Stabilizer.
commercial this gggggreat
especially one that macro (it is in the price list are not).
ВикторРусс
Re: The Stabilizer.
Filled
With some oddities. The resin was heated non-uniformly, in the Heterosexual sector felt the temperature higher than in the rest of the hot mixture from the middle began to flow into the sector Homo and slightly to the sector nacro, the wax began to melt, emit a scent and go after the resin, then calmed down and began to harden. Right ear I blushed for some reason.
At this point, I have a deep sense of satisfaction
from the work done, like I'm a long way from everything and a miracle happened went on to do business.
Around the evening of the same day I found a strange crackle from the stabilizer. Resin padstyle ,and the glass cover cracked, and the area Neutro glass cracked very fine , and especially under the labels directly into crumbs, as if pushed from the top down, but thanks to the bezel rests...
Anomalies: pieces of wax swam into the area neitro, and the top in the area nytro was 1mm crack in the resin to the bottom closer to the edge along the entire area, if the connecting edge separated...
In General, if the stabilizer is out working and there are no contraindications to its use I would from the bottom stuck a second lid for integrity and would be carefully filled with epoxy tresino.
pictures temporarily lay out:
Re: The Stabilizer.
I said that the cover will crack? .... who would have listened to me
ВикторРусс
Re: The Stabilizer.
And the crack on the surface is the health impact?
Can it pour epoxy? or just leave?
Re: The Stabilizer.
I don't know.... but I don't like
Re: The Stabilizer.
try to pour from the cracks but in theory they should not be there.... I would be better disposed of, there too complex relationships with you, and the cracks are not in the filled layer and how they will affect your mind very difficult to understand.
ВикторРусс
Re: The Stabilizer.
Ehh uhh better burn
overdid it a bit with a desire more powerful, much of the sector Neutro itself cracked and broke into fine crumbs glass under it, and when at a shop printed matrix and were eager to get their hands on observed anomaly with electricity, I caught myself thinking , what am I so tense...
Re: The Stabilizer.
Is it possible in the future to cover the cardboard stabilizer varnish?
(the problem is that he's the sixth day...)
Make anchors on a double Scotch and permutation (adlake anchors) of the cardboard-labels can be damaged...
The stabilizer feel sympathy and want to keep.
Re: The Stabilizer.
you can quite.
ВикторРусс
Re: The Stabilizer.
Lacquer is not the best option,from it the image floats.
Tell me how to use the program for stabilizer “ health“?
Re: The Stabilizer.
And instead of varnish would you recommend? (there is PVA, the tape was no better, or maybe a certain brand of varnish)ВикторРусс wrote:Lac not the best option,from it the image floats.
Re: The Stabilizer.
Another stupid question
Decided the topic of the stabilizer.
Put process (the organization) to stop, it's been a week and a half, now I can not understand in what state the process is...
As the saying goes, someone's missing, who somehow did not raise this issue, and someone he didn't raise (because and so happy with everything).
The process directly involves me, I want to check up on him (but don't know how).
(on the physical level, called around and went to whom just maybe... I can't say anything...)
Re: The Stabilizer.
Canned - in stop (while looking for alternatives)...димыч wrote:all is calm enough, except for the fact that the company in which I work is recognized as a loss and decided to conserve...
(we are unprofitable can not be - the price of the entrance and exit times in 6 different... but we have optimization
Re: The Stabilizer.
The stabilizer is very good at helping our logic to understand that the world is not quite the same as it represents the majority.
Especially when I explain "coincidence", "it happened so", "well, who knew"...
In the case of the stabilizer I see what you're doing and watch the result...
Suggests that people placed in the "limitations" and you don't know...(shows just a small part and attention to her hard bound...)
Re: The Stabilizer.
exactly, and the restrictions are very strict and when one of them spontaneously turns out it is trying to start to beat on everything that sticks out, including family members, work, coincidence, etc....
fortunately there are people with whom this happens (find a way to come out quite abnormally and it goes under "attention" because it's not as "direct view" but rather scanning anomalies), and in the case of BJ is the same - the process is faster than attract attention, or it is generally not involved, because the changes and the tools themselves are not visible and sustainable.
can't even imagine how the situation started, that is why I say that people can almost all speak "about the development of" for the most part funny, need to talk about removing blocks first.
I see their trailer....
ВикторРусс
Re: The Stabilizer.
Michael wrote something like that in the water in which floats stabilizer (latest versions) can put the puck "KV"
and how else to improve this water ?
charge the water with "the chopper Rinat"?
structure matrix BJ,Panacea,Panacea-youth?
shift the ORP closer to the 0 mark?
even maybe like, salt...
Re: The Stabilizer.
it is not necessary to invent anything besides what is said, I immediately gave the correct instruction.
Re: The Stabilizer.
VictorysActually perceive a stabilizer such as a bowl (not just the disk) - you can even say see...(maybe unwanted glitches)
To change the environment on the back side - it is difficult to predict what will...
Re: The Stabilizer.
just someone is continuous the awl up... it is good when the perception of a little podosinovets, otherwise you can be mangled wood.
Re: The Stabilizer.
3rd morning in a row waking up with thoughts about what you need to do the Stabilizer. Apparently, it is
Re: The Stabilizer.
funny... and what is it? only saw the usual...
