Post
by Кобра » Sun Jan 30, 2011 4:33
Hello, listened to 15 consecutive days of MM in the morning and before bed Healing. MM from feeling positive, pleasant relaxation, feet why it becomes terribly hot inside and under the navel a strange vibration, and the body is relaxed, after listening I want to first stretch, and then curl up and take a NAP. But with the Healing of all as it is not very first effect is the same as with MM but since mid, when there are cicadas, this irritation takes these sounds I can't normally take, I want to rip the headphones from your ears, throw them away and stand up, stretch their legs, as if to shake off these nasty sounds, but I overpower myself, forced to listen, eventually Wake up, when there is already next track (Star wanderer), although I have a feeling, I never was knocked out, but listened to every sound, waiting for the end of torment... So it was about 10 days, then it became easier, the sounds are still annoying, but neither to such an extent and the end do not miss. And strangely, I am constantly engaged in swimming and fitness, in the evening usually do stretching and studied belly dance or any other, but after 4 or 5 days of auditions, completely fell off the desire to do something physical, terrible lazy and have always want already gained 4 kg(( In terms of brains say there is nothing, nothing until the test.
Now would be a break of 15 days, then again 15 days I will listen to MM in the morning, evening Healing. I have these 15 days just to relax, or you can start 15дневный course for example of Endorphins and Brain?
