About the parlor
You were given the opportunity to try and to experiment without paying for the room. And you miss the opportunity. Where is the stupid question you saw? Wash you all your stupid ask and even those who don't want to notice the obvious signs and improvements.Жека3000 wrote:LILIYA-R wrote(a):
Why do people always vrednichaet and asks stupid questions?
Such as Your...?
LILY-P wrote(a):
Experiment to make all the statistics And then it works.
And You made up?
And came to the conclusion...?
Can Your statistics to see/read?
I made statistics and already wrote more than once about the results. Checked for those who know and not telling them about what I used and all of the Parlor. Yet it is not manifest leash and then spoke.To fiction self-hypnosis or suggestion from the outside. And I know these people and saw the changes and not just talk I say that the results have been noticeable.
The student and the doctor had to do every strongest poison. And here the student gave the teacher the water and he believed that his student has surpassed t he really learned a lot. And died after drinking that water clean and believe beforehand that it is poison. And died. And died from the poison of his thoughts. That's what I wanted to say. You all get to the words. Databytes to the front room and ask her your pressing questions and the answer will come in the form of situations or people that you answer this prompt. Just learn the signs to spot. All of you will be....Александр79 wrote:witch doctor drank clean water, and died from the poison instantly. But first, the student told him that he of the clean water died.
Did not understand )))
Those who were at the seminar this time so I will not say I'm sure. Because many felt that had no idea. And it's even the other felt. So powerful was the energy. And when in a team, to build a common structure of interaction that's pretty amazing.Василий_V wrote:Yes I agree but any even biologicheskii the device has properties to lose tobish spoiled. Here's the tool for adjusting the front room.
so I say that there is a feeling that not only configures the port, or does nothing at all..
Maybe those who have some reason it seems that does not work with the Parlor's possible that people are generally Niska can't build a normal relationship. Or build them through denial. Then there is another method. Tell yourself that you do not believe and to add-I don't understand how it works and what needs to happen? And then according to the method of throwing Monad it works and show how it works and show you what I did. You only think pleasant and helpful. And that pout is not nakogo will.
LILY-P
At least you read his post, not to mention the fact that it would be nice if You would read the posts to respond to!
1. Your stupid question:
2.Statistics is in addition to Your surface lines, science! And based on that, I very much doubt that your so-called stats are a little similar to noteworthy, from others, data. Of course for You it is facts, but not for the reader of Your posts!
Is the question smart?ЛИЛИЯ-Р wrote:Why do people always vrednichaet and asks stupid questions?
Yeah! You write a lot!ЛИЛИЯ-Р wrote:All three of my post forgot to sign up
Question by ASD: It is known that the Svetlitsa-S has the focus and accordingly there is indication of the necessity of placing a label to the body ( old version disc ). Also there is mention that for a more soft, friendly perception You other people better to expand the room label to them. Is it possible having two drawing rooms to secure them together ( like a sandwich ) to You and to other people facing the label? In passing, if at all possible, will have a value of the shift of the structures depicted on fotonovela inside the parlor relative to each other when shifting them around its axis ( it is not clear how they will have each against the other-because the discs are opaque, with cards of course more clear - the location of the element inside may repeatable and symmetrical )?
Владимир МокрушинысЮ
Guest was me. Not an option - the front room in the form of a disc on the back will protrude, giving rise to puzzling questions, such as work colleagues, and in addition that there companion will go after bodily barriers? Waiting for an answer ASD.Владимир МокрушинысЮ wrote:Guest hang on the back label forward, then at you the impact will be, and the other person would perceive you better.
Thrust Chamber With associated with the model flow. Of course, if you put them together opposite sides, the flow will be extinguished. However, they can move relative to each other at a distance of 3-4 diameters (E.g. put in different pockets). Then there will be an additional stream between the Parlor that will complement their action.The rotation around the axis does not affect the quality of work of this tandem.Anonymous wrote:Question by ASD: It is known that the Svetlitsa-S has the focus and accordingly there is indication of the necessity of placing a label to the body ( old version disc ). Also there is mention that for a more soft, friendly perception You other people better to expand the room label to them. Is it possible having two drawing rooms to secure them together ( like a sandwich ) to You and to other people facing the label? In passing, if at all possible, will have a value of the shift of the structures depicted on fotonovela inside the parlor relative to each other when shifting them around its axis ( it is not clear how they will have each against the other-because the discs are opaque, with cards of course more clear - the location of the element inside may repeatable and symmetrical )?
Between the parlor in the same plane need the distance in 3-4 diameter for the formation of additional flow, with a smaller distance, the flow value will fall, they will interfere with each other? It is necessary that the orientation of the labels was the same, and if not, how will this affect the tandem? What do You think, hypothetically, if there is a possibility to operate the parlor in conjunction, the maximum expression of this property, could be presented as a ranked room ( 3-4 in diameter ), with the same or change ( one ) orientation labels? So probably works Mat-grace, but he for home, and surrounded by external people will have to think about them, illuminating the inverted parlor...АСД wrote: Thrust Chamber With associated with the model flow. Of course, if you put them together opposite sides, the flow will be extinguished. However, they can move relative to each other at a distance of 3-4 diameters (E.g. put in different pockets). Then there will be an additional stream between the Parlor that will complement their action.The rotation around the axis does not affect the quality of work of this tandem.
Previously experimented "Cloak", under the clothing on his back - Pad "Grace", manifested the strengthening properties of the SS. Fastened with small strings rug. Although from the cover you can get, where the volume of the products smaller than a "medallion" of the SS, and a lighter clothing to use...Мирта wrote:So probably works Mat-grace
Sincerely, MAG.no
Rug "Grace", what is there inside...
Inside another (already thinner) case, in which flexible elements, such as the "laminated paper", 30x30 mm, the distance between the centers of the elements of ~75 mm (I assume a work item Ø ≤25 mm), in number of 32 pieces (8 rows of 4 pieces), pasted on one cloth and just covered (stitched around the edge of the case) second...
Sincerely, MAG.no
Sincerely, MAG.no
That's the reason why ( from a purely hygienic reasons at least ). Mlyn, while We're talking about Mat wrote ASD obviously my question and did not notice that 3-4 post have to repeatМаг.нет wrote:pasted on one cloth and just covered (stitched around the edge of the case) second...
Sincerely, MAG.no
the Question to ASD: having a thrust chamber With a stream when the orientation of the label away from you will this thread include the energy of the owner or may be information about it? Has there been testing on GDV with an inverted parlor?
Николай11
This version of the question more correct than the previous one, but still not quite.Мирта wrote:the Question to ASD: having a thrust chamber With a stream when the orientation of the label away from you will this thread include the energy of the owner or may be information about it? Has there been testing on GDV with an inverted parlor?
SS is the difference in the parties and a comparison with the flow rather are given for illustrative purposes and does not reflect the full picture. Rather, we should talk about the anisotropy direction. An example of a flat spiral. Despite which side to look, you can see the different direction in the twist. Therefore, the flow generated by the SS - the opposite of the information structure relative to the SS. It's more of an informational quality than energy. As the word horn. When read one way - it is something radiant or pouring. In the other turns of the mountains(a), which is perceived as veering off the point (to the top).
General term of Energo-informational processes (devices, technology it.n.) very confusing and not clearly defined. There is a confusion of the concepts of energy and information and everyone understands it in their own way. Any radiation of energy. But radiation can be a carrier of information. Information can be separated from one medium and transfer to another.
Therefore, a person in the process of interaction with other systems and emits and, accordingly, transmits and receives information. And he does it continuously. Accordingly, the information flow that goes from person to person or can be further modulated, such as a Parlor. I.e. to create additional conditions for improving the exchange of information. This creates an additional feedback loop, which allows to increase the effectiveness of their information system.
The appeal Chamber in the direction of a person helps to restore its information systems and improve the mode of communication. In other words: to know you it will be better. Turning the Room you mentally reinforce its action, creating a new communication channel.
Such a mental enhancement can be done in other cases. For example, it is necessary to help the patient body. Then you localize the Parlor on the body (in the area of its projection). This is the first stage of amplification. You can go ahead. Imagine that the breath comes out of a Chamber a stream of light envelops the diseased organ. On the exhale the negative chamber sucks thread (black or brown). Try to breathe this way through the Room at least a few minutes and you will feel relief. You can do this exercise and the relief will still come (but later), because the anisotropic structure of a Chamber in their design.<
It is not clear Svetlitsa modulates the flow of information or creates an additional feedback loop?АСД wrote:further to modulate, for example the front Room. I.e. to create additional conditions for improving the exchange of information. This creates an additional feedback loop, which allows to increase the effectiveness of their information system.
Thank you!
Sincerely, MAG.no
This:АСД wrote:General term of Energo-informational processes (devices, technology it.n.) very confusing and not clearly defined. There is a confusion of the concepts of energy and information and everyone understands it in their own way. Any radiation of energy. But radiation can be a carrier of information. Information can be separated from one medium and transfer to another.
“Everything is eternal, alive and thinking. It is triune in nature: matter, energy and information, and can not be added or diminish, appear and disappear, but only moves in his Trinity from one state to the other.”
As one of the particular manifestations of the law of conservation of energy.
Sincerely, MAG.no
In my opinion, this is an artificial division. Because energy is material, and matter energetic.Маг.нет wrote: “Everything is eternal, alive and thinking. It is triune in nature: matter, energy and information, and can not be added or diminish, appear and disappear, but only moves in his Trinity from one state to the other.”
Sincerely, MAG.no
