Арго
Re: Stream. The basic features and rates.
Post by Арго » Sun Jan 26, 2014 22:51
integrated mode is the new - can help in language learning ?
Артур888
Has thanked: 7 times
Been thanked: 5 times
Post by Артур888 » Mon Jan 27, 2014 1:05
What is the difference of IP work with the weather and weather control ?
Post by Михаил_ » Mon Jan 27, 2014 1:15
Арго wrote:of the integration mode new, can help in language learning ?
maybe
Post by Михаил_ » Mon Jan 27, 2014 1:16
Артур888 wrote:what is the difference of IP work with the weather and weather control ?
management controls as a reasonable opportunity and work - uses personal trends.
арте:м
Been thanked: 8 times
Post by арте:м » Tue Jan 28, 2014 1:52
Михаил_ wrote:in General, this topic will be addressed in the club's broadcasts.
It turns out that's, to me alone it is not clear what does the term "broadcast club"? :)
Артур888
Post by Артур888 » Tue Jan 28, 2014 9:44
Club (from the English. clob or club using it. club) is a meeting place for people with common interests (business, informative, educational, entertaining, collecting, etc.), often formally United in the community, organization, or Association. Usually takes some room and is used for regular meetings and communication of its members. There are virtual clubs.
львёнок
Post by львёнок » Tue Jan 28, 2014 15:07
Артур888 wrote: There are virtual clubs.
bi Chaachu to participate in this virtual (and not only :wink: ) Club !!! :oops:
Post by bofara » Tue Jan 28, 2014 15:32
When I really want riot to go, but it turned out that I'm colorblind and in General for the army no good. So.. we are All different.. :?
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Tue Jan 28, 2014 16:10
I'm way in the army did not go because of flat feet, but I think it's not by accident :?
арте:м
Post by арте:м » Wed Jan 29, 2014 0:14
The abstraction of the branch is increasing rapidly :)
To answer in style: "the club broadcast is a particularly powerful variety, intended for users with experience in commercial broadcasts from six months and accustomed thus to high loads" - was not so easy! :)
СтАвР
Post by СтАвР » Wed Jan 29, 2014 0:20
people teeth, all this is irrelevant to the topic...
Алега
Been thanked: 3 times
Post by Алега » Thu Jan 30, 2014 2:10
Michael,tell me-mode "capsule" in the UK somehow affect the stream?
Post by Михаил_ » Thu Jan 30, 2014 16:31
Алега wrote:Michael,tell me-mode "capsule" in the UK somehow affect the stream?
nope, there is no opportunity for it nothing to influence :)
Post by Михаил_ » Thu Jan 30, 2014 16:33
well, it turns out that the theme will be disclosed in a timely manner.... is seen a little earlier.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Thu Feb 06, 2014 0:55
1) does it make sense to broadcast a product that requires explicit control, such as a Stabilizer, a man who won't know about it and will not use it deliberately? It is clear that, given the cost of the item is relatively rare, but it can still take place - for example, a business partner that plays an important role in my life, and just a good person, but in magic without believing.
2) When broadcasting the same Stabilizer, in the absence of experience with the physical analogue, you can immediately start working with the broadcast, or it makes sense to give the time to it more tightly prescribed?
3) To what extent the size of the object remains effective stream FE "House"? It is clear that with the apartment and a private home would work effectively, and if you try on a residential apartment building or the front door (well in my apartment was affected, it is still part of the house, anyway)?
Post by bofara » Thu Feb 06, 2014 4:06
1.Of course.
2. Yes.
3. In my opinion depends on vosstanovleniem operator.
Андрей С.
Post by Андрей С. » Thu Feb 06, 2014 17:08
2. Yes - immediately or wait? :)
3. And in my opinion, given that the stream goes to the object, the operator then vosstanovleniem factors are secondary.
СтАвР
Post by СтАвР » Thu Feb 06, 2014 17:44
1. I believe that stub as the UK and the range, it is not necessary to broadcast to the one who does not know and will not enjoy, better then AMB
V4 maybe
About stalba, if I'm not mistaken, the test broadcast were those who did not use physically and everything is fine, but generally you can with broadcast to start, just worth recording that is, and I'm not writing, then it was fun :)
Regarding the broadcast of the object, so you still stream radiate and affect the surrounding the apartment :?
Андрей С.
Post by Андрей С. » Thu Feb 06, 2014 20:56
So, on the first point, opinion was divided :)
About the record is clear, and here's another thought - if you make a schematic sketch (well, a circle with sectors) and to put there numbers on the anchor, just for clarity - so you can do that or not?
СтАвР
Post by СтАвР » Thu Feb 06, 2014 23:46
so why not make a paper stub and on it place, I remember bafara somewhere I posted the file with a stub which can be printed and anchors were there
Андрей С.
Post by Андрей С. » Fri Feb 07, 2014 0:23
I on the contrary had in mind - do not turn this sketch into a mini-stabilizer, as the physical I don't need it :) Sketch just for convenience...
СтАвР
Post by СтАвР » Fri Feb 07, 2014 0:27
did not understand then what you mean in the way to do it
I do not soared, simply saw the stub in full and placed where I need
Андрей С.
Post by Андрей С. » Fri Feb 07, 2014 0:40
Well, I mean, I would be more comfortable not only with words write - "the anchor of the No. 1 object so-and-so in the aspect of such posted on the program protection in the sector Neutro-Heterosexual just to the left of the Development", and to sketch this schematically - circle, sector and the value to deliver. Just not to forget - so clearer than a list of dozens of items.
update.
All delved into the theme of the Stabilizer, understood, sorry for offtopic :)
СтАвР
Post by СтАвР » Fri Feb 07, 2014 0:45
look, take this picture http://openmagic.org/st/st.jpg
and it using a graphic editor mark
Post by bofara » Fri Feb 07, 2014 8:14
Stabilizer can be used only passively, assuring he still works.
Don't see any reason not to start working consciously at once with the broadcast Regulator, the more some subconscious sometimes raskazano too well and understands /uses the health/ such things as Stabilizer. Michael gave similar examples with people who did not really know what it is, but 'suddenly' understand how to work with this stuff.
On point 3 I meant "the fact that the operator considers his house." It is theoretically possible, IMHO, if the operator is recovered enough, the whole planet Earth to perceive it /operatorsky/ as your home, right? I personally, about love, to be felt at work in the house. About assuring the key - man broadcast and prescribed excellent "House", but he then after some time changed the physical body are then spelled out the stream - in the "old" house.. or I Hope it is clear.
