СК1М
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Mar 17, 2011 11:50
In principle, the effectiveness of the more obvious issues where there is potential for development and application of Planetary principles, and they can affect many areas of life.
On the one hand of course these devices are crutches prostheses, but can also help to evolve. Well if you do in the gym at the gym, the level of sports training can affect the application of skills in the power loads in my life without fitness equipment. Well this type of training.
Sincerely, MAG.no
Довольный
Post by Довольный » Thu Mar 17, 2011 14:13
MAG.no
What is "Planetary" principles? Only easier please :)
Post by Маг.нет » Thu Mar 17, 2011 15:25
Easier way:)
There is an internal manifestation of the planetary principles of Man, as part of the world is easier - the same Modules BJ, mechanisms which can be considered from the perspective of trenchlines model.
http://www.mindmachine.ru/viewtopic.php ... &&start=25
http://www.mindmachine.ru/viewtopic.php ... &start=100
Or symptoms considered from the point of view of Astrological or Separationthe or Runic model, etc.
Well, for example, a little explanation of the Astrological model is here:
http://www.mindmachine.ru/radionics/documentation.htm (the complete user manual for the program astrodynamical the realization of the goals).
I think just to understand...
But in any case, this is not a complete view, we can see from the other side the same.
Sincerely, MAG.no
Довольный
Post by Довольный » Thu Mar 17, 2011 18:56
Michael_
If you use one of SK+and SK two+Y and podadite on the same recording (even from single player) Audi-goal.
I think the efficiency will rise in 2 times? Then by how much? And is it worth it at all?
Post by Михаил_ » Thu Mar 17, 2011 21:00
appropriate, if the wording is still somewhat different. More precisely, in any case, the effect will grow. Perhaps less than two times, and possibly much more. The thing is that depending on the situation and its development potential, the effectiveness of the additional "pressure" on it can be different, i.e. the result depends on whether there is still room to push (well, I explained very primitive, but the point about this).
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Mar 18, 2011 18:31
Никола Питерский wrote:]Hello good people..still don't understand how this thing (SK) works..usually how things are done - the person sets a goal, forming the intention, renders..one word work, and in the case of the UK it turns out that ALL makes the device or what? ve ..so you can completely any physical shape to lose..or something I don't quite get?
As the man working out that purpose.It's not work-work is conventionally of course ,but for someone and render -great work. In any case, it is necessary to submit what you want(clearly) to draw your picture or write what you want.Or a mandala or katrid appropriate from the modulator is also possible( with the quality you want to).All of this concentration at the desired and is already working.Let's not hard but takes time. :) And pleasant work.
Post by Маг.нет » Fri Mar 18, 2011 19:06
ЛИЛИЯ-Р wrote:Let's not hard but takes time. :) And pleasant work.
...and useful... that too is not unimportant.
Sometimes you can without paperwork, and to pick up>leave for a bit, an effective state will be much>and formulate the task of>detecting if a strategic issue - b/C nail Polish in "object table", if the tactical with the possibility of adjustments - mark on a piece of paper, fixed on where we left off in the consideration of options, and notice the responses sometimes do not notice a long period of time, or adjust or reset superfluous or remove the priority.
Sincerely, MAG.no
Been thanked: 10 times
Post by Мастер 108 » Sun Mar 20, 2011 14:52
Михаил_ wrote: I think gray hair - the release of certain substances into hair which provide a fertile ground for the growth of certain bacteria, or just the change in metabolic processes that leads to a new stable state in particular hair. The process may slightly migrate and / or be stimulated by repeated stimulation from the body.
In General, all so, but this is the consequence. The cause of gray hair — atherosclerosis of cerebral vessels. And yet, Yes
Михаил_ wrote:from our Arsenal is "standard", "tablet", "cleaning the blood" -available in the form of audio and mandalas free is in the form of modules in BJ
But atherosclerosis of brain vessels may be the consequence of the infringement of the carotid arteries spasserovannye the neck muscles, which can spazmiruyutsya the result of problems in abdominal cavity — often functional disorders of the kidneys (they may not hurt, and even tests can be nice, but the kidneys are functionally impaired). A problem in the abdomen can be from the kidneys, and from colorchange (around the kidneys) space, such as an inflammation or swelling of the portion of the colon, which lies on the kidney. And this whole vicious circle starts with spazmirovannah gallbladder, because he first reacts to the stress.
In General, the modules BJ, etc. is good, but you need to work with your hands, in the sense find specialist visceral chiropractic (not a chiropractor, just in case) and go through therapy.
Post by Михаил_ » Sun Mar 20, 2011 15:06
Thank you very much, I had not considered this process. Judging by the regular evidence of recovery of hair color, with the vessels must manage shared regeneration by improving the General energy. However, this process can take a year or two. Judging by how much time I have stopped own vascular spasms that were actually from childhood (i.e. I don't remember when they were not, although rare was a phenomenon, I specially was not cleaned - very gone).
It is actually quite amusing to realize yourself healthier than in early childhood :)
well, if the vessels, then I would add in the recipe is the usual process of cold cold water, after GG :)
Post by Михаил_ » Thu Mar 24, 2011 21:44
Мастер 108 wrote:
there are MANY ways to heal yourself with all You mentioned in the picture or its parts. Some of them - for "self-production", for example AI, the part - to visit a specialist. I like being familiar with tremendous force methods sujok therapy, would recommend them:) and with chiropractic, a sign for unnecessarily. Now, the thing is that with the same sujok - it so happens that the sign is, and "specialist" to do anything, except that the sign, or that everyone can himself by reading books on sujok designed to work independently and beginners.
This is what I?
Please do not have such recommendations, at least in my section. No offense, but it looks like some is or as slightly narrow perception processes.
For example, all these problems can be removed simply with water. Well, not simple of course. Generally there are many methods, but need reasonable caution in their application. I tend to filter recommendations for the result which I cannot vouch. As people listen, do, then?
Therefore, regarding the recommendations emphasize - I wouldn't do.
Сатурн
Post by Сатурн » Fri Mar 25, 2011 16:21
05.02 priorel W1 and BJ.I want to describe one case. while attuned myself to W1 ( spinning tracks all kinds for W1) and I thought what goal to deliver.spoil about the debtor, decided to set a goal to repay the debt( 2500 rubles). should this man a long time, we do not talk with him for a long time ( you do not want us to communicate with each other). put a mental target and time. I've used the track. while achieving 14 days.reinforced track is some possibility. Turner it I have all day( 1 week), then wrote on the paper what you want( man pays the debt that is the number), a week later a call from him, his words what he remembers about the debt, and as willing to give, but requests a little wait here for just one. as he was without a job and now money is tight( and added that the work which he found he liked, found a job at душе0. and I can not understand,like, and succeeded, but the money will not see. still have to wait. wrong wording was?
Сатурн
Post by Сатурн » Fri Mar 25, 2011 17:54
people has anyone used the cartridge to the modular No. 17( back and legs.withdrawal of muscle nerve blocks the back and legs. helps to relieve muscle clips resulting from psychological trauma and disturb the work of the body) with СК1М? write to anyone what's going on.I bought it on the days I do holotropic breathing during the sessions, these clips have me very painfully manifested( those involved in holotropic breathing, I understand).
Michael I have a question for You. can СК1М with cartridge No. 17 to ispolzuyut and how best constrait?
Довольный
Post by Довольный » Fri Mar 25, 2011 18:48
I honestly have no idea how to remove the blocks in the muscles without any physical work..
Post by Михаил_ » Fri Mar 25, 2011 18:49
1. In principle, the cartridge to the modulator and not to SK, but SK will work, but my experience of usage I have. It is better to use complete with the transfer pair (be more noticeable), though it is possible and so. Just put on the stage and put in writing or mentally the impact of the program in this cartridge itself.
Сатурн
Post by Сатурн » Fri Mar 25, 2011 18:58
Thanks Michael for the reply. tomorrow I will acquire then I will unsubscribe about results.
Happy.
holotropic breathing helps to remove the blocks.maybe not as well as physical work.
Post by Михаил_ » Fri Mar 25, 2011 19:37
There is a direct connection not correctly integrated into the cocoon experience - a violation of the structures with the muscle blocks. What is the reason for a separate area of therapeutic effects - presso puncture with its varieties, among which there are close to what gives chaotrope, i.e. regressive experiences either directly or metaphorically (indirectly, but by analogy) related to the causes of the violation. I.e., a direction of psychotherapy. Everything is connected... and usually better units just removed from the information part. In any case, if the work is complete, which side do not pull the other out. Ie take the information (for example, a disk Explorer quite clearly works with this) - will receive a response in the body. Take directly work with the body, it is extremely likely that you will go social, or physical consequences, or otherwise resonate with the experience that once upon a time led to the formation of this unit.
So Saturn is mostly right.
Man is a unified whole. And mutual influence of its different guises much higher than expected now.
Man and the world - is also a unified whole.
So we just have a wider perception.
Post by Михаил_ » Fri Mar 25, 2011 19:49
Сатурн wrote:05.02 priorel W1 and BJ.I want to describe one case. while attuned myself to W1 ( spinning tracks all kinds for W1) and I thought what goal to deliver.spoil about the debtor, decided to set a goal to repay the debt( 2500 rubles). should this man a long time, we do not talk with him for a long time ( you do not want us to communicate with each other). put a mental target and time. I've used the track. while achieving 14 days.reinforced track is some possibility. Turner it I have all day( 1 week), then wrote on the paper what you want( man pays the debt that is the number), a week later a call from him, his words what he remembers about the debt, and as willing to give, but requests a little wait here for just one. as he was without a job and now money is tight( and added that the work which he found he liked, found a job at душе0. and I can not understand,like, and succeeded, but the money will not see. still have to wait. wrong wording was?
well, why not right.... perhaps it is good.
A very obvious example.
See for yourself:
- on the face of the onset of rapid human reaction, although he didn't have communication.
- on the face of it self-call, then a stimulus inside forced him to make that call
- on the face of some improvement in the situation of a person that can contribute to the solution of the situation.
- perhaps because of the wording people still found a good job, in the form of a pure side-effect.
it's just that every situation has a reasonable capacity, a limit, then it is possible to push, but only if it's vital, until the salvation of this life itself, or more importantly.... Then our subconscious mind on the situation mobilizes all resources in such a situation and SK differently react to the situation. Otherwise (household situation), SK is looking for optimal impact.
And it is the optimum usually has a limit. Here him and buried. SK is not a magic wand....
Many times we on our own experiences faced with situations that can be apparently noticeable "shake" in the right direction, but it is not always possible to solve. Ie if the decision is in the zone of fully anomalous, it is possible to not always. Especially if it is reliant on more than one person (we experimented on some business projects there, quite naturally, the impact depends on certain mechanisms, fixed at the level of "law", i.e. to change out, until the level where you need a complete anomaly to go further, breaking many times and not a single behaviour is fixed by the instructions for many people, not one. Of course there was the stopper. We acted completely within the law, but wanted to help the projects leaving beyond the current situation in viability objective)<
Post by Михаил_ » Fri Mar 25, 2011 19:55
From the point of view of the above, SK is more effective where less restrictions.
For example. Debt repayment can be divided into two very different tasks:
- want more money and be sure for what, since, as has been said many times, the goal for money for money doesn't work for our subconscious and is typical is not correct wording.
- want to eliminate the trace is completed the relationship with a former friend.
Ie, on the basis of this money you could get somewhere else "by accident", but a person to make up for it or just forgive him and forget about the situation. And this may be easier for IC in General and to implement the decision. The coupling of these two really unrelated things, is a bit far-fetched and complicate the solution, making it less flexible.
The greater flexibility inherent in the wording, the better. However if the life becomes more unpredictable and volatile, and the operator is required readiness for these changes.
Сатурн
Post by Сатурн » Fri Mar 25, 2011 21:58
Michael thanks for the clarification. but there were examples in my experience but they are BJ. rather when worn still version 2.0. on the forum http://openmagic.org read User guide ( this page http://openmagic.org/ph/showthread.php?t=94) there is this:"Activate the module "pass air", target: achieving well-being in all aspects of life in the best possible way". in General I set a goal and when there was a very( as I then understood it) is favorable for my situation. I wasn't ready for it. indeed the operator is required readiness for these changes. here and now I want to buy BJ 2.1. reading the description, and revoke it's probably something that we need to be ready to change. what kasaetsya of cartridge No. 17 reason he wants to buy it after I began to wear BJ 2.6. these clamps are well, just durom climbed( disk Explorer already 3 years I listen periodically). and if I wear 2.1 is probably all will grow or increase.of course this can be mitigated with the help of holotropic. but there are things should not be rushed ( recommended 1 time per month at most, although I violated those rules). well, let's see what happens.
Довольный
Post by Довольный » Sun Mar 27, 2011 14:43
Michael_
1. Higher efficiency SK+At SK or two?
2. At what distance should stand apart SK+Y when executing the same goals and different goals?
Post by Михаил_ » Sun Mar 27, 2011 15:32
1. it is not possible to compare.... well, it's like two processors in the computer or a fast video card.... what is more important? depends on the task.... don't know, but potentially SK+Have more powerful....
2. SK and I are on top of each other (IC is on) in the video is there. Other devices or additional SK associated with the Amplifier, are within a radius of 1-2 meters from the U.
Ольга К
Сотрудник mindmachine.ru
Been thanked: 17 times
Post by Ольга К » Tue Apr 05, 2011 14:21
My story))
For a long time I'm trying to get our landlords to put the car into the Parking lot, not outside..somewhere on the highway..all Refer to the lack of places (although there are still five pieces will be included) Submit all application for a permit of my car, slowly adding it to the previous list...and a fool submit...and again failure..
Think Ah so?...well, and put his "long-awaited desire" on the device IC. I worked with him, tuned we're together...and forward. A week passes...comes back a failure..
Well...and I thought, let him lie down. Suffer more..
It turned out that one of the staff we changed cars, and again you need a list to carry on the shift plate. And again slowly entered my room...And suddenly you're lucky...
And oooo miracle (it turns out that this is the case), our employee comes and says that the chief was fired for..."raspravlenija" with the responsibilities...and that my car probably now fit into the overall list...new boss, new rules..
And now I see...next-next dawning hope...
Summary: my car is in the LIST!!! Hurray!!
Сатурн
Post by Сатурн » Wed May 04, 2011 18:05
Hello Michael. I have a question for You. on this thread have repeatedly mentioned the program to СК1м.it ever will be released for users СК1М
Post by Михаил_ » Wed May 04, 2011 18:13
Yes, someday it will be released.
Сатурн
Post by Сатурн » Wed May 04, 2011 18:41
sorry that is not soon, but it does not work properly or very difficult to formulate goals.
