Ideally, radial, and tight one-to-one (to obtain the scalar field), the magnetization reversal, the latter North. But it turns out expensive (unless on sale to do the installation). Magnets with radial polarization makes only to order, and minimum quantity 50 T. R. (their number depends on the size), but with different polarization goes and does 100T.R..ЗОМБИ wrote:what is the direction of the field and the configuration of the magnets needed for the magnetic conversion of the water?
Structured water
Re: Structured water
Andrei Patrushev
ie the magnets from the HDD will not work, well then I am calm, although you can probably independently from neodymium to make more powerful , but probably it is not necessary
Andrew, do You think the steel pipe will interfere with the magnetic transformation of water?
Yes, hardly the right field can be obtained on steel (magnetic) tube. The second point - magnetized the steel tube is exposed to very severe corrosion.ЗОМБИ wrote:Andrew, do You think the steel pipe will interfere with the magnetic transformation of water?
It is possible and simple to fit - just flat magnets next to one another to attach with alternating poles (last the North pole to the water)ЗОМБИ wrote:.e. magnets from HDD will not work, well then I am calm, although you can probably independently from neodymium to make more powerful , but probably it is not necessary
Gee, 15тыр in the Treasury, will have to change pipe or what... ahhhАндрей Патрушев wrote:Yes, it is unlikely the correct field can be obtained on steel (magnetic) tube. The second point - magnetized the steel tube is exposed to very severe corrosion.
I mean pile on top of each other glued and the North pole on the tube?Андрей Патрушев wrote:Possible and in a simple approach - just flat magnets next to one another to attach with alternating poles (last the North pole to the water)
Not, along the pipe current water - first one (to the pipe by any pole), then next to him another (but the tube has the other pole) and so a few one after the other with different poles, but the latter to pipe the North pole. Hardly makes sense in a too long chain (the process is exponentially), but exactly how much it is necessary - it's hard to say. Probably not less than five.ЗОМБИ wrote:I mean pile on top of each other glued and the North pole on the tube?
Not necessarily - you can make the frame from plastic. Copper and brass with steel you can not put (it turns out electrochemical couple) plus copper (and brass) diamagnetics.ЗОМБИ wrote:need tube change or what... ahhh
horseradish radish is not sweeter, still cutting, cooking. Wait to see Rivotorto -- will whoop it up... and let them lie on the shelf, although probably one I before Emerald put up input through it tacolcyАндрей Патрушев wrote:Not necessarily - you can make the frame from plastic. Copper and brass with steel you can not put (it turns out electrochemical couple) plus copper (and brass) diamagnetics.
(electrochemical couple encountered in practice, in good time the crane is changed, there is a strip of brass was corroded, the metal layers inflated)
Белый Камень
A couple, but wherever you look, brass valve and cocks are everywhere and XS for many years, the valves seals brass with virtually no options, valves Majewski, etc., etc.
while Yes, the magnets, there are all sorts ORP)) can give the amendment serious.
White Stone
Have You tried ever in old houses to change these valves?
The tube just breaks off...
However, the process heavily depends primarily on the degree of mineralization of water and the area of the electrodes... for Example, steel bolts brass body valve seat Soviet of the toilet, eaten very thoroughly and quickly.
Белый Камень
I am not saying that there is no effect at all. In older homes, and what a party it breaks when repairing begin
Izumrud-si the second day of the disabled (alter something), the water in the tank is kept ORP -440 !!
Good day,
Asking respected members of the forum explanation.
In the process of studying literature on the use of sodium thiosulfate (see another topic), I saw numerous mentions and downloaded the book of academician Bolotov about the health of the body.
In particular, AK.Bolotov says that the body needs to "zakislate", not "oxalacetate". And because people recover from any horrible diseases!
So after all, in your opinion, you need to zakislate or oxalacetate? Or to combine both methods?
Terve
should be (theoretically
) to rock the metabolic pendulum... ie to zakislate, then zaslujivaet
Terve
From the point of view of physiology it is not so simple... the Body tries to maintain homeostasis. If You always use some a measure of acidic foods, it will shift the indicators of the internal environment to the alkaline side, to compensate, and Vice versa.
In high doses, compensation may not work, at least once, and the internal environment will be determined by the enrolment ratios of substance, but then as compensation and at the expense of some of the inertia is dramatically swing the other way...
Искатель-2
you're not out there you recommend, there are few who will grasp, well, a maximum of 2 people. Let's then do the RAID. And then there are atheists. They do not in the subject.ЗОМБИ wrote:I have plasticИскатель-2 wrote:tank that the iron
safarigirl later
_________________
couldn't recommend Izumrud-si again... homemade whipped water will not drag, on taste-with nothing to compare... there is no characteristic feeling of a full stomach (as from any other water) after drinking two glasses of emerald water... there's a strong diuretic effect as from any other water...
Karovska support is very responsive to customers, I was called three times by my questions!
in short-AYS
__________________
you still flop with buckets -- then we go to you!
Let's try a couple of emerald to ProClarity. Free. Purely for the cause of the activation. Shironosov and so no money sitting.
http://forum.ixbt.com/topic.cgi?id=47:9332-172
Искатель-2
here is a chic answer that I remember (cattle detected)
http://forum.ixbt.com/topic.cgi?id=47:9332:2372#2372
NAUM
I have OO Emerald
Where do you find these filters? We have 3 brands: Aquaphor, Barrier, Geyser.
Dear Seeker and other users of Emerald
Please tell me how it is troublesome every time need water to connect the device to the faucet and wait for it to fill? Or do you have any other technical solution? What Emeralds do you have? If you buy from St. Petersburg - it Emerald Three in one Diamond or Three in one?
Искатель-2
what 50 TrЗОМБИ wrote:Andrei Patrushev
what are you - http://www.magnitos.ru/index.php?productID=311
here neodymium to stack, 1000R - 20 pieces can
Искатель-2
you have absolutely no clue, nothing I have will not connectТерве wrote:Dear Seeker and other users of Emerald
I just open the tap
and it's not the emerald, which the Bahir is osmosis+emerald
need some water for the kettle - put a 3l glass jar, after 2 min of the Bank is filled. what's the problem ?
Искатель-2
Dear Seeker,
I'm from St. Petersburg and planned to buy St. Petersburg Emerald, it is much cheaper Yarovskogo (there are over 10000 and 12900, even some promotions and discounts are). Their website http://izumrud.com.ru. There's another wiring diagram:
Искатель-2
Terve
buy anything, your St. Petersburg emerald water does not clean properly - there is no osmosis, no mineralizer, no Faraday cages
I have long made
it's not another connection scheme, this other device do. he's no osmosis and so on
I have long made
Искатель-2
here compare the diagram, what is richer ?Терве wrote:Dear Seeker,
however, I fear that the conversation to end, like no money it is expensive and so on....
