
Abide with me, lead me, slavisa in the world out of my heart.
Every moment of his existence I am aware of Your presence, I embody the divine plan.
Гостья
Hi Andrea,
I would like to ask You, what could mean such a thing. I drew attention to it a few years ago, then it did not happen as often now - almost every night. When I relax, I suddenly begin to feel in your chest sound like the sound of the motor, i.e., the frequency is much higher than the frequency of heartbeats-pulse. (If we take the frequency of the heart beat 60 beats per min., the frequency of this "phenomenon", for example, 200-300 "beats" per minute, approximate, because in this state I can't take stopwatch in hand and measured) for Example, it would be possible to compare long-pronouncing the letter "R-R-R-R-R" or with the purr of a cat. It is those vibrations which are written by people who have experienced astral or the rising of the Kundalini, or is it some kind of symptom of the heart (for example, there is a saying "a beating heart", although I don't know what it is)? What is it ?
Гостья
