Andrew,
thanks for the comments, from your point of view you may be right.
Yes, I have realized that changing the result is not change why it happened.
I mistakenly thought that changing wave, you can change what a person thinks or to make him think in this direction.
I became interested in that because there is such a point of view:
The thought primary in relation to future events.
People can shape events in his life and his thinking.
The more he focused on a certain object of desire, the sooner it can happen. But it's a double-edged sword - he may think he focused on that object, and really to be focused on his absence, saying why it hasn't happened yet (worry, negative emotion). On the other hand, if he reflects on the event as if it already happened, ie in the present tense, there is a positive emotion, in my case, I have use some joy and I want to smile and the more I think, the more emotion (in both cases). The stronger the emotion, the stronger the effect of achieving/not achieving.
The subconscious through emotion signals us when we are in a state conducive to the achievement of a specific goal (positive emotion) or Vice versa check for that event (negative emotion).
Negative thinking not only affects the achievement of the objectives of man, but also hinders the satisfaction of needs (achievement of certain events) of your body, down to individual cells (supply cells with energy, and not only which we get from food).
With emotion, the subconscious mind signals the thoughts of the person currently thinks, and it means to be in adequate or no preference/stated goals in the past and present they themselves consciously or subconscious.
Also to achieve the purpose and condition in which we find ourselves when the idea flashes on the desired event/purpose hinders our faith, that we cherished for years and thinking about the growth of this category of events. This belief can be changed in two ways, in my opinion, hard to think long enough about the event before it escalates into a faith, or more easy (maybe not, as anyone) - by setting goals and listening to the Conductor or session L03. Most interesting, you also recommend to set goals in the form as if they already happened.
And about article, there are not all on the left side developed, there is simply put as when one group thought about the good things (positive emotions) and the other on the negative (negative emotions). Emotions this was the result, thought was the cause.
I think if they were scared that they flu can get sick, then some part certainly would be sick (they would have started to worry about sick or not sick, thereby unwittingly wanting this event, thinking about it, even if in the negative form).
In General, not really the topic of the forum have written.
