SELF-HYPNOSIS AND PROPER GOAL SETTING
Олександр
Re: self HYPNOSIS AND PROPER goal SETTING
Post by Олександр » Tue Oct 04, 2011 13:38
Андрей Патрушев wrote:
Олександр wrote:
Андрей Патрушев wrote:Oleksandr
Like the special no comments.
And do You literally "set goals"? :)
And how it literally? Maybe not literally. What do You exactly mean? :?
What do You do in your head when you set goals? Where You have them located in the inner space?
Perhaps in the future, if you about it! :roll:
Post by Андрей Патрушев » Tue Oct 04, 2011 13:51
Олександр wrote:Probably in the future, if you about it!
No, I'm just about space (front, back, left, right, top, bottom). :)
By the way, where in your inner space is past, present and future. How many events in the future and the past enables Your present? :)
Олександр
Post by Олександр » Tue Oct 04, 2011 14:58
I hadn't thought of that. But in principle it seems that front! And what is so important?
Олександр
Post by Олександр » Tue Oct 04, 2011 14:59
Андрей Патрушев wrote:by the Way, where in your inner space is past, present and future. How many events in the future and the past enables Your present? :)
And how is it determined? :?
Post by Андрей Патрушев » Tue Oct 04, 2011 20:18
Олександр wrote:And how is this determined?
Consistently remember events from the past through the present into the future (in the future it is necessary to take developments in the buyout, You're sure, the type of washing, work, the sun will rise, etc.) - define your timeline - how You code time.
Олександр wrote:I hadn't thought of that. But in principle it seems that front! And what is so important?
But You yourself wrote:
Олександр wrote:I can easily and quickly solve any the tasks.
But if You put them on the right, or left, or top, then all will go awry... :?
Because the "set goals" is just an idiom of the Russian language, is true only for the person who invented it (well, and for others with a similar configuration of thought)...
Олександр
Post by Олександр » Thu Oct 06, 2011 12:51
Андрей Патрушев wrote:Oleksandr wrote(a):
Actually I have everything mixed as all the vulgar actions of the present and the future I see, too, as if in front of him.
Post by Андрей Патрушев » Thu Oct 06, 2011 12:58
Олександр wrote:actually I have everything mixed as all the vulgar actions of the present and the future I see, too, as if in front of him.
This is normal.
Still one left, the other right... :)
Many "life line" is before the eyes and often goes from left to right, diagonally...
Denisko
Post by Denisko » Fri Oct 07, 2011 3:43
Yesterday before the session put a few purposes, respectively, amounted to
for them affirmations:
1.) During each meditation session I am in deep relaxation
and the deepest altered state of consciousness in which the experiencing
a fantastic, transcendental feeling, as well as complete freedom
and peace. At this time, my body asleep but mind awake. Consciousness
separated from the body. (The goal is the deepening of meditation, trance)
2.) Every night I witness the fact that make astral
projection. (Target - output in the astral)
3.) Every night I find myself thinking about what we are dreaming.
(The goal is lucid dreaming)
Next, I went to bed, read affirmations and previzualizare their end
results. Then turned off the light and began the session with a disk "Hypnosis and
self hypnosis". During the session, nothing remarkable happened.
After the session got out of bed, went to kitchen, drank a glass of water and lay down
to sleep. Then I just had this dream (but I accept it as normal reality):
I lie on the floor, turn the disc "Healing" and begin a meditation session.
Closely follow the music.. And then she comes to the moment
where is pure wind noise with crickets. And at this point, I'm starting
very good to feel that in my room, where I started meditation,
actually rose a strong vortex, which started I "really"
for a blow... at First was a little scared, but I remembered
in such cases, we need to continue to focus on relaxation,
and continued to do so.. In the end felt the sensation of flying up
(leaving the body).. Then through the 10 seconds was up (as it was then too late
I understand awake in the dream).. See their loved ones, share with them was well appreciated
divisions.. And make a clear conclusion that experienced WTO and now
wind sounds for me to become the anchor for such feelings. Next dream
some domestics.. And then Wake up again, this time in normal
reality.. immediately before I forget everything, turn on the light and write everything on a sheet...
In the end, I understood that self-hypnosis worked - I really am
experienced a fantastic, transcendental feeling (the wind noise) :)))
And witnessed the making of astral projection :)))
But it all happened in a dream :) The question - why?
Andrew, please tell me, what's wrong with affirmations and I
they are now correct to test all the same in the usual
reality?
And another question for the practitioner of the WTO - you have been such to you in a dream
went to the astral plane? Although, if you argue on the basis of the teachings of the books
Carlos Castaneda, this definitely has something.. :)<
Post by Андрей Патрушев » Fri Oct 07, 2011 9:15
Denisko
You got just what you asked for. :?
Vinki bap
Post by Vinki bap » Tue Oct 18, 2011 10:08
Proper formulation of the goal...
The goal is the final expected result of the activity. There are likely about the meaning of need to write...uh.. for me Personally, the meaning of my purpose purpose to live every day to know the direction of their actions.
Post by Андрей Патрушев » Tue Oct 18, 2011 10:52
"Proper goal setting" is a statement of the purpose according to certain rules, which help to avoid blunders on the path of cultivation. The rest of this thread irrelevant. :?
Denisko
Post by Denisko » Tue Dec 06, 2011 5:04
Andrew, have a question for you:
how all the same correctly to work with affirmations?
Whether reading it, try to feel
and visualize what you read? Or just
expressive reading without mental tension
will be enough?
Just for example, when working with the program rainbow-Arc
in fact, because we do not realize what information
recorded in our subconscious mind. However, the method of 25 fps
is recognized as working.
Some books on writing affirmations, on the contrary, that
you need to feel and understand what you read..
So still, where is the truth:
1.) read affirmations, fully imbued with their meaning
2.) read affirmations unconsciously, by disabling the filter of consciousness
Thanks for the reply.
Post by Андрей Патрушев » Tue Dec 06, 2011 9:40
Denisko
The truth, as always, is somewhere nearby... :?
Better for You better. :)
Тяфа
Post by Тяфа » Tue Dec 06, 2011 23:56
Sorry haven't read everything in this thread, sorry if already asked. Andrew, please help me to correctly formulate the goal for weight loss when listening Conductor. From the sketches I got: I am always in control of your appetite. I have a beautiful, slender body. But as along as human beings, do not get all this together, and maybe even differently it :cry: bc bc bc
Post by Андрей Патрушев » Wed Dec 07, 2011 0:29
Тяфа wrote:I'm always in control of your appetite.
And even when making love? :shock:
http://www.mindmachine.ru/articles/afformations.htm
Denisko
Post by Denisko » Wed Dec 07, 2011 10:03
Андрей Патрушев wrote:Denisko
Thank you for understanding. I came to the conclusion,
it is necessary to make such affirmations,
on that when reading responds to the soul..
I really like affirmatsii..
Read and feel some positive energy
inside yourself..
But something happens as ponapishut something, read and
puzzled how it generally to understand and feel..
In General, you need to write such statements to their soul
understood..
Post by Андрей Патрушев » Wed Dec 07, 2011 10:26
Denisko wrote:In General, you need to write such statements to be desapontada..
+200! :)
Тяфа
Post by Тяфа » Wed Dec 07, 2011 15:36
Andrei Patrushev Very so much for the reference! :o :D
Инка
Post by Инка » Sat Feb 04, 2012 16:41
Good afternoon, the site I am a newbie and just recently started listening to your CDs. Andrei Patrushev, thank you so much for creating them!))
I am an aspiring writer... my goal is to write an INTERESTING book (fantasy genre), which will finish (and not catch a thing and poudalyat all written texts...) i.e., the text and content should be fully me to do (or not fill).
What I need to do this:
-perfect idea that will hook and not let go until the end, will be different from all previously written
-interesting characters
-perseverance, to not give up halfway
-inspiration
-creative...
Ie my goal is: "I published my book", but simply issue isn't enough for me...
"I published his brilliant book" ...I don't know, somehow pathetic...
"I published his interesting book" ...something wrong, just "interesting" is not enough... she needs to learn, to leave a mark,to be remembered...
"..memorable..." - she can remember and as a failed masterpiece
Besides, writing books is not 3 months, it is necessary to set intermediate goals.. maybe
"I have a great book idea that I brought to life"????
What do you think, is this statement of purpose?
Thanks in advance)
Post by Андрей Патрушев » Sat Feb 04, 2012 16:54
Inca
There are a couple of English books on NLP (unfortunately we have not translated), just aimed at this topic. One of them is "The Power Process", the second can not remember.
I think the elephant should eat in parts. Examined at the level of understanding that is necessary to write brilliant books, and start working on personal qualities...
"If you can not write - do not write". :)
Инка
Post by Инка » Sat Feb 04, 2012 17:07
Андрей Патрушев wrote: There are a couple of English books on NLP (unfortunately we have not translated), just aimed at this topic. One of them is "The Power Process", the second can not remember.
With English tugovato will...
But about quality... I think it is primarily the perseverance and dedication...
will work))
Thank you)
Инка
Post by Инка » Sat Feb 04, 2012 17:09
Андрей Патрушев wrote:"If you can not write - do not write". :)
can not))) but also to write the banality of don't want to...
Мариомар
Post by Мариомар » Tue Feb 28, 2012 21:17
Andrew, tell me: If the disc is still better to use affirmations or affirmatsii?
Post by Андрей Патрушев » Tue Feb 28, 2012 22:37
Marimar
What is the Soul. :?
Кэст
Post by Кэст » Sun Mar 04, 2012 12:32
Andrew, can you recommend literature on self-hypnosis.
