Contraindications
katuha432
Re: Contraindications
Post by katuha432 » Tue Aug 30, 2011 0:03
Hello. While listening to a disc the conductor, closer to the end of the recording, I Wake up in a strange panic, unable to move, and there is heaviness in the whole body... What does that mean? And does that apply to my installation to learn how to relax?
Post by Андрей Патрушев » Tue Aug 30, 2011 0:16
katuha432 wrote:Hello. While listening to a disc the conductor, closer to the end of the recording, I Wake up in a strange panic, unable to move, and there is heaviness in the whole body... What does that mean? And does that apply to my installation to learn how to relax?
Yes, it is one of the signs of deep relaxation, a panic, it's most likely Your reaction to unusual condition (though, maybe after some trauma with loss of consciousness).
Magin82
Post by Magin82 » Fri Sep 23, 2011 9:57
Hello. Upon first listening, the Conductor had a strong relaxation and repeated falling asleep, but now I can only listen when I needed to sleep (after a daily duty, for example), otherwise from the first minutes starts horrible discomfort such unbearable itching all over the body
Post by Андрей Патрушев » Fri Sep 23, 2011 12:40
Magin82
Hello.
Take a break. Most likely, it takes time for the changes You want.
Прохожий
Post by Прохожий » Wed May 23, 2012 4:07
Welcome.Recently purchased MM,and would like to ask:some years ago I was cured of hepatitis C,therapy was VERY difficult both morally and physically,within 1 year I was half-asleep due to the action of this drug from depression(GALAXINA)because without it the chances to withstand the treatment was INCREDIBLY small.And after therapy I was encouraged to start the head to drink a rather long course of the drug and stimulating the nervous system and most importantly, most IMPORTANTLY the brain, PHENOTROPIL.I drank it for 4 months and the head started working like a clock!But the wonderful work the brain and I have to say GREAT mood and activity(fatigue is almost never assumes)during the day after 6 PM I STARTED strong panic attacks,which I NEVER had before.The emotional coloring of the attacks were always different but the main theme was the fear that with me to happen again severe attack of pancreatitis at the time to him when I'm ready.The fear that I will suffocate for VERY strongly squeezed his chest.After the attack passed I was possessed by indifference to all that surrounds me because I realize that this could all end in a moment.And as a result a month later I was in the hospital with pancreatitis.The attacks had plagued me for quite a while.This lasted three months then I went to a specialist who diagnosed me with:hypochondriacal neurosis,Russian explained to me so I no never to use drugs from the group of AMPHITAMINES that is, those that somehow stimulate the brain and of all the nootropics I was allowed only those in which there is no hint of stimulation and sedation,Mexidol for example,but antipsychotics and tranquilizers just a REGULAR drink,but after a short one month course TERALIGEN from neuroleptics, I refused and try to cope on their own.Drink only Mexidol(anxiolytic) and Valerian.But neither epilepsy nor schizophrenia I was not there and with the heart in General,it was true in childhood a slight concussion long years 12назад.Went without consequence with the blood circulation of the head are very minor violation.Please answer can I use MM and if so what discs is better to start?Thank you in advance!<
Post by Андрей Патрушев » Wed May 23, 2012 9:50
Passer-by
Hello.
Obvious contraindications. :)
Limit the session time to 15-20 minutes with minimum brightness.
Прохожий
Post by Прохожий » Wed May 23, 2012 14:50
Good day.VERY happy with the fact that there are no contraindications!As I lay great hopes on this device.And which session you would I recommend.While the purpose of my use MM to strengthen my nervous system and lift the immune.Although in the future I would like test and out-of-body experience.More precisely, to experience consciously.Thanks in advance. :)
Post by Андрей Патрушев » Wed May 23, 2012 15:04
Passer-by
Session "r"
Прохожий
Post by Прохожий » Wed May 23, 2012 16:05
I'm sorry but what is this session well, that is what to treat them?And given my HISTORY(neurosis) what are sessions in ewih words I should stay away?And of course the question:which of your sessions would YOU recommend me from those who are on the disks.
Прохожий
Post by Прохожий » Wed May 23, 2012 18:28
About the "r" sessions, the question is removed I understand but what do you RECOMMEND me after three weeks, I poslushay them?While the goal is to get rid of the anxious depressive syndrome and I would like to know what session you're not recomendate.Thanks in advance! :)
Прохожий
Post by Прохожий » Wed May 23, 2012 18:30
Yes, by the way, together with MM I have purchased several of your CDs including "Endorphins"if I use it in parallel to the sessions of the"r" or if not in parallel then how better?Thanks in advance for the answer! :)
Post by Андрей Патрушев » Wed May 23, 2012 18:59
Прохожий wrote:And given my HISTORY(neurosis) what are sessions in ewih words I should stay away?And of course the question:which of your sessions would YOU recommend me from those who are on the disks.
You should refrain from the sessions of the "E" and disk Endorphins. Session "d" and series Theta Meditation should be "consumed" with caution - some may cause You to have depression.
Прохожий
Post by Прохожий » Wed May 23, 2012 21:44
Good day!Sad :cry: that you cannot use session "Endorphins"and series "E",what about "d"I realized very gently for 10 minutes.And what are ALL the same SESSIONS except those which you pointed out to me I still can,because there is something else for me to be less secure,thanks in advance! :)
Прохожий
Post by Прохожий » Wed May 23, 2012 21:47
And if not very difficult I could in a nutshell explain why still can not I use the Endorphins because they are created to improve EMOTIONAL state. :)
Post by Андрей Патрушев » Thu May 24, 2012 9:21
Passer-by
Because You have panic attacks, which are characterized by beta wave (more precisely, the theta-beta) activity in the brain. Although Endorphins have frequencies somewhat lower than those that occur in panic attacks but still possible "slyvania".
Post by Андрей Патрушев » Thu May 24, 2012 9:23
Прохожий wrote:And what ALL the same SESSIONS except those which you pointed out to me I still can,because there is something else for me to be less secure,thanks in advance!
Session "r".
Прохожий
Post by Прохожий » Thu May 24, 2012 12:16
Good time of day!Thanks for the reply.So if I understand correctly acceptable for me session and discs recorded at ALPHA frequencies?
Прохожий
Post by Прохожий » Thu May 24, 2012 12:45
Please forgive my intrusiveness,I just know VERY little so far in this case and ask you to answer one more my question:can I "USE" PSYCHICZNY drive RELAXATION(which I already purchased)and disc PAIN management(also already purchased),thanks in advance! :)
Прохожий
Post by Прохожий » Thu May 24, 2012 16:10
ESCHE again I apologize for my BADGERING and EXCUSE me,just everything that kasaetsja HEALTH used to get to and from!And in your FACE I see a COMPETENT specialist who KNOWS his BUSINESS and can give a specific answer to a specific question so do not try to chat on the forum esche with someone on SUCH serious ISSUES for me!So,my question:how should I read about glasses learned that the RED diodes are BASICALLY going to sessions on CONCENTRATION and can cause EXCITABLE people (which I unfortunately are YET!) even more unfounded anxiety and fear.And today calling the office I learned that my parcel which I expect from day to day with INER poison put just the red points.I ask not for reasons of fear of photoepilation,I think I do not threaten because I for half an hour watching the SUNSET in his reflection and I just should become,but about the fact that I read that the color red can heighten anxiety for me as it is not in itself,of course in the near future I'm gonna get INDIGO in the meantime, what would you recommend?Thanks in advance! :)
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Thu May 24, 2012 23:07
Прохожий wrote:in the meantime, what would you recommend
Set the minimum brightness :)
Прохожий
Post by Прохожий » Fri May 25, 2012 12:35
Good time of day.Thanks for the reply!
Прохожий
Post by Прохожий » Mon May 28, 2012 12:40
Good day!Question to Andrew.You wrote that the listening sessions on relaxation,sessions of"R" increases the action of drugs on the human body.And in this regard I would like to know are there any interactions with this drug as Dalargin(a neuropeptide),which is as anti-ULCER remedy, has the effect of anesthesia and some have to be INCREASING(up to normal)emotional state at the expense of SOME selective communication with the OPIOID receptors,but EMPHASIZE the fact that the drug IS NOT a NARCOTIC and analgesic for sale without prescription so "meek"to cheap pleasures ANY euphoria will not get him,that is, a healthy person no significant effect will not have.He assigned me a small course of 14 days,in connection with the EXACERBATION of pancreatitis,in the smallest dose.Thanks in advance for your answer. :)
Прохожий
Post by Прохожий » Mon May 28, 2012 12:42
By the way I like mashinka :D so LOOKING forward to your reply very MUCH wants to quickly start working with her! :)
Post by Андрей Патрушев » Mon May 28, 2012 12:55
Прохожий wrote:so if I understand correctly acceptable for me session and discs recorded at ALPHA frequencies?
Yes, at least to start.
Прохожий wrote:can I "USE" PSYCHICZNY drive RELAXATION(which I already purchased)and disc PAIN
Can. :)
Прохожий wrote:RED diodes are BASICALLY going to sessions on CONCENTRATION and can cause EXCITABLE people (which I unfortunately are YET!) even more unfounded anxiety and fear
It is unlikely. Any glasses turn into red when viewed through closed eyelids. :)
Прохожий wrote:You wrote that the listening sessions on relaxation,sessions of"R" increases the action of drugs on the human body.
No, not write. :? I wrote that in the regular classroom with the alpha sessions, the body itself begins to come back to normal, so some drugs (especially taken on a regular basis, in connection with chronic diseases, like diabetes, for example) can be peredozirovki while maintaining the old (familiar) dosages.
Прохожий
Post by Прохожий » Mon May 28, 2012 15:21
Thank you so much for the answer! :)
