Small offtopic.
Has thanked: 24 times
Been thanked: 142 times
Re: Small off-topic.
Post by Маг.нет » Fri Aug 09, 2013 13:45
Маг.нет wrote:Everyone is different and their bodies and often to bring under one system is difficult, and sometimes and not useful.
watch yourself (such a list can create external "navedeno" - samouverennyj illusion), especially dangerous, irreparable, there can be nothing system BJ "high ecological" (with booolshim stock), although voltage can be generated, manifesting itself through a chattering of health or situations (it is not the fact that definitely harm, when considered in the long term, but the best voltage to look for and choose a milder way when they are in sight, with possible variants).
Yes, and it is useful sometimes to disable the logic, it is not always appropriate - may interfere with and distort the perceived, driving under templates.
Sincerely, MAG.no 〠
Алхимик
Post by Алхимик » Fri Aug 09, 2013 15:51
So I'm about the same. Michael wrote that he is a big reinsurer and tried a lot of things in BJ in terms of security. And at the same time, often "scary" :)
Most likely he's right, because people are very different.
Thank you for your answer, I heard what I wanted :)
Post by Михаил_ » Fri Aug 09, 2013 16:02
now there are no such versions, so you can't wear immediately, but the scheme 2.2-panacea-3.0-PK-OZ-frm (in the options on the other version 2.x and various other products along the way) will be more effective and milder for many (or analogues bespltnye)
can otherwise AMB-PCs-3.0 OZ-frm
in General, almost always better to start with minor versions. to PC and three-pointers, at least with panaceia.
people for whom a three-pointer from the norm I've seen only a couple.
time - very individual, for some years, for someone a couple of days.
So, Yes, focus on yourself....
Post by Михаил_ » Fri Aug 09, 2013 16:24
Алхимик wrote:So and I about the same. Michael wrote that he is a big reinsurer and tried a lot of things in BJ in terms of security. And at the same time, often "scary" :)
Well, Yes, I'm a big freak ... so the fact that I'm posting this to put it mildly, not very ordinary things, so what is there to safe somewhere, you know, if I was not a reinsurer, I would have long lived next incarnation :) and hardly had he lived on middle school age :)
On the other hand I'm not the only reinsurer :) so all of this appears including in free access.
Look for a middle ground in myself. We should not forget about safety (including the need to remain in a normal state of mind and not to go roof), but also to sit idly in our time is also contraindicated :) (no matter where).
And you know Lazarev with Schatz has done it like him... http://yandex.ru/yandsearch?text=%D1%82 ... %B5&lr=213
I am quite far from politics and out of it completely, although the guys I am genuinely cute and I completely understand them slightly assuranoe for our time decision. I remember reading LJ Tatiana - "I sat in the kitchen all night, and discussed - it's time knocks... what is there to do there?, if not blame, then what can we do here???" The guys pulled fuse, they spat including personal safety, which of course pose a very real shock and invented the slogan "go down to the level of our audience" (i.e. on the knees). It is, if you break away from the situation here in its single plane evaluation (I repeat - I am very far from politics), in General, shows the real state of most of the population on the planet, not in relation to power or some of its excesses, but in General to respond to what can or should disturb people. Well if symptoms, many internally used to pass by, trying to ignore and be on my knees even in the shower.<
Алхимик
Post by Алхимик » Fri Aug 09, 2013 17:27
Michael, what you are doing too much reassurance can not be, because there will always be people who have "all wrong, why didn't you tell me"...
But Schatz and Lazarev annealed :D super!!!
Михаил_ wrote:we must Not forget about safety (including the need to remain in a normal state of mind does not go to roof)
Some personal stuff: never tried drugs, doesn't work on me hypnosis, I'm strong enough and balanced person, with sensitive to place, time and energies. Based on all this, sometimes you just want to experience something from the category of the ordinary, even on LSD once thought... :oops: Maybe BJ will, but maybe not...
Михаил_ wrote:but to sit idly by in our time is also contraindicated (not important where).
Well, it's at any time in the universe only two ways, either degradation or progress. Staying in one place does not happen. Just now it is most strongly manifested in my opinion.
Алхимик
Post by Алхимик » Fri Aug 09, 2013 17:49
Now printed on a b/W printer several superimposed matrices on your home site http://magic.s-a-p.in/map-generator. Spouse first, "covered", and then already nauseated beginning. And "covered" after 2-3 seconds after printing.
How long does the effect of the resulting image? Yet not destroy it?
Another question. Yesterday the wife took the bracelets (1.0) rubbed his hands and said between his palms formed a ball of energy that really felt like a kind of elastic substance, when approaching hands it springy. Her issue was that her idea or what?
Post by Михаил_ » Fri Aug 09, 2013 17:58
1. and who said that destroying an image will stop the action? and applying and printing with only a stimulator of the start of the process and not the bundle with him. No cords no - You process has started and it is not in the photo and the printout, and in a particular area. If called zero to three and called an ambulance, then what You laid then, because the call does not cancel by itself?
lasts indefinitely (effect blend), well feeling present then blunted of course due to the habits and clean up their own problem areas.
2. well, it's kind of the classic test for a sense of everki between your hands everywhere described, that here is not the usual.
Алхимик
Post by Алхимик » Fri Aug 09, 2013 18:04
Thank you for the quick reply! :)
Красавица
Post by Красавица » Fri Aug 09, 2013 19:52
Do I understand correctly - :) if the generated images do not print and store on a computer in a separate folder - also acts?
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Fri Aug 09, 2013 20:11
Красавица wrote:I understood correctly - :) if the generated images do not print and store on a computer in a separate folder - also acts?
Even if you don't keep working.
Красавица
Post by Красавица » Fri Aug 09, 2013 20:29
Andrew S.-Thank You! :)
Алхимик
Post by Алхимик » Sat Aug 10, 2013 3:12
Андрей С. wrote:Even if you do not keep working.
And what is the reason that "covers" only after 2-3 seconds after printing on the printer?
Post by Михаил_ » Sat Aug 10, 2013 3:44
the printout on the printer, copying a file from media to media, the re-imposition of the same photo one more time and so on - it all "kicks off" the process. As it repeats it. With the different options give slightly different results. Printed - kicked :) went opanasivna (or whatever in your case is selected) site or person. If it was the case again went to a better level. The process is not instantaneous and inertial time. As if to pour a bucket of cold water is how many lasts and senses are developing - have the first, second, and so on. And water "flying" may the moment but not instantly.
There are about the same.
Post by Михаил_ » Sat Aug 10, 2013 3:45
Ie the manipulation of photos (already obrabotany), exactly as the treatment, starts the process of processing the chosen object. You can say so (this is the most accurate explanation). That is, the action is just the "start" button and not the processing itself, but a process, like a wave, has some time to develop.
Exactly as in the "relaxation".
Post by Михаил_ » Sat Aug 10, 2013 3:47
For example.When processing large monolithic buildings through the sticker process goes fast but apparently (seconds) and then another few weeks "makes" energocor main.
Алхимик
Post by Алхимик » Sat Aug 10, 2013 6:07
Wow! :)
But there is a limit to "charge" for the place? Ie if you run the process in automatic mode with the pad matrix in the photo space, will there be a time when there will be "saturation" and the overlay process would no longer be effective?
Post by Михаил_ » Sat Aug 10, 2013 12:02
well, of course it will come (the limit). or balance in real time.
Алхимик
Post by Алхимик » Sat Aug 10, 2013 12:06
Then another question:
I took a picture of his wristwatch made BJ as 1.0 plus the matrix "P".
The photo is repeatedly processed through the imposition of 2.1.
What is the result I got (quality and strength)?
Post by Михаил_ » Sat Aug 10, 2013 12:16
it's like "I cooked porridge from axe that I got, porridge or wet axe?" :)
well, after maticni panacea it was the panacea (and she do not care I think 1.0).
after applying 2.1, it probably has slightly changed his action in the direction of panacea adapted to work 2.1 :)
since
-BJ P version over 2.1 is not overwritten
processing a single frame from a 2.1 this is a very primitive analog 2.1
ie well naponelli lightly on the panacea and she went with some qualities 2.1 (FOR adaptive and perceived your actions as the programming of its work under the algorithms 2.1), but why would it not just make mental?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Sat Aug 10, 2013 12:23
Operately in South Africa Stolowe mountain in Cape town , Cape Agulhas , where two oceans meet, the Cape of Good Reliable -the lighthouse and the paws of a lion (ibid) and many more places. Took out the stones, as a transfer pair. So at first they gave very weak signal. But it's been six months and charge spread throughout what was applied, now the stones kicking hard. Here the objects of nature and places of power)))) Although all the water, and is associated with water ,spread faster charging. Well it is note)) . In General, to take these same pictures openzone matrix using the generator to impose a Cure the same , then the effect will be stronger. Don't really understand how I want the places of power . Just as natural objects rather clean. What's the application for something.
Алхимик
Post by Алхимик » Sat Aug 10, 2013 12:51
Can someone tell me... Have access to a laser with a normal resolution for engraving different in the flesh to burn photos as it is better to use for making BJ?
Post by Михаил_ » Sat Aug 10, 2013 13:35
does :)
Алхимик
Post by Алхимик » Sat Aug 10, 2013 13:52
I'm probably all tortured, but still...
There is a treatment room in which the spinning "pinwheel" of Rinat. "Charges" of different creams, medications, etc that is used to rejuvenate the ladies coming to the session.
I advise the honourable audience to improve the process of "charging" of drugs?
Post by Михаил_ » Sat Aug 10, 2013 14:10
a panacea for youth obviously like
Алхимик
Post by Алхимик » Sat Aug 10, 2013 15:53
Thank you Malik, but I already read many times.
I'm interested in the letters "PC."
