Advice from Andrei Patrushev
толяныч
Post by толяныч » Sun Apr 26, 2009 17:45
Tell me please, when I put on the drive a Hypnotic Trance from the Theta Meditation your suggestion for 15 or 20 minutes before the end of the disk to carry out the regression or progression within this jisne I'm not interrupting the rhythm and sound of the signals on disk immersion into a hypnotic trance? And one more question. Can I assume not to impose on the disc your suggestion in order to implement the regression or progression within this isnie, such as to listen through (the player in the headphones) the recording on a disc a Hypnotic Trance, and through the speakers to listen to your suggestion to implement the regression or progression within the present life, with respect, Toljanic.
Post by Андрей Патрушев » Sun Apr 26, 2009 21:35
толяныч wrote:Tell me please, when I put on the drive a Hypnotic Trance from the Theta Meditation your suggestion for 15 or 20 minutes before the end of the disk to carry out the regression or progression within this jisne I'm not interrupting the rhythm and sound of the signals on disk immersion into a hypnotic trance? And one more question. Can I assume not to impose on the disc your suggestion in order to implement the regression or progression within this isnie, such as to listen through (the player in the headphones) the recording on a disc a Hypnotic Trance, and through the speakers to listen to your suggestion to implement the regression or progression within the present life, with respect, Toljanic.
I wrote about 15 minutes from start... :)
Can with the speakers as You prefer.
Post by Guest » Sun Apr 26, 2009 21:48
And I realized that only at the end you can apply the suggestion well, that said,but it would not properly understood. So it is possible to impose from the beginning 15 minutes. I will try with speakers as it is more comfortable, thanks for the reply, sincerely, Toljanic.
вовка
Post by вовка » Mon Apr 27, 2009 16:18
Andrei Patrushev
Please tell me how to listen to Thompson. I just have Music for Brainwave Massage (Inner dance part A, Inner dance part B, Аwakened focus, Tranquil awareness). You need to listen to all at once or by parts, in the morning or anytime? This study
Post by Андрей Патрушев » Mon Apr 27, 2009 16:32
Before learning Аwakened focus, after - Tranquil awareness
вовка
Post by вовка » Mon Apr 27, 2009 17:48
Andrei Patrushev
Thank you!!!!!! Another question: listen to relaxing, or something to do? How many times a day can I listen? And what is Inner dance and what is it?
Post by Андрей Патрушев » Mon Apr 27, 2009 18:14
вовка wrote:Andrei Patrushev
Аwakened focus - you can do training material (if not prevent), Tranquil awareness - better than a relaxed, Inner dance - to stimulate creative activity (somewhere between sessions). To listen better every day.
Никос-В
Post by Никос-В » Tue Apr 28, 2009 23:47
Good evening, Andrey! Tell me, please, after the course (21) listening to the disc, the Explorer immediately began to have nightmares (every night), although during the course of such dreams do not arise, dreamed of a normal, pleasant dreams.
Should I continue listening to this disc, or may be any advice to rid of nightmares?
Post by Андрей Патрушев » Wed Apr 29, 2009 15:44
Никос-В wrote:Good evening, Andrey! Tell me, please, after the course (21) listening to the disc, the Explorer immediately began to have nightmares (every night), although during the course of such dreams do not arise, dreamed of a normal, pleasant dreams.
Hello!
Is there a common theme in the nightmares? How was the sleep to the Conductor?
ММозг
Post by ММозг » Wed Apr 29, 2009 17:39
Hi Andrew! As I understand it in most meditation practices the main purpose is to achieve so-called "zero" level of consciousness. The same can be reached through MM. My question is the following: is it possible to simultaneously listen to the alpha session or the disk Explorer and meditate as I used to do it, muttering the mantra to herself? I ask because I bought Innerpulse and drives Conductor, Healing Endorphins and solar wind 4 days ago. When listening constantly distracted by some thoughts. Now I use only R-session and guide for the morning and evening. The Conductor can't hear/concentrate on the text or climb different thoughts or fall asleep. In advance of blagodar for the answer.
Никос-В
Post by Никос-В » Wed Apr 29, 2009 17:51
often have dreams with zombies and such wickedness... :? without a Guide for 9 days and every night something, Yes like that... (the state of mind in everyday daily life about the same before and after the "session") To listen to the disc dreams were normal - diverse, without narekaniy about the horrible theme! Of course, I try to remember and sopostavit what is this situation other than Explorer, but is to mind or what comes, especially since the nightmares began to dream the first night after...
Никос-В
Post by Никос-В » Wed Apr 29, 2009 20:52
Malenjkoe clarification about dreaming about zombies and sometimes conflicts bright (which just Wake up) which seemed to be all any relationship I have...
Алексей C
Post by Алексей C » Thu Apr 30, 2009 9:57
Hello dear Andrew. I have to WA a couple of stupid questions :)
1.I read on the forum about theta drives and do not understand...They need to listen without the mind of the machine(without glasses)?
2.Disk Explorer is the alpha?
Зоренька
Post by Зоренька » Mon May 04, 2009 1:23
Dear Andrew. Going to Moscow for Your discs. Is it possible to learn this morning of "Conductor" in the evening before bed to heal, in the middle of the day MM? Well, I've got time. And I want everything at once :oops:
Саша 2
Post by Саша 2 » Mon May 04, 2009 14:20
Good day! Can help. I've been listening to Theta disks(5 disks) and the solar wind. Impressive. I liked it. The effect is impressive.
But...the body was like a sleeping, lethargic , relaxed. Can the hearing of theta waves to affect the erection. Women like a lot, and even more drawn to them, but with an erection as was not very. Type the body does not want. Can I listen to something with beta waves or something else will advise me.
Post by Андрей Патрушев » Mon May 04, 2009 15:52
Саша 2 wrote:Good day! Can help. I've been listening to Theta disks(5 disks) and the solar wind. Impressive. I liked it. The effect is impressive.
Erection directly from the theta condition is not connected (for example, the strongest erections in the morning, just the background theta), and tied to Your overall tone, which, of course, blame an excess of theta waves. All good, that moderate. :) Beta should first be familiar. But you can do it now. :)
Post by Андрей Патрушев » Mon May 04, 2009 15:53
Зоренька wrote:Dear Andrew. Going to Moscow for Your discs. Is it possible to learn this morning of "Conductor" in the evening before bed to heal, in the middle of the day MM? Well, I've got time. And I want everything at once :oops:
You can... :)
Post by Андрей Патрушев » Mon May 04, 2009 15:54
Алексей Семенов wrote:Hello dear Andrew. I have to WA a couple of stupid questions :)
1. Yes.
2. Yes.
Post by Андрей Патрушев » Mon May 04, 2009 15:59
Никос-В wrote:Malenjkoe clarification about dreaming about zombies and sometimes conflicts bright (which just Wake up) which seemed to be all any relationship I have...
From the Conductor dreams are usually dreaming with a strong educational theme (You're there all the time, you will learn something). Specific content depends upon your condition and personal characteristics... Often topics similar to nightmares, dream when there is an internal (sometimes deeply hidden) fears, and nightmares she's different just by the availability of exit but not of hopelessness. The dreams usually begin to dream immediately after the first lesson and lasts from 3 days to a week and a half...
Post by Андрей Патрушев » Mon May 04, 2009 16:01
ММозг wrote:Hello Andrey! As I understand it in most meditation practices the main purpose is to achieve so-called "zero" level of consciousness. The same can be reached through MM. My question is the following: is it possible to simultaneously listen to the alpha session or the disk Explorer and meditate as I used to do it, muttering the mantra to herself? I ask because I bought Innerpulse and drives Conductor, Healing Endorphins and solar wind 4 days ago. When listening constantly distracted by some thoughts. Now I use only R-session and guide for the morning and evening. The Conductor can't hear/concentrate on the text or climb different thoughts or fall asleep. In advance of blagodar for the answer.
Of course you can... But you can just sleep under the Conductor. :)
The thought is good. :) Just watch them as if from outside, marking the start and end of each...
Зоренька
Post by Зоренька » Mon May 04, 2009 19:14
Thank You, Andrew. Another question: during the acute illness (sudden this happens) continue to listen to CDs? Or wait a little?
Post by Андрей Патрушев » Mon May 04, 2009 21:15
Зоренька wrote:Thanks, Andrew. Another question: during the acute illness (sudden this happens) continue to listen to CDs? Or wait a little?
To continue...
Post by Guest » Tue May 05, 2009 11:37
Andrew, and what session it is advisable to listen to from the Beta waves? It is possible to register here?
Сима
Post by Сима » Tue May 05, 2009 19:33
Good day!
Andrew, could you comment on the situation. Started listening to this CD for the first time 4 days ago. During the first session tried to understand the meaning of the text, in the end, at the end burst into tears. The next day, all the time in my head popped the phrase from the disk are different. Now somewhere on the forum I read that it is better in the sense of not to think about it, and the effect can be lost. So it's my case or what? :?
The other 3 times in the sense of not ponder, just had different images and thoughts. Often just jumped back into reality. And I want to keep the status... :) I care more that when listening to the body sometimes sharply twitches, I want to change the position. Is it possible to turn on the side or as convenient?
And at the end of the session somewhere, there are attacks of irritation, do not want to hear more. This, I think, straining some muscles and I fly out in reality, trying to relax for a while, sometimes a long time. Then, after a period of alpha status, again, apparently tense, but other muscles (mainly in the neck and throat). In General, you want to stretch, to limber up, as if the body was asleep. What to do in this case?
Сима
Post by Сима » Tue May 05, 2009 19:39
Oh, sorry, didn't mention the disk is a Conductor. :) Another question: in which mode, and which disk is it better to listen in violation of the biological rhythms of sleep-wakefulness. I have for some time led a nocturnal, now it is very difficult to adjust to normal. :roll:
